Quantcast What else is needed for a 3" lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > What else is needed for a 3" lift?
Old 11-22-2009, 03:43 PM   #1
tock172
If I were to purchase this lift:
Rustys Offroad: XJ Cherokee 3" Spring Pack Kit
What else would I need to get, in terms of steering and stuff like that.
Thanks guys
1996 Mint Green XJ -Sold, 7/10
1986 BMW 535i -Sold, 12/10
2004 330i Sport
tock172 is offline   Reply With Quote
Old 11-22-2009, 03:46 PM   #2
Stout95YJ
2003 WJ
Id get a track bar first, then some control arms
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting
1996 XJ trail rig - sold
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
Stout95YJ is offline   Reply With Quote
Old 11-22-2009, 03:50 PM   #3
tock172
That's what I was thinking, anything else?
2004 330i Sport
Old 11-22-2009, 03:53 PM   #4
99Greenmachine
Definitely some adj. control arms maybe a new trackbar... for that price, there are other kits out there that include what you need.
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 11-22-2009, 03:54 PM   #5
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
The trac-bar will need addressed and you will likely need longer swaybar endlinks or disconnects. The control arms will be fine for 3" of lift and I wouldn't replace them unless your current bushings are shot. The reason I say that is because the arms for a 3" lift are only 1/4" longer than stock, but if you add more lift later you will need longer arms and you don't want to swap them twice. If you do swap them now go with adjustables like stated above, then you will be good for more lift later.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 11-22-2009, 04:12 PM   #6
MrZucchinihead
I'm running 3" lift coils and an AAL, nothing else, stock LCAs and track bar, although it is a little off center, still drives perfectly fine.
MrZucchinihead is offline   Reply With Quote
Old 11-22-2009, 05:38 PM   #7
tock172
So other than the basics, like leafs, coils and shocks, I should want a kit that offers:
Sway bar relocation/discos
A new trac bar
Brake lines
And maybe control arms.
Anything else other than an sye/tcase that I may need?
2004 330i Sport
Old 11-22-2009, 07:50 PM   #8
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
You can use the kit above without anything else, but the front axle will be pulled toward the drivers side by a small amount. The swaybar will be pulled back very close to the coils too. You can drill a new hole for the trac bar on the axle mount and fix that problem, or leave it as is if it doesn't bother you. Mine is still with the stock trac-bar and pulled over but it is hardly noticeable. The swaybar is hit or miss, some need the longer links and some don't. The control arms won't really make much difference as the ones for 3" of lift are only 1/4" longer than stock ones. I would go with the rusty's kit if it was what you liked and add disconnects and a good trac-bar and double shear bracket like the IRO set-up later if it were me. Hardly any kits come with everything you need, some come with different things. But you will be okay running the rusty's kit by itself if wanted.
Old 11-23-2009, 10:17 AM   #9
tock172
Well the reason I ask is because I am really wanting to get my XJ converted over to 4x4 pretty soon. I have had all the parts to do it for about 3 months now, and haven't gotten anything. I have been weighing lift options for over a year now, but I haven't bought anything because I decided that I would not lift my XJ until it was 4x4. A few days ago, however, I figured, hey, if I am going to be doing all the 4x4 stuff at once, why not lift it at the same time, and save myself the trouble of getting everything taken off twice.
So, now I am seriously trying to find a good lift with the components I need. In addition to that, because I will likely be adding a tire carrier rear bumper to my XJ, I should definitely get a kit with full leaf packs. So now I am weighing options on what to get.
I like the IRO 3" kit with full leafs and a trac bar, I think I will probably get that when the time comes, but I am also keeping RE's 3.5 Superflex and the Rusty's kid in mind as well.
2004 330i Sport
Glock Forum
