the Jeep leaked all of my transmission fluid out. i figured out where it was leaking from, the hose from the radiator had come apart. so i fixed that but what type of transmission fluid does the AW4 use??
Thanks,
Jack
transmission dipstick tube under the hood. You'll need a funnel with a small end. Most auto parts stores should carry one that will work. I got one from Autozone with a step-down at the end and it fits into the trans tube perfectly.
4 qt is only the content of the pan when you flush it. If you have had a leak you might have lost more than just the pan capacity. Make sure you check the level frequently after you refill it as the fluid needs to recirculate across the transmission and fill the 'gaps'. The proper procedure to refill is to have the engine running and add the fluid. Check the warm and cold level as level.
It is very important that you use the right fluid (Dex/Merc III as mentionned).
- Drain and Re-fill = 4 Quarts (3.8L)
- Filter and complete fluid exchange = 8 Quarts (7.8 L)
-2.5L (4cyl) Chrysler/Mopar Automatic Transmissions use ATF+3 or ATF+4 Type 7176
Manual Transmission
Chrysler now recommends the use of 10w-30 motor oil
-AX-5 5 speed manual - 3.3 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in some Owners Manuals)
-AX-15 5 speed manual - 3.32 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in some Owners Manuals)
-NV3550 5 speed manual - 2.1 quarts Mopar fluid part # 04874464AA or Snychromax (meets Mopar MS-9224 specs)
The NLGI specs are important - typical NLGI GL-5 gear oil carries added sulphur used as an Extreme Pressure (EP) lubricant. Especially when heated, sulphur is antagonistic to yellow (copper-based) metals - and the synchronizer rings and any bushings in the AX-15 are bronze. Most synthetic gear oils are rated GL-5 and are listed as "safe for use with yellow metals."
Unlike API motor oil specifications (to API Service SL/CJ-4,) NLGI Service specifications are not reverse-compatible.
If you want to use a synthetic (RedLine, AmsOil, etc.) either check the back of the bottle or check the manufacturer's website to make sure it's safe for use with yellow metal - using sulphur-bearing gear oils usually results in draining your synchronizer rings at your next fluid change...
Transfer Case
-NV231 Part-Time (Command-Trac) - 2.2 Pints (1.0L) Dexron III/Mercon
Gear oil is gear oil, any brand will do. I prefer brand names and most auto parts store have several to choose from. Valvoline and Mobile are common but I have used the generic stuff from the Farm and Fleet store also.
I hear for the diffs if you offroad or tow. You should use 75/140? Anyone heard of that. Is it a bad idea to use or is it an upgrade from the 75/90?
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
