What Year XJ's were Full Time 4x4? - JeepForum.com
post #1 of 15 Old 01-26-2009, 09:38 PM Thread Starter
lazermule
So what years of XJ's were full time 4x4? I just bought a 1996 and I would just like to pull it home with my car dolly if possible. I believe if it is a full time 4x4, this may not be possible. Any chance a 1996 is full time?
LM
lazermule is offline
post #2 of 15 Old 01-26-2009, 09:39 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
http://www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/ 84-87 only.
xjfever is offline
post #3 of 15 Old 01-26-2009, 10:07 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
it was an option from 84-01.
Factory Four Link
XJLI is offline
post #4 of 15 Old 01-26-2009, 11:22 PM
93gc40
Non were FULL TIME 4wd that I know of . Some have the 242 transfer case which has a 4FT option, in addition to the 4hi and 4lo. If you are going to tow it put the transfer case into neutral. You should be OK
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #5 of 15 Old 01-27-2009, 08:16 AM Thread Starter
lazermule
That is kind of what I thought. I didn't look that close when I bought it and the thought crossed my mind when I thought about using the tow dolly.
post #6 of 15 Old 01-27-2009, 11:44 AM
cbordea
Am I right in saying if it has an automatic tranny that you can't tow with the back wheels on the ground (very far) or it will overheat the tranny? I have that concept in my head from somewhere.
cbordea is offline
post #7 of 15 Old 01-27-2009, 11:47 AM Thread Starter
lazermule
I would think you could tow it if you put the transfer case in Neutral. The one I will be towing is a 5spd and the trans is junk.
But you are correct, if there is no unlock such as a transfer case, it's not a good idea to tow an auto vehicle very far or very fast.
LM
post #8 of 15 Old 01-27-2009, 11:50 AM
bluejunior
bluejunior's Avatar
its not about year models its about selec-trac or command trac transfer case. but it SHOULD NOT be in gear at all if you're towing it you should set the tranny and the transfer case to Nuetral.
ps selectrac with fulltime 4x4 will have 4L, N, 2H, 4H, and 4HFT
the command track will not have that fifth option on the shifter (4HFT)
bluejunior is offline
post #9 of 15 Old 01-27-2009, 01:34 PM Thread Starter
lazermule
Wont be a problem putting the one I'll be towing in neutral, that is the problem, it is stuck in neutral.....
LM
post #10 of 15 Old 01-28-2009, 04:17 AM
MrBuick
1990 XJ Cherokee
LM
I found this out the hard way. Nobody had a real answer WHY, so I did it anyways. Put a 96 Caprice up on a tow dolly(had to push it up on there, in the rain.... ), and drove home 300 miles with it behind my Buick. I figured it was hard on the trans. But the trans already had no 3rd or 4th gear. Got it home, got it running the next day, and took it for a drive... Noticed a whine, but thought it was the trans. the whine left if you kept your foot on the gas... I was going over a bridge, and let off the gas as I came down... Both rear tires locked up at 40mph, and I started dumping gear oil all over, as the driveshaft beating the Sh*t out of the mufflers, and rear floor pan.
The Pinion Nut went MIA, and the pinion made great friends with the Posi.
Maybe that is why? After I rebuilt the Rear end with better gears, I just had to laugh.
~Cory Magner "My name is Cory, and I'm an addict."
95 Maroon Buick Roadmaster.
180k, Headers, Catback, 3.73's, 3000 stall... yea... It's FAST.
90 White Cherokee - Traded a 96 Caprice for it.
140k, Rusted body, Bald tires, & non-working 4wd mods. Summit Turbo Muffler. Aussie D30/D35 & posi-lock, waiting to go on.
MrBuick is offline
post #11 of 15 Old 01-28-2009, 04:18 AM
MrBuick
1990 XJ Cherokee
But, Jeeps are one of the vehicles you can safely tow behind an RV, with the tires on the ground.
MrBuick is offline
post #12 of 15 Old 01-28-2009, 04:25 AM
Motorcharge
4FT is FULL TIME.
You're thinking AWD.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #13 of 15 Old 01-29-2009, 03:54 AM
spnkr94
You must be on ISSF too, just sold my caprice and bought this xj to build....cheaper on gas so far.
spnkr94 is offline
post #14 of 15 Old 01-29-2009, 04:03 AM
LobstahJeep
Ok so what would be the difference between full time and part time in my 95? I have 2wd/4HFT/4HPT/N/4L, where should I have that if I am driving in the snow on the road?
1981 CJ7
2001 XJ
ΜΟΛΩΝ ΛΑΒΕ
LobstahJeep is offline
post #15 of 15 Old 01-29-2009, 04:37 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
You should be in FT while driving on snowy roads. If you get stuck or need more traction, toss it into PT.
Oh, and if you haven't yet, visit us at www.midcoastjeep.com and www.maine4x4.com if you're interested in wheelin'.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
NP242 Transfer Case: Full Time and Part Time, What's The Difference? 89SAFARIXJ XJ Cherokee Technical Forum 62 10-27-2013 09:17 PM
transfer case problem ? please leave input, part time/full-time robdoggydog1 XJ Cherokee Technical Forum 8 11-26-2009 10:51 AM
Does Front Locker Lock on all Levels (Full-Time, Part-Time) CalebsXJ XJ Cherokee Technical Forum 4 11-09-2009 10:04 AM
What year is the best for XJ's XJ OnTheBeach88 XJ Cherokee Technical Forum 62 04-10-2007 03:17 PM
Which year is the best for XJ's bajaviking XJ Cherokee Technical Forum 17 05-27-2005 09:40 AM
