Quantcast What size tire can be run on a stock tire carrier - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > What size tire can be run on a stock tire carrier
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 06-21-2006, 07:23 PM   #1
hmmhoyhoy
I want to run a 32x11.50 or a 33x.11.50. Does anyone run this setup on a stock tire carrier. I can get one from a guy for 20 bucks so I figured why not. Im sure someone has done this and reinforced it or something
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline   Reply With Quote
Old 06-21-2006, 07:28 PM   #2
Blue XJ
1988 MJ Comanche
What do you mean by stock tire carrier? LIke that bolt on the inside? My 32's don't fit on the inside.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 06-21-2006, 07:29 PM   #3
hmmhoyhoy
No, the ones that go on the rear of the XJ{swing away}
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
Old 06-21-2006, 07:58 PM   #4
RWB214
I think they only made stock rear xj tire carriers for a few years back in the 80's, is that what you're thinking of? Basically if the steel looks strong and rugged, and the tire physically fits on there, I'd say why not.
RWB214 is offline   Reply With Quote
Old 06-21-2006, 08:42 PM   #5
hmmhoyhoy
Yeah they made it on like 86.87 and 88 that I know of, this ones off an 87 and its in great shape but I dont want to much weight and have it rip out. Does anyone who runs this know
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
Old 06-23-2006, 08:06 AM   #6
RWB214
to mount it on the body without worring about it ripping out you can put a steel plate on the inside of the sheet metal to distribute the weight of it. Other than that go with the stock mounts? I'm not sure where they are though.
Old 06-24-2006, 12:00 PM   #7
TheNerd
I just recently put some 32's on my swing away carrier (87'). It has started making squeaking noises from the upper ball joint on the passenger side of the jeep. Other than that, it seems to be okay. Crank up the stereo and the squeak goes away. I don't see the added weight of the tire ripping the carrier off or anything... at most perhaps a rebuild of the upper joint at some point in the future.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is online now   Reply With Quote
Old 06-24-2006, 01:09 PM   #8
tvisXJ
1987 XJ Cherokee
I have an aired down 31x10.50 on mine
Current Jeep condition: SOLD :*(
tvisXJ is offline   Reply With Quote
Old 06-24-2006, 09:31 PM   #9
hmmhoyhoy
Sweet, I am gonna go for it. Thanks guys
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
