What's the best 3.5" lift out there? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > What's the best 3.5" lift out there?
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 03-31-2002, 05:07 PM   #1
positivej12
Arrow What's the best 3.5" lift out there?
I'm looking to add a 3.5" lift to my '92 xj sport but i'm a little confused with so many differnt brands out there. i have heard good things about Rubicon Express and their stuff, but i don't know how much anything of theirs costs!! Help is needed.
2-Door Silver 1992 XJ Sport
4.0 High Output
K&N Filtercharger
Wet Okole Seat Covers
Husky Liners
3.5" RE lift
31" 15x8 MT Classic II's
Rusty's cat-back
High-flow cat
Draw-Tite Hitch and a new trailer!!!
Some other things but that's enough.
134,000 miles and in great shape
positivej12 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2002, 08:24 PM   #2
TJs96XJ
Post
I hope this helps a bit, I recomend the RE 3.5 or the 4.5 inches. Rusty's 4.5" Kit w/ rear Spring Pack
• 2 - 4.5 inch Coil Springs
• 2 - 4.5 inch Rear Springs
• Front Adjustable Trac Bar
• Lower Control Arms
• TC Drop Kit
• Brake Line Extension Kit
• Front Sway Bar Extensions
• 4 - Rusty's Hydraulic Shocks $669. 00 + s/h $754.00
Rusty's 3" Kit w/ Rear Spring Pack
• 2- 3 inch Coil Springs
• 2- 3 inch Rear Springs
• Rear Brake Line Extension
• 4 - Rusty's Hydraulic Shocks $418.00 + s/h $503.00
Rusty's Adjustable Trac-Bar #TB-100 $129.00
Rusty's Adjustable Trac-Bar w/ Frame Mount #TB-200 $189.00
Trac-Bar Frame Mount #TBM-150 $89.00
RE Hiem Conversion Kit #TBM-RE $99.00
Upper Control Arms$115.00/pr
Lower Control Arms$115.00/pr
Adjustable Upper Control Arms$169.00/pr
Adjustable Lower Control Arms$169.00/pr
Adjustable Trac-bar$129.00
Adjustable Trac-bar w/ HD Frame Mount$189.00
1.75 Poly Spacers$38.00
.75 Poly Spacers$31.00
1.5 inch Short Add-A-Leaf$29.00
2 inch Full length Add-A-Leaf$59.00
3.5 inch Full Length Add-A-Leaf$59.00
3 inch Rear Replacement Springs$209.00/pr
4.5 inch Rear Replacement Springs$209.00/pr
*NEW* 6 inch Rear Springs$299.00/pr
3 inch Front Coil Springs$99.00
4.5 inch Front Coil Springs$129.00
6.5 inch Front Coil Springs$149.00
.75 Extended Greasable Shackle$59.00
1.5 Extended Greasable Shackle$69.00
Transfer Case Drop Kit$12.95
Front Sway Bar Disconnects$59.00
Front and Rear Sway Bar Drop$18.00/pr
Front Bump Stops$28.00/pr
Rear Bump Stops$28.00/pr
Front and Rear Brake Line Extension Kit$10.00
Front and Rear Stainless Steel Brake Lines$89.00
2 inch Bump Stops$28.00
Poly Rear Bump Stops$35.00
1 inch Block Kit w/ U-bolts$39.00
2 inch Block Kit w/ U-bolts$49.00
Cherokee Super-Poly Bushing Kit$128.00HD
Grade 8 U-bolts$6.95/ea
RUBICON EXPRESS Cherokee XJ 4.5" suspension
RE6111 $749.95
The RUBICON EXPRESS Cherokee XJ 4.5" suspension system is the kit of choice for those who use and abuse their Jeeps on the world's toughest trails. These kits are built to perform. We have designed these kits to increase wheel travel dramatically while maintaining excellent road handling. The kit includes: 2 front coils, lower "Super-flex" control arms, upper chro-moly control arms, adjustable chro-moly trac-bar, extended front quick disconnects, extended rear brake line, 4 shocks, U-bolt kit, rear block kit, and full-length rear add-a-leaf. Recommended tire size is 32x11.50, 33x9.50, 33x10.5 or smaller.
RUBICON EXPRESS Cherokee XJ 3" suspension lift
RE6010 $499.95
The RUBICON EXPRESS Cherokee XJ 3" suspension lift is an excellent choice for the customer who wants a vehicle that will handle all the rough stuff and still feel like a stocker on the road. This kit includes every thing the 4.5" kit does less the upper arms, block/U-bolt kit and trac-bar. With this kit we recommend tire sizes 31x10.5 and smaller.
XJ Super-Flex Kit 4.5" 1984-2000 $749.95
XJ Standard Kit 2" 1984-2000 $199.95
XJ Super Ride 3.5" 1984-2000 $399.95
XJ Super-Flex Kit 3" 1984-2000 $499.95
XJ Super-Flex Kit w/Rear Springs 3.5" 1984-2000 $749.95
XJ Super-Flex Kit w/Rear Springs 4.5" 1984-2000 $949.95
"80" CJ7 Just sitting right now my son will be old enough soon to help with his jeep
"87" Cherokee
"89" Cherokee Mud-dog
"96" Cherokee Country 3.5 RE Lift IT REALLY IS A JEEP THING!!!!!!! $3,100 wish list down from $4,600 God made earth in 6 days and went WHEELINNG on the 7th
TJs96XJ is offline   Reply With Quote Quick reply to this message
