what kind of spark plugs for my XJ - JeepForum.com
post #1 of 15 Old 03-20-2011, 10:57 AM Thread Starter
whiteys_red_XJ
hi im planning to do a tune up on my 96 xj i will be running accel wires,cap,rotor,and coil. I had E3 before but the prongs all burnt of when i changed them i then put in champions in. and i was just wondering if the champs are the best for an xj with 179k on it any help is apricated thanks
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 15 Old 03-20-2011, 11:14 AM
mtwask01
1995 XJ Cherokee
Yes, definitely use the champion spark plugs type RC12LYC. These are the OEM spec spark plugs for your engine. I just changed mine from Autolite AP985s and noticed a much smoother idle. My idle no longer fluctuates up and down at stoplights. Make sure the gap is .035".
mtwask01 is offline
post #3 of 15 Old 03-20-2011, 11:23 AM
VTEK1
I use Bosch platinum plus they last for a while and never had any issue with them. I have run them on my 99 since day one 91000-150000 miles. And napa wires
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #4 of 15 Old 03-20-2011, 11:36 AM
mtwask01
1995 XJ Cherokee
Is your Jeep one with the distributorless ignition, because I'm pretty sure those use different spark plugs.
mtwask01 is offline
post #5 of 15 Old 03-20-2011, 12:19 PM
Dbiked
Haha Just for ****s, i checked the gap of my old spark plugs, after doing a tune up on my jeep, The gap was .65 , almost double what they should have been haha
Utah jeep crew member #32
Dbiked is offline
post #6 of 15 Old 03-20-2011, 01:02 PM
VTEK1
No its got a distrubitor i just use those instead of champions. Nothing bad about champions however
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #7 of 15 Old 03-20-2011, 01:55 PM
JeepRide
JeepRide's Avatar
I just put a set of autolite #985 spark plugs in my 98xj for cap and rotor I used the napa belden parts they have the brass contacts.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #8 of 15 Old 03-20-2011, 02:04 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Stock is .035, so .65 would be way more than twice the factory gap.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #9 of 15 Old 03-20-2011, 04:03 PM
VTEK1
Lol i think the decimal place is a little off. Wish they would do that wirh my paycheck
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #10 of 15 Old 03-20-2011, 04:17 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
From experiences of many on multiple forums....
84-99: Plain old champion copper plugs
00-01: NGK. The ignition on the 00-01 is different (coil pack) and NGK are a very good choice for these. Jeep started using NGK for their OEM plug on the 4.0 somewhere in this time frame, possibly 2002.
I love Bosch products, but because some (not all) have had mysterious misfires with them which have gone away when switching plug mfgs, I can't recommend them.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #11 of 15 Old 03-20-2011, 04:43 PM
VTEK1
Interesting to note. I'll keep an eye out for this, never heard anything bad until now. Thanks.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #12 of 15 Old 03-20-2011, 04:48 PM
tjwalker
tjwalker's Avatar
This Bosch plug miss is something that is very interesting indeed. I have just recently started collecting information on it and investigating it a bit. I absolutely love Bosch. I have their dishwasher, their power tools, their engine management sensors, the list goes on and on. Bosch has very good engineering.
The mechanism behind the 4.0 misfires is very unclear and what clouds this more, is that it absolutely does not happen to everyone, only to certain engines; the majority of Jeep 4.0 engines will probably work fine with them. Because of the complexity of trying to figure this out without a controlled large scale experiment, (my pole shed and checkbook aren't up to this!) the cause is unlikely to ever be understood by us end users.
But, because of the volume of threads about this, and the fix clearly being to switch plug mfgs, it is apparent that there is a connection here; this is not just one person thinking that their misfire was caused by their Bosch plugs. It's quite a few reported events.
The above is why I can't recommend them, but can make the recommendation of Champion for 84-99 4.0 engines and NGK for 00-01 4.0 engines. Never an issue with these plugs and these applications.
tjwalker is offline
post #13 of 15 Old 03-24-2011, 06:06 PM
tjjeepwrench978
1997 XJ Cherokee
champion gold truck plug
tjjeepwrench978 is offline
post #14 of 15 Old 03-24-2011, 06:36 PM
JrTjK
1978 FSJ Wagoneer
Another vote for Champions...they're used factory, so that's good enough for me!
JrTjK is offline
post #15 of 15 Old 03-24-2011, 08:24 PM
ChrkeeplainsMen
I installed those new E-3 plugs and they work great..
2000 XJ 4.5+ Lift 32 BFG AT
2002 F250 7.3Power Stroke 2 Inch Lift 33's DC Bead Lock Black
2007 Yukon Denali Black
ChrkeeplainsMen is offline
replaced spark plugs - 4.0 wont hold idle - 00-01 spark coil rail ahuf XJ Cherokee Technical Forum 19 01-02-2011 10:15 AM
best spark plugs scottxj96 XJ Cherokee Technical Forum 2 10-06-2008 10:35 PM
what kind of spark plugs are you using w/ your stroker? BigOrangeXJ XJ Cherokee Technical Forum 15 06-15-2007 03:35 AM
Spark Plugs louisd11 XJ Cherokee Technical Forum 15 05-31-2007 12:26 PM
spark plugs netrnr XJ Cherokee Technical Forum 6 05-27-2005 05:17 PM
