What lift type is it? - JeepForum.com
post #1 of 25 Old 08-08-2011, 04:20 AM Thread Starter
RacerX
1989 XJ Cherokee
I was told when I bought my 1989 Cherokee Limited that it had a 2" lift.
However, It seems more like 1 1/2 or 1 1/4" after I subtract a couple inches for the 31" tires (assuming stock height of 63.3"). I expect this may be due to wear, and trying to haul too much weight (bricks )
My questions are:
How do i figure out what kind of lift I have?
How do I fix it back up to the 2" lift
e.g. If I had WJ front springs I could go to JY and get another pair, OR If bastard pack, I could just add a leaf each side rear.
Also rear leaves are spreading a little, so I need to bind them together...
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline
post #2 of 25 Old 08-08-2011, 06:50 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The only way to measure for true lift height is to measure from the center of the wheel to the bottom of the flares. This eliminates any tire size differences. If your fenders are trimmed you can measure from the frame to the axle tubes and there is a picture somewhere on here to show where to measure. If your fenders aren't trimmed the stock height is 17" in the rear and 17.5" up front. WJ coils don't fit on XJ's. ZJ coils will give very little lift 1/2" to 1" and will ride like crap. The easiest way to lift the front a small amount is to add coil spacers or extra rubber isolators to the top of the coils. The factory isolators are cheap and each one will give about 5/8" of lift. Spacers are good to around 2" of lift and after that you need longer coils. You can add-a-leaf in the rear from another set of leafs or use a longer shackle for a little more lift depending on what was done to it before.
xjfever is offline
post #3 of 25 Old 08-10-2011, 12:25 AM Thread Starter
RacerX
1989 XJ Cherokee
Originally Posted by xjfever View Post
If your fenders aren't trimmed the stock height is 17" in the rear and 17.5" up front. ... The factory isolators are cheap and each one will give about 5/8" of lift. Spacers are good to around 2" of lift and after that you need longer coils. You can add-a-leaf in the rear from another set of leafs.
Thanks!
Yeah found a more level spot, measured 20" front, 19" rear, on the driver side, it seems to list to the driver side a bit.
So I think I need 1 isolator front ans a leaf or something in the rear..
At least I know where to start now.
RacerX is offline
post #4 of 25 Old 10-14-2011, 07:08 PM Thread Starter
RacerX
1989 XJ Cherokee
This is the Rt (passenger) side knuckle and tracbar mount.
The part with the Green X - Does this come from any particular lift kit ??
It seems to be a little loose, Dude at Les Schwab says to just weld it, but ... the trackbar already pushes the tires too far to the right (pass), so I'm thinking about removing it.
Advise?
Bolt size for the stock tracbar mount hole (or does it need some kind of sleeve)?
RacerX is offline
post #5 of 25 Old 10-14-2011, 07:39 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The green x is a track bar drop bracket and it should be removed and thrown away. They cause excessive stress on the axle bracket and can cause breakage. If needed, a longer adjustable track bar is a better solution.
Your sway bar links are too short. See how they are rubbing on the coil springs. The ends of the sway bar should be pointed up at about a 10-15* angle. Look at a stock XJ and compare the sway bar location/orientation/angle.
CJ7-Tim is offline
post #6 of 25 Old 10-14-2011, 09:39 PM Thread Starter
RacerX
1989 XJ Cherokee
Ok good to know- thanks, ..and yeah I been planning to lengthen the stabilizer links, I know they're prob 2+" too short.
I didn't even know that track bar drop bracket was there until the alignment guy said it was loose, then i went to junkyard and compared them with mine...
grrr!
RacerX is offline
post #7 of 25 Old 10-15-2011, 02:50 AM Thread Starter
RacerX
1989 XJ Cherokee
Do you know what size bolt or if I need a sleeve on the bolt for the track bar to axle mount?
I've heard conflicting reports about it (13mm or 9/16??) Green -and that it may not fit snug in the hole..
- Maybe I can weld a fender washer on it?
RacerX is offline
post #8 of 25 Old 10-15-2011, 09:25 AM
CJ7-Tim
CJ7-Tim's Avatar
The bolt is a Hex Head, M10x1.5x70. This bolt uses a flag nut, a nut with a tab welded to to that fits into the bracket. You should use a Grade 8 washer. The track bar bushing has a sleeve in it.
If the axle end bolt hole is worn and oval shaped you should make and weld on a repair plate with a snug fitting bolt hole.
CJ7-Tim is offline
post #9 of 25 Old 10-15-2011, 11:03 AM Thread Starter
RacerX
1989 XJ Cherokee
Great, thanks for the info and pic, Tim!
RacerX is offline
post #10 of 25 Old 10-16-2011, 02:07 AM Thread Starter
RacerX
1989 XJ Cherokee
How do I get the Pittman arm off??
RacerX is offline
post #11 of 25 Old 10-16-2011, 03:13 AM
CJ7-Tim
CJ7-Tim's Avatar
What are you trying to remove ?
CJ7-Tim is offline
post #12 of 25 Old 10-16-2011, 10:01 AM
BRad704
Nothing to see here...
BRad704's Avatar
Great image Tim. That needs to go in an XJ-newbie stickie.
BRad704 is offline
post #13 of 25 Old 10-16-2011, 11:14 PM Thread Starter
RacerX
1989 XJ Cherokee
- The Pitman Arm. (and the tie rod attached to it) I couldn't get it off yesterday at junkyard.
RacerX is offline
post #14 of 25 Old 10-17-2011, 02:40 PM
graytm4
1997 XJ Cherokee
you need a puller for the pitman arm
graytm4 is offline
post #15 of 25 Old 10-24-2011, 10:30 AM Thread Starter
RacerX
1989 XJ Cherokee
ZJ steering rods
Ok I went to harbor-freight and bought a wheel puller, took it back to the junkyard.... I could not get the Pitman arm off!
I ended up taking the whole steering gearbox off and trying the puller that way (on the ground), all it did was scrape grooves in it.
so I just knocked the tie rod out with a hammer, and left the rest.
I still want the ZJ pitman arm. Maybe another junkyard will pull it for me?
RacerX is offline
lift , repair , sagging , springs
trying to decide on lift higth and type BftXJ XJ Cherokee Technical Forum 7 02-08-2010 08:23 AM
i don't know what type or kind of lift kit to get? jpchk2000 XJ Cherokee Technical Forum 0 04-14-2009 09:33 PM
what type of lift.... LiBMXr1390 XJ Cherokee Technical Forum 9 09-15-2008 08:17 PM
Type of lift for mud only? TXjeep97 XJ Cherokee Technical Forum 9 12-17-2004 03:07 PM
Question about an alternative lift type... bdw8 XJ Cherokee Technical Forum 7 07-19-2003 09:00 PM
