What is a good 4.5 in Lift Kit for a 96 cherokee - JeepForum.com
post #1 of 18 Old 02-12-2010, 10:15 PM Thread Starter
whiteys_red_XJ
Hi Im looking to get a 4.5 in lift kit but im not to sure on what brand and prices.I was looking an Rough Country full leaf lift.and do I have to make any drive line changes please any one who knows about lifts on cherokees let me know thanks
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 18 Old 02-12-2010, 10:20 PM
BeepBeepGoJeep
1994 XJ Cherokee
if your not wanting to spend alot of money then i would get the RC 4.5 full packs, thats what im getting.
[]IIIII[]
BeepBeepGoJeep is offline
post #3 of 18 Old 02-12-2010, 10:22 PM
Hussler
1992 XJ Cherokee
A rough country long arm would be niccceee.
I have a 4.5 Rubicon express on my 95, works well, nothing to brag about. No driveline vibes, and no mods to the driveline.
Have a 4.5 Procomp lift on my 92. arms are well built, it felxs ok but not as nice as the RE lift. again, no driveline vibes.
In this day and age I suggest the rough country kit (long or short arm) best bang per buck
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #4 of 18 Old 02-12-2010, 10:46 PM
robeljo
1995 XJ Cherokee
I have the rusty's 4.5. I'm around $600 or $700 but I'm very satisfied. Handles well.
robeljo is offline
post #5 of 18 Old 02-13-2010, 05:36 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The rough country long-arm kit is the best bang for your buck as mentioned above. Going to 4.5" with short-arms will make your ride a lot stiffer because of the control arm angles. The long-arms will ride better and flex a lot better too. With the 96 model you will likely have some vibrations at that height. Some get by with a t-case drop where others have to have the SYE/cv driveshaft. Some of this depends on which drivetrain you have The AW4 transmission (4 speed auto), the 242 t-case, and the 8.25 rear end are the longest components which means a shorter driveshaft and worse driveline angles. The 5 speed, 231 t-case, and d35 rear end are the shorter components. Depending on which combination you have you may need the SYE. The 96-up models also have a different type of output on the t-case which is more prone to vibrations after lifting.
xjfever is offline
post #6 of 18 Old 02-13-2010, 06:02 AM
Super6XJ
Im getting the RC 4.5" Full leafs.. and I did some research and its not bad price.
best if you have a dealer locally. and buy from them
but You may have to get the SYE,
im hoping i dont.. :/
Your Welcome
Super6XJ is offline
post #7 of 18 Old 02-13-2010, 09:53 AM
Apostle
I have the rc 4.5 full leaf on my 89. its a good product. only thing i would change would be adding the LCA drop brackets, give it a bit smoother ride.
use existing trac bar, but you drill a new hole 3/4" to the driver side (axle mount).
"To learn who rules over you, simply find out who you are not allowed to criticize.
Voltaire
Apostle is offline
post #8 of 18 Old 02-13-2010, 10:40 AM Thread Starter
whiteys_red_XJ
LCA drop barckets
What are lca drop brackets?
post #9 of 18 Old 02-13-2010, 10:46 AM
Hussler
1992 XJ Cherokee
essentially its the "old school" way of fixing control arm angles, but now adays its almost cheaper to buy a long arm kit than to buy adjustable short arms AND lca drop brackets. Believe me, I did the math Im going to get the Rough country long arm to smooth out my ride.
lca drop brackets: Moves the mounting location of the control arms farther down therefore brings angles of control arms closer to stock after a lift.
Hussler is offline
post #10 of 18 Old 02-13-2010, 10:56 AM Thread Starter
whiteys_red_XJ
LCA drop barckets
post #11 of 18 Old 02-13-2010, 11:00 AM Thread Starter
whiteys_red_XJ
Thanks huslla737 I think I'm going to get the long arm lift I'll just have to keep saving lol
post #12 of 18 Old 02-15-2012, 04:46 PM
slamin04
2011 JK Wrangler
i just did my 4.5 ZONE, for me it is best for the money. It is an aal system, i got the system for 450 bucks,
PAY IT FOWARD Garage Buildin!!!
http://www.flickr.com/photos/cosmos111/
slamin04 is offline
post #13 of 18 Old 02-15-2012, 07:02 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
The best kit is one you build yourself. I had bad luck with RC leafs and RE as well. If I were to do it again I would piece it together with different brand parts I wanted
1990JEEPXJ is offline
post #14 of 18 Old 02-15-2012, 09:52 PM
ScottD16
i got the 4.5 rc full pack lift about three years ago and its pretty nice a little rough though but not a hard fix. the kits they have today have come a long way it makes me jealous, they are very complete with great quality. also i have a 96 and it had no vibrations.
ScottD16 is offline
post #15 of 18 Old 03-25-2012, 08:14 PM
Cooray45
1995 XJ Cherokee
I'm tryin to figure out wich kit for my 95 xj thinkin of x series 4.5 has everything and leaf packs
Cooray45 is offline
4.5 inch lift , 96 cherokee , cherokee , full leafs , rough country
Ahh, it's good to be back in a Cherokee! sanrico XJ/MJ Cherokee Non-Technical Forum 6 03-23-2009 04:10 PM
Is this cherokee a good deal??? flynn25 XJ/MJ Cherokee Non-Technical Forum 4 01-09-2009 09:17 PM
Was this cherokee a good deal? jeffasher1988 XJ Cherokee Technical Forum 14 06-27-2006 10:40 AM
Did I get a good deal on this Cherokee? guest XJ Cherokee Technical Forum 3 05-09-2004 06:07 PM
99 Cherokee...a good tow vehicle? Slammed_Am XJ Cherokee Technical Forum 16 03-31-2004 02:57 PM
