What are Signs of a bad MAP Sensor. - JeepForum.com
post #1 of 4 Old 08-04-2005, 11:19 PM Thread Starter
ChaoticBastard
As some of you may have read I am having problems with my 90 XJ.Started out not that bad Sputtering or cutting out at higher RPM's,Then the next day getting much worse.I changed the Following items to see if it would change anything.
Coil,Fuel Filter,Got TPS Checked was OK,Pulled cap seems ok.Wires are newer.Cleaned the throttle body,And Today got a new Cat Converter.Still runs the same but now its stalling too.So my gut and my friends idea is that the Fuel Pump is going out slowly.Was going to have it diagnosed Monday and replaced if nessecary.
Someone mentioned the fuel pressure regulator and the Computer itself..I havent even thought of the MAP sensor until now.My monte carlo had a bad map sensor,It was missing sputtering Running rich and all that.Changed it out and it is fine.Now question is has anyone had there MAP sensor go on there older XJ -87-90?If so do tell what your symptoms were and if they matched my problems at all.Thanks for the help
It might be called a MAF sensor..Im all Confuzzled today
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #2 of 4 Old 08-04-2005, 11:31 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
MAP is manifold absolute pressure sensor, and it's located on the firewall behind the valve cover.
MAF is mass air flow sensor and the XJ doesn't have one.
Could be the MAP, check and make sure the vac line to it is in good shape. Also disco the EGR vac line and plug it and see if that helps the idle and the stalling.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 4 Old 08-05-2006, 10:13 AM
therealsmack
If it does help , what ? leave it plugged.
1987 4.0 XJ , with 1986 Jeep pioneer wheels.
This forum rocks!!!!
therealsmack is offline
post #4 of 4 Old 08-05-2006, 06:02 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
No, get a new EGR valve.
93 Sport
Specs in Profile.
balloo93 is offline
Signs of a TPS going out??? 94HOCHEROKEE XJ Cherokee Technical Forum 4 08-22-2009 08:41 PM
Signs of bad from U-joints? ekim121 XJ Cherokee Technical Forum 11 12-17-2007 09:54 AM
Signs of a bad axle u-joint... Jeepokee XJ Cherokee Technical Forum 9 09-13-2006 08:26 PM
Signs of a bad track bar (stock)? Bryson XJ Cherokee Technical Forum 6 09-07-2006 10:23 PM
What do those +/- signs mean? Einstein XJ Cherokee Technical Forum 1 05-22-2001 09:58 AM
