What U Joint do I need? Guaranteed not in search :) - JeepForum.com
post #1 of 8 Old 07-05-2012, 02:14 PM Thread Starter
Ruffnek
I have a '98 Cherokee, and every time I've gone to get a rear U Joint for the rear drive shaft, I get one that is too small and have to bring them the one I removed. Apparently it has some heavy duty driveshaft...anyone heard of this? To make things more difficult, I put in a TJ Rubi D44, with the stock driveshaft, so can anyone tell me what U Joint I require? I think it has 2 different sizes of ends...
Thanks!
Ruffnek is offline
post #2 of 8 Old 07-05-2012, 02:47 PM
Millermagic
I have a stock driveshaft in mine and it's the same front and back ...
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 8 Old 07-05-2012, 03:44 PM
Timo_90xj
Timo_90xj's Avatar
I would place my bets on a 1330 u-joint. Stock driveshaft u-joints are 1310.
Check the u- joint measurements:
* 1310 cup diameter 1.062" (1 1/16"), width of the joint 3.219" (3 7/32")
* 1330 cup 1.062" (1 1/16"), width of the joint would be 3.622" (3 5/8").
It's the same thing with my ZJ niner, every place is selling me 1310 u- joints, although the rear DS has 1330 joints. Same goes for some XJs, dunno why some of them have 1330 joints in the rear..
***Under construction***
Timo_90xj is online now
post #4 of 8 Old 07-05-2012, 04:03 PM Thread Starter
Ruffnek
That actually sounds familiar, but what about the D44 Yoke? I think it's different...
Ruffnek is offline
post #5 of 8 Old 07-05-2012, 04:09 PM
RLE
2x Timo. My 98 5-speed uses a 1330 joint at the rear diff. The Chrysler p/n is 4746-936 and the Spicer equivalent is the 1330-X. According to the .pdf 1997-1999 Jeep Cherokee Parts Catalog I have, the 1330 size joint was used on 4.0 6 cyl with a 5-speed.
Northern Drivetrain has some great info on their site for sorting out u-joints and they sell Spicer.
I ordered mine from them last year - great service.
http://www.northerndrivetrain.com/ca...ints_1330.html
RLE is offline
post #6 of 8 Old 07-05-2012, 04:09 PM
Timo_90xj
Timo_90xj's Avatar
Depends on the D44, but a lot of them use 1330- series yokes. I can't remember which one TJ rubi's use, but I'm fairly sure they are 1330- series yokes/ u- joints.
Just go out and measure, that's the easiest way
post #7 of 8 Old 07-05-2012, 04:19 PM
RLE
Sorry Ruffnek, I posted without taking into account that you changed to a D44. What I said applies to when your wehicle was stock.
If you measure the cup size and the lengths as Timo posted, then take a look at what is available on
that Northern Drivetrain site and you'll probably find a Spicer joint that will fit.
RLE is offline
post #8 of 8 Old 07-05-2012, 04:26 PM Thread Starter
Ruffnek
Well I do have the 5 speed so maybe that's where the confusion always happens at the part store. I just went outside and measured and they seem to be the same size cups both ways, and the same width, I'll try a 1330, maybe this wasn't as complicated as I thought.
Thanks!
Ruffnek is offline
cherokee , dana 44 , u joint , universal joint , xj
U-joint Ear was not seated in the front yoke today...should I replace the U-joint? gistecknician XJ Cherokee Technical Forum 1 01-04-2010 09:41 PM
ball joint and u joint replacement xGArfx XJ Cherokee Technical Forum 5 08-02-2009 06:25 PM
Ball Joint/U joint recomendations FG Jeep XJ Cherokee Technical Forum 12 06-21-2009 09:41 AM
U-Joint/Ball Joint questions Arcticcat843 XJ Cherokee Technical Forum 3 01-08-2007 03:32 PM
U-Joint questions (yes ive done a search) lma1973 XJ Cherokee Technical Forum 28 06-16-2005 06:52 PM
