what would cause my exhaust manifold to glow red? - JeepForum.com
post #1 of 18 Old 09-05-2009, 03:09 PM Thread Starter
white93xj
After about 5 mins of running the exhaust manifold glows red. I know this not normal. The Jeep runs pretty good with the exceptions of an intermittent high idle. Clogged Cat? Running rich/lean? Although if it ran rich/lean wouldn't that through a code?
98 4dr XJ 4.0 Sport
white93xj is offline
post #2 of 18 Old 09-05-2009, 03:11 PM
Holder350
1995 XJ Cherokee
My bet is a vacuum leak causing a lean mixture.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 18 Old 09-05-2009, 03:26 PM
tjjeepwrench978
1997 XJ Cherokee
cloggered cat
tjjeepwrench978 is offline
post #4 of 18 Old 09-05-2009, 05:37 PM Thread Starter
white93xj
Wouldn't a Lean Mixture cause a CEL?
98 4dr XJ 4.0 Sport
post #5 of 18 Old 09-05-2009, 06:11 PM
tangofox007
Not if a bad oxygen sensor fails to recognize the lean mixture. In fact, the oxygen sensor could well be the root cause of the problem.
tangofox007 is offline
post #6 of 18 Old 09-05-2009, 09:25 PM
JeepRide
JeepRide's Avatar
Is your cat converter glowing red?
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #7 of 18 Old 09-06-2009, 09:57 AM Thread Starter
white93xj
Cat is not glowing red only manifold up to the section where it turns into one pipe. It's also intermittent. I started her up last night and she idled and ran fine. Im stumped and don't want to throw money at guesses. It feels like I have good pressure at the tail pipe when I start her.
If the o2 sensor were bad and not picking up the lean mixture, wouldn't I get a code for the o2 sensor?
98 4dr XJ 4.0 Sport
post #8 of 18 Old 09-06-2009, 11:53 AM
93gc40
ye, re-read changed question.
Do you have any codes?
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #9 of 18 Old 09-06-2009, 12:14 PM
Holder350
1995 XJ Cherokee
when you first turn the key on does the CEL come on then go off?
post #10 of 18 Old 09-06-2009, 01:01 PM Thread Starter
white93xj
I do have a CEL, It's for EVAP Leak Large detection. It also through a TPS code ( But I think thats from unplugging it to see if it had changed the idle quality.) No code for the O2 sensor or rich/lean air/fuel mixture. I drove her today and she's running fine. (Manifold looks to be normal temp, not glowing). You think the intermittent high idle has something to do with the manifold getting red hot?
98 4dr XJ 4.0 Sport
post #11 of 18 Old 09-06-2009, 02:09 PM
natertots
1990 XJ Cherokee
THe high idle is due to your tps so change or try and adjust it, and it could fix your exhaust problem too.
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #12 of 18 Old 09-06-2009, 04:03 PM Thread Starter
white93xj
When I unplug the TPS with the car running the idle bumps up and down then steady's itself. Does this mean the TPS is bad? When I unplug the IAC nothing happens.
98 4dr XJ 4.0 Sport
post #13 of 18 Old 09-06-2009, 07:55 PM
jim41889
i would clean your iac mine got suck open and it turned really red and i was freaking out cuz i was running about 45 and the jeep just kept going like the cruise was on wehn i finally pulled over i was sittin at abou 1750 rpms and i got some carb cleaner and havent had a problem since. just clean it out really good
jim41889 is offline
post #14 of 18 Old 09-06-2009, 09:53 PM Thread Starter
white93xj
I cleaned it very well, it wasn't in that bad of shape. I want to check the tps, can I use a digital fluke meter? If so how do I Go about testing it?
98 4dr XJ 4.0 Sport
post #15 of 18 Old 09-06-2009, 10:44 PM
Finaltheorem47
1992 XJ Cherokee
When I messed up my timing, my pipes were glowing red all the way through to the muffler lol.
Pull and read your plugs.
Finaltheorem47 is offline
exhaust manifold shawnxj XJ Cherokee Technical Forum 0 12-25-2008 10:49 PM
Which exhaust manifold? xjfan XJ Cherokee Technical Forum 6 04-04-2008 09:19 AM
exhaust manifold Rescue XJ XJ Cherokee Technical Forum 7 02-23-2008 11:28 AM
Exhaust Manifold Exhale XJ Cherokee Technical Forum 4 08-07-2006 11:33 PM
Exhaust manifold jeepinarkansas XJ Cherokee Technical Forum 6 03-10-2005 12:00 PM
