What size bolt for the lower thermostat housing? - JeepForum.com
post #1 of 11 Old 10-11-2009, 03:14 PM Thread Starter
amgqmp1
I've just spent five hours running to the hardware store and back trying to get a usable replacement for the lower thermostat housing bolt. I have lost mine.
Anyone know what size the bolt is and/or where I can buy one from?
amgqmp1 is offline
post #2 of 11 Old 10-11-2009, 06:14 PM
Team Beater
why dont you take the one from the top with you to compare?
Team Beater is offline
post #3 of 11 Old 10-11-2009, 06:34 PM
XJMuscle98
I want to say 2" but I'm not sure.
I know its 13mm
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #4 of 11 Old 10-11-2009, 07:27 PM Thread Starter
amgqmp1
Thanks to both of you! I'm going to head over to NAPA tomorrow with the top bolt (the thread is a match, the size of the bolt is not). I need a fresh gasket anyhow after my many hours of wrenching trying to get bolts that thread, but do not tighten, to work.
amgqmp1 is offline
post #5 of 11 Old 10-11-2009, 09:00 PM
cobra
1987 XJ Cherokee
one is long and one is short.. not the same length
cobra is offline
post #6 of 11 Old 10-12-2009, 04:11 AM
XJMuscle98
thanks. he wants the bottom which is short
Ronald Reagan
Currently: 10
post #7 of 11 Old 10-12-2009, 09:19 AM Thread Starter
amgqmp1
Thanks for the replies! If I can get a usable replacement at the auto parts store today, I'll post the size of the bolt I purchased to help with future searches.
amgqmp1 is offline
post #8 of 11 Old 10-12-2009, 01:12 PM Thread Starter
amgqmp1
5/16" x 1 3/4" (Coarse Thread) looks like a proper replacement. I assume a 2" long would normally work too. Sadly, I'm passing from normal into riggin' it up time. I'll start a new thread about my idea to JB weld the housing on...
amgqmp1 is offline
post #9 of 11 Old 06-03-2010, 04:19 PM
SKI-SKI-SKI
Any chance you know the length of the upper bolt? I broke it and have been drilling on it for DAYS!!!
SKI-SKI-SKI is offline
post #10 of 11 Old 06-03-2010, 08:06 PM Thread Starter
amgqmp1
I don't recall the exact length of the top bolt, but it's much longer than the bottom bolt. My best guess is that it's a 3.5" long bolt (with thread only on the top 1.25").
I ended up having a guy put a helicoil in after my bottom bolt incident. It held all winter, and is still going strong. It should be much easier with the top bolt, although you are already experiencing that it's a lot of bolt to remove.
The moral of the story is that your hard work will pay off.
amgqmp1 is offline
post #11 of 11 Old 07-31-2010, 08:10 PM
y2kxj
5/16-18 thread
Top one is 1 3/4 long, bottom is 3/4 long
y2kxj is offline
Size - Lower Theromostat Housing Bolt - 93 XJ NY1995ZJ XJ Cherokee Technical Forum 4 03-25-2009 09:14 PM
Replacing thermostat and housing, broke a bolt in the block lol Everlastinboost XJ Cherokee Technical Forum 24 06-12-2005 07:02 PM
Thermostat housing Blake XJ Cherokee Technical Forum 2 05-10-2005 10:57 PM
Lower disconnect bolt torx size? Braeden XJ Cherokee Technical Forum 11 08-11-2004 11:29 AM
Thermostat and Housing ? JeepinHood XJ Cherokee Technical Forum 4 08-13-2003 08:23 PM
