what rear axle should I get - JeepForum.com
post #1 of 12 Old 03-28-2013, 06:51 PM Thread Starter
EvolutionXJ
1994 XJ Cherokee
Alright so I have 94 XJ...pretty sure it has the Dana 35 which I have heard is garbage. What rear axle should I switch/upgrade too? C8.25? Or maybe the Dana 44. I don't even know if that would, those are just 2 of the rear axles I know about. And yea I plan on getting whatever axle I decide on from my local junk yard lol
Sent from my DNA
EvolutionXJ is offline
post #2 of 12 Old 03-28-2013, 07:06 PM
cory4um
What are your plans for the jeep? How big of tires do you want to run ? No sense to get extreme here, if you don't have to.
Tons of info on this forum covering rear axle swaps. Do your research! Handy google box in the top corner of every jeepforum page
Easy swaps, practically bolt in- c8.25 from a 97-01 cherokee. Dana44 is stronger yet, but was a rare option in early cherokees, go for big $$$ usually.
The Ford 8.8 can be found easily, some with 4.10 gears and a LSD. This requires some fab work
cory4um is offline
post #3 of 12 Old 03-28-2013, 07:18 PM Thread Starter
EvolutionXJ
1994 XJ Cherokee
Right now its looking like I'm gunna be doing a 3.5" lift, even though I am struggling to find one im happy with on the internet :/ and will probably get 31x10.50 tires. Not set in stone yet and have been tossing around the idea of 4.5" lift and still sticking with 31x10.50's or maybe go to 33's. Im going to take it off roading but nothing tooo hardcore (I say that now...wait till I get on a trail and change my mind lol) and it will be alternating with my awesome gas mileage vehicle as a dd more than likely.
Edit
But I've heard the Dana 35 is the WORST rear axle to come on XJ's. Well that just makes me want a different one. Maybe im weird lol
Sent from my DNA
post #4 of 12 Old 03-28-2013, 07:37 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Get a Chry 8.25 and drive shaft from a 1997-2001 XJ Cherokee. It will be inexpensive, easy to find, and bolt on. An XJ Dana 44 will be 2x to 4x the price of an 8.25, if the seller knows what they have. Plus, the XJ Dana 44 is very rare.
CJ7-Tim is offline
post #5 of 12 Old 03-28-2013, 08:08 PM
egodfrey
egodfrey's Avatar
8.25 from. 97+ will have 29 spline shafts versus the 27 spline in earlier models.
And you will want the driveshaft with the 8.25 because the pinion is longer on that axle so the driveshaft is shorter slightly.
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #6 of 12 Old 03-28-2013, 09:27 PM
cory4um
cory4um is offline
post #7 of 12 Old 03-28-2013, 09:31 PM
rugsucka
You can find a 97+ 8.25 for 100 bucks often. It will be the best option well beyond 31's and approaches the strength of a D44. Bolt in, move on.
rugsucka is offline
post #8 of 12 Old 03-31-2013, 08:04 AM
flexyxj
2009 XK Commander
With 31's, I wouldn't bother doing anything with your D35 until it's broke. Why fix what ain't broke?
flexyxj is offline
post #9 of 12 Old 03-31-2013, 08:15 AM Thread Starter
EvolutionXJ
1994 XJ Cherokee
Well my springs are fine so should I not get a lift...I just wanna upgrade since I found one at the junkyard already. Besides later on I plan on getting a larger lift and bigger tires so might as well upgrade early.
Sent from my DNA
post #10 of 12 Old 03-31-2013, 08:45 AM
CJ7-Tim
CJ7-Tim's Avatar
I have seen 2 stock Jeeps bust a D35 on P235/75/15 car tires. $100 is cheap insurance.
D35 on 31's ..........
CJ7-Tim is offline
post #11 of 12 Old 03-31-2013, 11:02 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
And I have wheeled sucessfully with 35" tires on a locked d35, stupidity can break anything. Not saying those incidents were caused by it, but hopping the rear tires on rocks will break any axle if you do it enough. For 31" tires unless you are going to do some extreme wheeling I would just leave the d35 under there. I have ran a couple of jeeps with 33's, 35's with one and had zero issues. If you need the peace of mind the 8.25 like CJ7tim stated, is a direct swap and cheap to find.
xjfever is offline
post #12 of 12 Old 09-24-2013, 12:25 PM
twmart
We just put a 1996 8.25 axle under a 1989 XJ and we are having an issue with the E-Brake cables.
Has anybody else noticed that the E-Brake cables are too short?
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
