-   -   What is a good 4.5 in Lift Kit for a 96 cherokee (http://www.jeepforum.com/forum/f11/what-good-4-5-lift-kit-96-cherokee-970998/)
whiteys_red_XJ 02-12-2010 09:15 PM
Hi Im looking to get a 4.5 in lift kit but im not to sure on what brand and prices.I was looking an Rough Country full leaf lift.and do I have to make any drive line changes please any one who knows about lifts on cherokees let me know thanks :wave:
BeepBeepGoJeep 02-12-2010 09:20 PM
if your not wanting to spend alot of money then i would get the RC 4.5 full packs, thats what im getting.
Hussler 02-12-2010 09:22 PM
A rough country long arm would be niccceee.
I have a 4.5 Rubicon express on my 95, works well, nothing to brag about. No driveline vibes, and no mods to the driveline.
Have a 4.5 Procomp lift on my 92. arms are well built, it felxs ok but not as nice as the RE lift. again, no driveline vibes.
In this day and age I suggest the rough country kit (long or short arm) best bang per buck
robeljo 02-12-2010 09:46 PM
I have the rusty's 4.5. I'm around $600 or $700 but I'm very satisfied. Handles well.
xjfever 02-13-2010 04:36 AM
The rough country long-arm kit is the best bang for your buck as mentioned above. Going to 4.5" with short-arms will make your ride a lot stiffer because of the control arm angles. The long-arms will ride better and flex a lot better too. With the 96 model you will likely have some vibrations at that height. Some get by with a t-case drop where others have to have the SYE/cv driveshaft. Some of this depends on which drivetrain you have The AW4 transmission (4 speed auto), the 242 t-case, and the 8.25 rear end are the longest components which means a shorter driveshaft and worse driveline angles. The 5 speed, 231 t-case, and d35 rear end are the shorter components. Depending on which combination you have you may need the SYE. The 96-up models also have a different type of output on the t-case which is more prone to vibrations after lifting.
Super6XJ 02-13-2010 05:02 AM
Im getting the RC 4.5" Full leafs.. and I did some research and its not bad price.
best if you have a dealer locally. and buy from them
but You may have to get the SYE,
im hoping i dont.. :/
Apostle 02-13-2010 08:53 AM
I have the rc 4.5 full leaf on my 89. its a good product. only thing i would change would be adding the LCA drop brackets, give it a bit smoother ride.
use existing trac bar, but you drill a new hole 3/4" to the driver side (axle mount).
whiteys_red_XJ 02-13-2010 09:40 AM
LCA drop barckets
What are lca drop brackets?
Hussler 02-13-2010 09:46 AM
essentially its the "old school" way of fixing control arm angles, but now adays its almost cheaper to buy a long arm kit than to buy adjustable short arms AND lca drop brackets. Believe me, I did the math :laugh: Im going to get the Rough country long arm to smooth out my ride.
lca drop brackets: Moves the mounting location of the control arms farther down therefore brings angles of control arms closer to stock after a lift.
whiteys_red_XJ 02-13-2010 09:56 AM
LCA drop barckets
whiteys_red_XJ 02-13-2010 10:00 AM
Thanks huslla737 I think I'm going to get the long arm lift I'll just have to keep saving lol :D:thumbsup:
slamin04 02-15-2012 03:46 PM
i just did my 4.5 ZONE, for me it is best for the money. It is an aal system, i got the system for 450 bucks,
http://i168.photobucket.com/albums/u...9342218934.jpg
1990JEEPXJ 02-15-2012 06:02 PM
The best kit is one you build yourself. I had bad luck with RC leafs and RE as well. If I were to do it again I would piece it together with different brand parts I wanted
ScottD16 02-15-2012 08:52 PM
1 Attachment(s)
i got the 4.5 rc full pack lift about three years ago and its pretty nice a little rough though but not a hard fix. the kits they have today have come a long way it makes me jealous, they are very complete with great quality. also i have a 96 and it had no vibrations.
Cooray45 03-25-2012 07:14 PM
I'm tryin to figure out wich kit for my 95 xj thinkin of x series 4.5 has everything and leaf packs
The time now is 03:31 PM.
