What lift type is it? - Page 2 - JeepForum.com
post #16 of 25 Old 10-24-2011, 11:05 AM
Ben
Pitman arms can be a real PITA to pull. If you're trying to junkyard one, look for a jeep with a leaking steering box. I've broken pullers, and beat the hell out of pickle forks. Most are too stubborn to remove without a torch.
Originally Posted by RacerX View Post
so I just knocked the tie rod out with a hammer, and left the rest.
Sounds like the drag link.
Why are you wanting a different height pitman arm? Have you changed the body side mount of the track bar?
Ben is offline
post #17 of 25 Old 10-24-2011, 07:36 PM Thread Starter
RacerX
1989 XJ Cherokee
I finally found it - It's a Fat Bob's
http://fatbobsgarage.com/i-6765193-j...1984-2001.html
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline
post #18 of 25 Old 10-24-2011, 10:07 PM Thread Starter
RacerX
1989 XJ Cherokee
yeah, the drag link tie rod end (I'd already removed the actual drag link)
the body side mount was changed before I bought it (see above pics) I plan to remove it. I want the lower pitman to flatten the steering geometry closer to stock, with the 2" lift.
RacerX is offline
post #19 of 25 Old 10-25-2011, 09:30 AM
Ben
I only saw the axle end mount's aftermarket bracket with the green X on it.
I'm kinda thinking you don't have to do that though, your track bar's body side mount looks stock to me, and to keep the drag link parallel with the track bar at the top, you would probably want to keep the stock pitman arm. I would think you should just get an adjustable track bar to center the axle, and keep the OEM mounts on both sides of the track bar and drag link. At 2" of lift, the inverted Y of the stock steering is still well within it's rage of being effective.
Ben is offline
post #20 of 25 Old 10-25-2011, 12:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You do not need a Drop Pitman Arm until you have more than 6-8" of lift. The stock pitman arm is fine for any lift 0-6" tall.
CJ7-Tim is offline
post #21 of 25 Old 10-25-2011, 03:13 PM
Kevin108
If I ever get rid of my XJ, I hope someone comes here and asks the same question.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #22 of 25 Old 10-25-2011, 07:06 PM Thread Starter
RacerX
1989 XJ Cherokee
Ha, think that's bad? look at my leaf springs:
RacerX is offline
post #23 of 25 Old 10-25-2011, 07:44 PM
Kevin108
LMAO way to clamps, no clamps!
Kevin108 is offline
post #24 of 25 Old 11-03-2011, 10:32 AM Thread Starter
RacerX
1989 XJ Cherokee
I know I need clamps.
whats a cheep way to go? Easy way?
RacerX is offline
post #25 of 25 Old 11-11-2011, 01:53 AM Thread Starter
RacerX
1989 XJ Cherokee
yes Track bar is stock (except the bracket with green X).
I want to add another inch... or so..? sounds like It will be best without pitman or the X bracket.
Why do we need a Track bar, anyway ??? Never had a vehicle with one before. It has control arms, shocks, springs & stabilizer bar mounted to axel...
RacerX is offline
lift , repair , sagging , springs
trying to decide on lift higth and type BftXJ XJ Cherokee Technical Forum 7 02-08-2010 08:23 AM
i don't know what type or kind of lift kit to get? jpchk2000 XJ Cherokee Technical Forum 0 04-14-2009 09:33 PM
what type of lift.... LiBMXr1390 XJ Cherokee Technical Forum 9 09-15-2008 08:17 PM
Type of lift for mud only? TXjeep97 XJ Cherokee Technical Forum 9 12-17-2004 03:07 PM
Question about an alternative lift type... bdw8 XJ Cherokee Technical Forum 7 07-19-2003 09:00 PM
