Quantcast what is the point? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > what is the point?
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 09-15-2006, 02:44 PM   #1
xj 98/yj 94
what is the point?
of going bigger than 31's? i mean is it just for looks? or to get more differential-ground clearance or what.. just seems like they are a pain, more money and rub on body... just curious since i am new to this... i am currently running 31's and need tires by winter and was debating if i should get 31's again or go to 33's... is it worth the extra money?
'95 ZJ.... new DD
'98 XJ.... sold
'98 XJ.... Sold...(biggest regret)
'91 YJ.... Was mine,now dad's DD
'94 YJ.... Sold...
'95 ZJ.... Sold, '04 TJ.... Mom's DD.....'97 TJ.... Sold
xj 98/yj 94 is offline   Reply With Quote
Old 09-15-2006, 02:50 PM   #2
andrew2516
So you can finish the trail when your buddy on 31"s cant
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
www.PGHOFFROAD.com
andrew2516 is offline   Reply With Quote
Old 09-15-2006, 03:02 PM   #3
UltimatE
Resident Audio Guru
UltimatE's Avatar
Going higher is all about the ground clearance. Most of the time you can go farther on a trail simply because your undercarraige has enough ground clearance to clear over obstacals. 2 identical rigs, one with 31x12.5 tires of brand X and the other has 35x12.5 with the same brand is going to have the same traction. However the bigger tire will be able to deflate more and therefore CREATE more traction.
I guess it all comes down to your budget.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Old 09-15-2006, 03:18 PM   #4
FlybydayXJ
I believe the reasoning goes as follows: Tires make their ground clearance by getting your axles higher off the ground so when you come to muddy spots or rocks you dont have to drag/scrape your diff thru the obsticale. They also contribute to the total height (like by the TC etc)
The suspension lift is more for better aprch/dep angles and keeping you from getting high centered and making room for bigger tires . I would also asume a bigger tire diameter has a bigger foot print when aired down too giving better traction.
Anybody care to validate, add to, or set my assumption stright?
'96 XJ 4.0 L6
5 Spd
235/75 R15 Yokohama Geolanders
Shiny alloy wheels
FlybydayXJ is offline   Reply With Quote
Old 09-15-2006, 03:24 PM   #5
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
bigger tires provide a sometimes deeper tread, bigger footprint for increased traction, and greater ground clearance/improved stability with higher lifts
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 09-15-2006, 03:30 PM   #6
RP_Offroad
It would probably be easier to go over larger rocks than it would be with a smaller tire too. I don't know how to explain it but with a smaller tire you are are sort of driving into the rock than over it, although this is for larger rocks.
RP_Offroad is offline   Reply With Quote
Old 09-15-2006, 03:32 PM   #7
Cause
...in your dreams
Cause's Avatar
1988 MJ Comanche
Bigger is ALWAYS better, if you don't believe it ask her...
..More ground clearence, better traction wider footprint, softer ride aired down....
Scout734--->I agree, Cause is sweet...I voted for Cause...I love Cause, he's so hot I could have pancakes with him every morning!!
AmbuGrl--> Helllz...Its about the Hott Ladies Of JF that are all here for Cause.
Sarahdactyl--> Cause is the sweetest man .... Hands down. Cause, you take my breath away.
MissMurder--> 'Cause has no reason to ever be grumpy, he's the keeper of my heart....He's the only old guy I actually like. Ahhh, 'Cause. One of the few old men that can make my girl bits tingle.
Froggin--> I love you, Cause. Truly, madly, deeply. It might be fickle, but....I love you.
I don't share....much. Cause, I love you more and more each and every day. You make my heart go pitter patter with the words that come out of your mouth. I am voting for Cause....why? b/c he is my snugglebunny and I love him.
XJIceQueen--> If I get desperate to have babies once I get my heart back up to speed I'll call 'Cause first...
1. Stupidity should be more painful!
2. Don't believe everything you think!
3. Your post is as worthless as you!
Cause is offline   Reply With Quote
Old 09-15-2006, 03:34 PM   #8
Jeepsterboy101
I'm all about running 35's just for looks.
www.scottsxj.com (under construction)
Jeepsterboy101 is offline   Reply With Quote
Old 09-15-2006, 03:35 PM   #9
90lerado
the thing some people forget is the whole reason for lifting a vehicle is just to fit bigger tires on it. tires get everything higher off the ground. the whole point of lifting is to fit bigger tires. ideally you want the biggest tires on the least amount of lift with the most usable flex. that way you keep the lowest COG that you can but still maintain clearence.
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts"
- General George Patton Jr, "War as I knew it" 1947
new vehicles:1996 Ford F150 5.0l 4X4 with a plow.
90lerado is offline   Reply With Quote
Old 09-15-2006, 03:38 PM   #10
loudog3114
approach/departure angle, axle clearance, and footprint (bigger = more traction and less likely to get stuck in ruts.)
92 YJ, 35's, 6"
97 Honda CBR1100xx
loudog3114 is offline   Reply With Quote
Old 09-15-2006, 03:42 PM   #11
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thats the truth.
-Matt
White '94 YJ Sport
Old 09-15-2006, 03:54 PM   #12
StokedXJ11
1997 XJ Cherokee
so from a technical point of view, whoever it was that posted pics a while back on a XJ with stock suspension and 33s. It is a very good setup b/c of his better ground clearance and lower center of gravity?
Stock 1997 Jeep XJ Country
RJC #377
StokedXJ11 is offline   Reply With Quote
Old 09-15-2006, 04:51 PM   #13
gregmondro
and I thought I was the only one :P
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Old 09-15-2006, 05:05 PM   #14
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I didn't see flotation listed in any of the other posts. How many dedicated mud rigs do you see running 31s? The more air that your tires carry, the more you will float through the mucky stuff.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 09-15-2006, 07:00 PM   #15
andrew2516
My buddy in the pic has about the same amount of lift as I do. The difference is that I'm running a 34" tire and hes running a 31" tire. My jeep went through that hole pretty easy and he had no chance. The only thing bigger tires do is raise axle clearance and overall height.
8" Lift
www.PGHOFFROAD.com
Glock Forum
