What should a 4.0 rebuild cost? - JeepForum.com
post #1 of 9 Old 08-22-2011, 10:25 PM Thread Starter
xorg
Developed a small knock and figured with all the money I have invested in this thing to have the motor pulled and rebuilt. Very minor knock but a knock nonetheless. Assuming pistons and everything else checks out what should it cost? Also, If anyones near Chicago that can do this or knows someone let me know.
xorg is offline
post #2 of 9 Old 08-23-2011, 07:59 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
And there is the issue.
You mention full rebuild, then say "assuming pistons and everything else checks out".
I have been saying for quite a while now that one persons version of a rebuild is not the same as another persons version of a rebuild.
I will not rebuild a motor with the same pistons in it.
ALL my motors get the crank ground, bored out with new pistons and rings, all new bearings, deck the block, pressure test and skim the head(s), new oil and water pumps, new camshaft and lifters, line bored for the main bearings, and so on.
That comes to @$800-900 in machine work alone, and you haven't bought any parts yet.
Rebuild "kits" can be had for reasonable money with name brand parts inside in most cases.
You could always buy a "remanufactured" motor and keep your fingers crossed. 99% of those places will only replace something if it is completely shot though.
Doing it yourself/having it done for you, is the way to go for a rig that you plan on keeping a long time. That way you can spec out the build from start to finish.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 9 Old 08-23-2011, 08:58 AM
macktheripper
1988 XJ Cherokee
I bought a crate motor for my XJ from the dealer. I dickered with him and I got him down to $1,100 for a long block. You can't do a GOOD re-build for that price, plus it came with a 3 year 36,000 mile warranty.
Marc
88 AMC XJ
14 KL
macktheripper is offline
post #4 of 9 Old 08-23-2011, 10:47 AM
DoctorTim
a good rebuild should be at least 1300 if you're expecting any quality. i found a shop that would rebuild mine for 1000 but i found a review online that said they started getting engine problems 30K after the rebuild.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #5 of 9 Old 08-23-2011, 02:37 PM
Luke94XJ
1994 XJ Cherokee
You could look for a low mileage junkyard engine, that should run around $500.
Luke94XJ is offline
post #6 of 9 Old 08-23-2011, 03:51 PM
xj4thewin
I just rebuilt my 4.0, after machine work, master rebuild kit, and additional parts, water pump, alternator etc, I just spent about 1800. Its worth it to me, I did the 4.8L stroker rebuild, a brand new spankin engine with more power? whats not to love.
92 XJ
My XJ Build
http://www.jeepforum.com/forum/f11/xj4tw-92-build-up-1182746/
xj4thewin is offline
post #7 of 9 Old 08-23-2011, 05:22 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
$1300 - $2000 depending on a lot of variables. Be sure you get at least 2, better to get 3 quotes before making any decision.
And as mentioned, consider a plug and play salvage yard engine. To each their own on these decisions.
A very minor knock may not necessitate a rebuild. The knock could be a bit of piston slap or valve noise; neither of these uncommon with the 4.0
What I recommend for these is to DRIVE IT, and keep an ear to it. If the noise gets no worse, keep driving it. I have seen many, many 4.0 engines run for tens of thousands of miles with a bit of a knock.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 9 Old 08-23-2011, 05:47 PM
1CVPaul
1994 XJ Cherokee
Just had mine rebuilt locally. Took it to a shop that I knew was meticulous and used quality parts. $ 2000.00 out the door. Runs like a top - well worth it. However I had done about everything else (trany, clutch, rear end etc...) already so it made sense to do the engine.
I'm right 97% of the time. The other 4% doesn't matter.
1CVPaul is offline
post #9 of 9 Old 08-23-2011, 06:40 PM
jeepdog5
jeepdog5's Avatar
If you pull the engine yourself ballpark around $1000-1300. For a turn key $1800-2000
jeepdog5 is offline
Anyone have a stock 4.0 rebuild done recently? Cost? FairlanePhil XJ Cherokee Technical Forum 7 08-25-2010 10:56 PM
Gotta rebuild my engine. Should I wait and stroke it or rebuild it to stock specs. BorderC XJ/MJ Cherokee Non-Technical Forum 12 04-13-2010 08:33 PM
Average Transmission Rebuild/Fluid Change cost? tock172 XJ Cherokee Technical Forum 8 08-07-2009 10:19 AM
engine rebuild cost? crateampscal XJ Cherokee Technical Forum 8 02-29-2008 11:08 PM
How much will it cost to rebuild the following? bigoltrux77 XJ Cherokee Technical Forum 6 09-11-2003 12:43 PM
