What Torque Converter 86 Cherokee? - JeepForum.com
post #1 of 5 Old 11-14-2005, 10:03 PM Thread Starter
MRoth
We need to get a new torque converter for the "new" tranny we're putting into our 86 Cherokee & I don't know if it's a locked or unlocked torque converter? Does anyone know what it would be or how to tell? It's got the gutless 2.8L V6 engine.
Thanks!
Mike
Michael Roth
Mine:
1987 Jeep Grand Wagoneer, Building up for offroading
1982 Mercedes 300 TDT Wagon
1953 Dodge B4-F 1 1/2 Ton Stake Bed, Restoration Project
Hers:
1999 Jeep Cherokee, 3" lift, 31" BFG's
1990 Jeep Wrangler 3" lift, 33" General's
1986 Jeep Cherokee, stock
MRoth is offline
post #2 of 5 Old 11-14-2005, 10:55 PM
Rabindranath68
no clue but this was in the stock specks on the forum im sure if you do some more research with this little bit of information you will find ur awnser
Manual Transmissions
AX4 - 4 speed manual - manufactured by Aisin - used 84-86 with 2.5L I4 and 2.8L V6 engines
T4 & T5 - 4 & 5 speed manual - manufactured by Borg Warner - used 84-86 with 2.5L I4 and 2.8L V6 engines
BA10/5 - 5 speed manual - manufactured by Peugot - used only up to 89
AX5 - 5 speed manual - manufactured by Aisin - used with 2.8L V6 and 87+ with 2.5L I4
AX15 - 5 speed manual - manufactured by Aisin - used with 4.0L I6 engines
NV3550 - 5 speed manual - manufactured by New Venture - used in 00-01 in SE models with 4.0L I6 engines
Automatic Transmissions
Torqueflight 904 - 3 speed automatic - used 84-86 with 2.8L V6 and 2.5L I4 engines
30RH - 3 speed automatic - used with 2.5L I4 engine 94?-00
AW4 - 4 speed automatic, electronically controlled - manufactured by Aisin - used from 87-01 (87-91 models include a Power/Comfort button that adjusts the shift points)
98 Cherokee Sport
163,000 miles
Roof Rack w/ 2 walmart lights
30x9.5 Bridgestone Revos
Stock
Rabindranath68 is offline
post #3 of 5 Old 11-14-2005, 11:28 PM
cmotsvt
Id think a parts store or tranny shop could fix you up nicely.
cmotsvt is offline
post #4 of 5 Old 11-15-2005, 11:50 AM Thread Starter
MRoth
I saw the stock specs, but they don't help me identify if it's lockup or not. The only parts store that carries torque converters is Autozone around here & they list both, but don't tell how to tell the difference either. I'll try giving them and maybe a tranny shop a call to see if they can help.
Michael Roth
Mine:
Hers:
MRoth is offline
post #5 of 5 Old 11-15-2005, 12:45 PM
cmotsvt
I would suspect its a locking torque converter. Maybe Jeep could help you, not sure since its pre chryco.
cmotsvt is offline
torque converter doesn't lock up 93 Cherokee mec93cher XJ Cherokee Technical Forum 0 12-28-2008 06:03 PM
Torque Converter bomba6213 XJ Cherokee Technical Forum 4 07-04-2008 09:18 AM
torque converter seal leaking=new converter?? iwishihad1 XJ Cherokee Technical Forum 3 01-23-2008 07:38 PM
HD Torque Converter? '88 Cherokee XJ Cherokee Technical Forum 3 09-07-2005 02:55 PM
torque converter rapha XJ Cherokee Technical Forum 0 04-14-2003 03:33 AM
