What oil to use in 4.0 97 Cherokee - JeepForum.com
post #1 of 5 Old 03-04-2009, 05:45 AM Thread Starter
Woody_FX
1997 LJ Wrangler
Hi guys,
Bought the Cherokee 2nd(3rd, 4th) hand and there are no manuals with it. Its a 97 4.0L Limited Edition version.
So what type of oil should i put into it? Is there anything else i should do for maintance? Put 4000km on it since i got it and dont know what the last owner did maintance-wise.
I can get a smell of petrol of it occaisonally. Usally on really hot days i think. In Queensland, Australia.
Many Thanks for the tips guys.
-W
Woody_FX is offline
post #2 of 5 Old 03-04-2009, 06:00 AM
jontz
1995 XJ Cherokee
10w30 is the manufacturer recommended weight. It will take 6 US quarts with a filter. I would also look at replacing spark plugs, wires, cap, and rotor just as general maintenance.
I'm not sure about the smell. You might start looking around for a leaky fuel line, or perhaps even a bad gas cap. Again, I'm not too sure about that one...
jontz is offline
post #3 of 5 Old 03-04-2009, 06:00 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Most of the time 10w-30 is what is recommended. 6qtrs of it. Check the transfer case level and the trans fluid level.
Flush the cooling system and refill it with fresh coolant.
Check the serpentine belt condition and look at the motor mounts and trans mount.
Drive it and look for wet spots on the tank or smell around to try to find the source of the smell. Check the injector seats and look for wetness there.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 5 Old 03-04-2009, 06:15 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
If you have no history of maintenance, change out ALL fluids. Oil, transmission fluid, transfer case, both differentials, coolant (replace with factory 195 OEM thermostat while you're doing this). Fluids are the best investment on future reliability of your XJ.
For tuneup hardware, you'd be looking at replacing spark plugs, plug wires, distributor cap, rotor, air filter, check belt condition.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 5 Old 03-04-2009, 06:21 AM Thread Starter
Woody_FX
1997 LJ Wrangler
Thanks guys! I try check that all out.
Woody_FX is offline
'96 Grand Cherokee Seats and Center Console in a '96 Cherokee? 96cherokeesport XJ Cherokee Technical Forum 16 09-25-2010 05:35 AM
Hey Cherokee owners...Will stock 2005 Wrangler Wheels fit a 95 Cherokee? RedArrow10 XJ Cherokee Technical Forum 3 07-23-2009 11:41 AM
5spd cherokee engine fit automatic(duh) grand cherokee? jumpn4jesus XJ Cherokee Technical Forum 5 07-02-2007 10:34 AM
grand Cherokee wheels fit a 1993 Cherokee Limited? Spanishfly XJ Cherokee Technical Forum 9 06-09-2007 07:21 AM
Nerf Bars Cherokee/Gran Cherokee are they interchangeable? Borinquenknight XJ Cherokee Technical Forum 1 02-15-2003 01:04 AM
