What is wrong?? - JeepForum.com
post #1 of 4 Old 09-29-2010, 04:16 PM Thread Starter
Cro577
What is wrong??
Okay, so I have a 1991 Limited it runs flawlessly, until you look at the speedo, its the only gauge that doesnt work.. But it isnt just a not working deal, sometimes it works, othertimes it doesnt work.. What is wrong with it? is there a way to fix it or do I need to get another cluster?
Also, the Right-rear turn signal has stopped working, the bulb is still good and when I go and hit the turn signal to turn right, the blinker light, just stays on... Is there a way to fix that also? Thanks in advance!
-Cro
Cro577 is offline
post #2 of 4 Old 09-29-2010, 05:13 PM
XJcruiser
If the rest of the gauges work, your cluster is fine. Check the electrical connection at the transfer case. It may be a loose connection or a short.
XJcruiser is offline
post #3 of 4 Old 09-29-2010, 05:15 PM
Paradise XJ
1988 MJ Comanche
The blinker socket ground is probably corroded or clogged with crap...that's inside the socket. Check to see if there is hardened "grease" in there. Clean it out gently. If it breaks you'll have to replace it.
Don't know if your speedo is electric or cable run. If electric, the sensor is likely going out, it's on the transfer case. If cable driven check the length of the cable for nicks and/or corrosion and how it connects to the cluster. My cable is a little bent so it wiggles under 45 mph.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #4 of 4 Old 09-29-2010, 05:23 PM Thread Starter
Cro577
Okay so, I didnt know that my dad checked the blinker, but he said that he checked the blinker wire with his meter thingy (forgot what its called) and it has no power... So where would the wire most likely short...
Cro577 is offline
speedo , tach , tachometer , turn signal , xj
You're doing it wrong! andersaur XJ Cherokee Technical Forum 5 03-10-2009 06:17 PM
What could be wrong? lilseth0014 XJ Cherokee Technical Forum 3 03-04-2007 09:34 AM
Something wrong with Jeep's record of my vehicle - wrong build sheet prior2 XJ Cherokee Technical Forum 16 12-21-2005 04:47 AM
Something gone wrong? devile XJ Cherokee Technical Forum 1 06-12-2005 09:49 PM
WTF is wrong now?? fisher446 XJ Cherokee Technical Forum 16 05-29-2005 11:54 AM
