What hose is this and how hard will it be to fix? - JeepForum.com
post #1 of 6 Old 07-20-2013, 09:35 AM Thread Starter
JeepinJesse
Hey guys yesterday I pulled into my drive way and saw white smoke coming from the hood. I popped the hood and saw the top hose running along the left side of the motor had blown. What hose is this and what do I do to fix it. Please leave comments , thank youu.
JeepinJesse is offline
post #2 of 6 Old 07-20-2013, 10:23 AM
Paradise XJ
1988 MJ Comanche
It's a heater hose. It goes from your t-stat to your heater core. It's easy as buying the hose, removing the clamps, replacing the hose, topping off your coolant.
The hardest part is BUYING the hose. You can buy bulk hose, but easier to use the pre molded hose, it's plug n' play. I'd replace both of them and give the other cooling hoses a good inspection too. Usually when stuff like this breaks, it's a wake-up call to do some maintenance. If this is a picture of YOUR engine, maybe a good cleaning too. Makes it easier to find stuff and/or other potential maintenance problems Just my two cents'.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 6 Old 07-20-2013, 10:26 AM Thread Starter
JeepinJesse
Ok thank youu , I appreciate it
post #4 of 6 Old 07-20-2013, 10:34 AM
CCKen
CCKen's Avatar
And...get the proper CCV fitting for your valve cover. LOL
Available at O'reilly and other parts stores. Dorman part I think.
CCKen is offline
post #5 of 6 Old 07-20-2013, 11:23 AM
AZ Jeff
2014 JK Wrangler
I would go one step further. Given that the hose blew, it did so because it was soft and old. I would be willing to bet that the others are in the same condition. And I would also be willing to bet if they are in that same condition, the coolant has not been flushed/changed in some time.
Assuming all of that is true, and coolant flush/change and replacement of ALL the hoses is a prudent thing to do. The cooling system of the 4.0 XJ is it's Achille's Heel, and keeping it in top shape prevents catastrophic failures and possible engine death.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 6 Old 07-20-2013, 11:56 PM
Hudson
That's your heater core hose.
Should be able to buy the exact length you need at a local parts store for under $10. I got mine for four something.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
