What does it take to successfully build a LCOG daily driver? - JeepForum.com
post #1 of 28 Old 04-12-2010, 08:01 PM Thread Starter
uRabbit
1990 XJ Cherokee
My XJ is in need of rear suspension. So why not lift it a little and add some meaties to it?
I'm a huge fan of the LCOG Jeeps I've seen around here. Some are stock height, up to 3". The max height I'm thinking is 2", as that's a safe height so I don't have to funk around with the tcase or anything, right?
So, my questions are:
- is it just a matter of buying a lift kit/BB kit and installing it?
- I wouldn't mind learning how to trim metal, so fender trimming would be good to give me more clearance. So how large of tires can I go?
- would I need to modify any other vital parts to keep the Jeep in good reliable condition?
Thanks all!
'90 XJ 4.0 I6 | 4x4 | AW4 | 242 | 25U Signal Support Systems Specialist | Ship Date 20100823 | BCT Fort Jackson, SC | AIT Fort Gordon, GA
"Jeeps don't come with cup holders, but marriages do."
uRabbit is offline
post #2 of 28 Old 04-12-2010, 08:05 PM
shawnzoman
1994 XJ Cherokee
Lift and trim will be the easy part. Depending on what size tires you wanna run is whats gonna cost ya in regearing, beefier axles, shafts and whatever else you wanna do to it.
Skeff
shawnzoman is offline
post #3 of 28 Old 04-12-2010, 08:05 PM
USMC_XJ
2003 WJ
You could do a budget boost. Rock lizard has a good write-up using a bastard pack and different shocks. You could go up to 3'' without a transfer case drop.
I am at about 6'' and I have no SYE and only a t-case drop. (Saving for it)
3'' and 31's is an awesome combination.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #4 of 28 Old 04-12-2010, 08:08 PM
shawnzoman
1994 XJ Cherokee
and depending on how you wheel it, plenty of armor as well.
Skeff
post #5 of 28 Old 04-12-2010, 08:09 PM
dhardman
if you go a little crazy with the cutting wheel, like 2 inches around your fenders, bumpstop properly, and possibly new lower control arms at some point, you could get away with a MAX wheel of 33's. thats actually what im doing once i get my shackles in from IRO, 2.5" lift with 33's. maxxxxximum droop with little lift = awesome setup.
dhardman is offline
post #6 of 28 Old 04-12-2010, 08:13 PM Thread Starter
uRabbit
1990 XJ Cherokee
Was thinking 2" with 31's.
I don't know much about suspension. Bumpstops, DYE, etc. Dunno any of it. Is there a sort of "suspension for dummies" guide that just explains what they are? Haha.
Thanks a lot guys!
uRabbit is offline
post #7 of 28 Old 04-12-2010, 08:21 PM
bigbike
1995 XJ Cherokee
I have like 3.5 and 35s, its pretty sweet, you will NEED bumpstops along with triming, beefy axles, lots and lots of armor, etc... basically the same as building a reg jeep but more bumpstops and fender trimming. with 2 inchs you can run 33 comfortably, maybe even 35s. Always remember lift does not equal tire fittage.
bigbike is offline
post #8 of 28 Old 04-12-2010, 08:24 PM
Nick
2006 WK
If you run 31's, you don't need bigger axles really.
I'd get a 2" Old Man Emu lift.
If you really wanted to regear, you could, but you wouldn't have to.
31's are still reasonable on stock gears, though you will notice a change in performance.
2001 WJ | 4.7L V8 |
Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline
post #9 of 28 Old 04-12-2010, 08:28 PM
Nick
2006 WK
Are you sure you can fit 35's on only 2" of lift?
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #10 of 28 Old 04-12-2010, 08:31 PM
dhardman
i've seen 37's on 2.5, so yes. all about not being too scared to trim some of the shiny paint off your precious jeep. trim accordingly, bumpstop, take care of the control arms, and you'd be surprised.
dhardman is offline
post #11 of 28 Old 04-12-2010, 08:34 PM
cj7guy
If LCOG is your thing then stay away from lifts. Everyone chiming in with their 3.5 and 6.5 lifts is nice and all, but those are not LCOG setups.
You should trim to fit 31s with no lift and/or 33s with a 2" if you want to stay LCOG.
This guy claims 2" on 33s
I found it in this thread.
http://www.jeepforum.com/forum/f59/a...71/index2.html
07 JKU - 6spd - LSD rear
cj7guy is offline
post #12 of 28 Old 04-12-2010, 08:39 PM
4pointOH1998
2016 KL Cherokee
I'm at 2" of lift and running 31s. I am planning on staying at this height when I go to 33s. A little more trimming and some bumpstopping and you can achieve a lot of tire in a little lift.
-Bryan- ΚΔΦ-MΘΣΝΔ
Fighting the rust since April '08...
4pointOH1998 is offline
post #13 of 28 Old 04-12-2010, 08:41 PM
dhardman
couldnt have said it better myself. lcog is all about droop. lift is nice and all when you pull up to a brand spankin new 2011 cummins dodge 3500 dually and make it look like a matchbox car with your 8" lifted xj on 35's, but on the trail, a 2" lifted xj with 33's/35's is just as capable as a 6.5" lifted xj on the same tires. all about articulation, droop, and trimming
dhardman is offline
post #14 of 28 Old 04-12-2010, 08:43 PM Thread Starter
uRabbit
1990 XJ Cherokee
Stock height would be even better, ifthat works. I actually saw that doorless Jeep when I was thinking about doing it.
So if I don't modify the suspension, all I'll need are bigger tires and trimmed fenders? Oh, and flares for legalities. Correct?
Also, as far as performance goes... Since when was the XJ a beastly performer anyways? :P
edit: droop?
uRabbit is offline
post #15 of 28 Old 04-12-2010, 08:44 PM
dhardman
tires, trimming, BUMPSTOPPING! and lots of it.
dhardman is offline
build thread for my capable daily driver tizzdizz XJ Cherokee Technical Forum 74 10-14-2014 12:26 PM
XJ vs WJ for daily driver? 1 ton yj XJ/MJ Cherokee Non-Technical Forum 22 07-19-2011 10:21 AM
97 XJ Sport Ultimate Daily Driver Build AbsolutXJ XJ/MJ Cherokee Non-Technical Forum 2 02-07-2009 08:35 PM
Build up my daily driver or pick up 2nd xj? JrTjK XJ Cherokee Technical Forum 8 02-19-2006 12:26 PM
