What size speakers do my 2000 cherokee have? - JeepForum.com
post #1 of 8 Old 09-16-2004, 08:41 PM Thread Starter
McDunna
Is it 5.25 all around?
McDunna is offline
post #2 of 8 Old 09-16-2004, 08:44 PM
86cherokeexj799
86cherokeexj799's Avatar
yea it should be 5.25 all around.
dave
1986 Cherokee with 3 inch Rusty's kit (not AAL)
33x12.5 BFG M/T's
Dana 44
Rigid FbW2 winch bumper
Powertrax Rear
4.56's
86cherokeexj799 is offline
post #3 of 8 Old 09-16-2004, 08:47 PM Thread Starter
McDunna
thanks
McDunna is offline
post #4 of 8 Old 09-17-2004, 01:54 AM
Roll Tide
Roll Tide's Avatar
Here is the info from crutchfield
But yes it is 5.25 all around. And it seems you could go a little bigger in the rear.
Roll Tide is offline
post #5 of 8 Old 09-17-2004, 04:42 AM
01xjrock
yeah... I have an 01... with the speakers up along the roof in the back... you can definitely put 6.5's up there. The 6.5's I have stuffed up there are some of the biggest 6.5's that you could possibly buy, and although not easy, they did get stuffed in there (most of the problem was weight, not size). I had to return the matching pair of 5.25's for the front because they were way too big to fit into the front. With that said, you need a small(er) sized 5.25 for the front and virtually any size 6.5 for the rear. I bought my speakers from 6th Ave. and they had 5.25's all around in the computer too for some reason. I think it was a mistake that older cherokees had 5.25's.
2001 cherokee sport - Red
JVC SH707, stinger rca's and monster cables, JL slash series amps, JL TR interiors, Kicker L7 sub. Wet Okole seat covers, Class III hitch, Flowmaster Delta 40 series and K&N style intake, tow hooks, 2 inch BB, cross drilled rotors, 30" BFG AT/KO, some cheap pep boys driving beams. Next on the list: OME 2" spring lift, real K&N FIPK, locker? (I wish)
01xjrock is offline
post #6 of 8 Old 09-17-2004, 11:19 AM
86cherokeexj799
be careful drilling and screwing into the rear hatch though, its fiberglass and screws pull throuh like crazy. i don't know how you mounted your 6.5s because they didn't have that on my xj. use some sort of plasic fastener to get them to hold.
dave
33x12.5 BFG M/T's
Dana 44
Powertrax Rear
4.56's
post #7 of 8 Old 09-17-2004, 12:45 PM
01xjrock
yeah... on the ceiling mounts there is basically a plastic mold. Small speakers could probably be just drilled in and it would hold. Mind were so heavy that I actually used two bolts on each and then, like you said, screws that went into fasteners. Then I couldn't put the stock speaker grills on afterwards, and had to use the aftermarket ones. This is not typical of most 6.5 inch speakers though. Previosly I had Boston Acoustic 6.5's and they fit up easily. JL TR series 6.5 would have sit up there nicely too, but I have these big, heavy Alpines... they are the top coaxials that Alpine makes and they are massive.
I highly recommend the JL TR series... they are actually the cheapest JL's made, but they have won sound competitions when it comes to actual clarity... they are also easily mounted as their magnets are not too big.
01xjrock is offline
post #8 of 8 Old 09-18-2004, 04:02 PM
oopswithanxj
cherokee speakers
i have a 2000 cherokee and my ft doors are 5 1/4 and the rear speakers are 6 1/2
oopswithanxj is offline
2000 Jeep Cherokee Sport Front Speakers JonV XJ Cherokee Technical Forum 10 09-01-2012 09:14 PM
What tire size for a 2000 Jeep Cherokee WBetheajr XJ Cherokee Technical Forum 9 02-21-2010 03:26 PM
Rear Drum size on 2000 Cherokee LTD mww1962 XJ Cherokee Technical Forum 6 10-30-2007 10:40 AM
2000 Cherokee Tire Size? sperrydan XJ Cherokee Technical Forum 8 05-25-2007 02:20 PM
2000 cherokee speakers davetutk XJ Cherokee Technical Forum 3 04-29-2004 09:35 AM
