what does a red GEN light mean? - JeepForum.com
post #1 of 11 Old 01-21-2007, 03:20 PM Thread Starter
red96jeep
on the dash right above the check engine light. what's it mean? in the manual it says that spot is not in use, but apparenty it is.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline
post #2 of 11 Old 01-21-2007, 03:28 PM
bee guz
If you have genenerator light on it means you are not makeing any power, for your battery, or there is something wrong with the printed circuit behind the instrument panel, and the light is just on, but I would have it checked out before you get stranded someplace.
If the light is just on dim, it could be a bad diode in the alternator, and if its a GM alternator this can be repaired by changing the diode trio.
bee guz is offline
post #3 of 11 Old 01-21-2007, 03:49 PM Thread Starter
red96jeep
haha well right now i'm stranded in my garage she wont start.
5 inch lift
rear ended= totaled
project vehicle
post #4 of 11 Old 01-21-2007, 06:03 PM
h2rescue
h2rescue's Avatar
I have the same light on and i have to get a new alternator
White Jeep Club Member #51
Project Groundhog:
1996 XJ SPORT, 4.0 AW4 NP231, Rock Sliders
PIAA lighting, Grill Guard, Dual Battery Setup
h2rescue is offline
post #5 of 11 Old 01-21-2007, 08:09 PM
anony91xj
Usually means the alternator is bad. If the car won't start, charge the battery or jump it and see if it'll start. If that light is on with the engine running (and the charger/jumper cables disconnected), it's a safe bet to replace the alternator.
1998 VW GTI 2.0
anony91xj is offline
post #6 of 11 Old 01-21-2007, 09:41 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
when my alt died i had no such light turn on, i dont even have one.
1990JEEPXJ is offline
post #7 of 11 Old 01-22-2007, 03:32 PM Thread Starter
red96jeep
ok well what should i do now, the light has stoped comming on. i have the battery fully charged, when the key is placed on the ON position all eletronics work and the chekc engine light and GEN light have stoped comming on. BUT....when i go to start the jeep it wont start. not even turn over. no clicky from the starter! i would say it's a bad starter but then why was my jeep cutting off randomly on the drive home the other night before all this started to happen? could it be a bad igniton switch? or am i just totaly screwed? i'm thinking of callin a tow truck tommrow to haul her off and rape me even more in the wallet.
5 inch lift
rear ended= totaled
project vehicle
post #8 of 11 Old 01-22-2007, 04:39 PM
RickyN29
RickyN29's Avatar
Wow, im surprised they refer to it as a generator!! That was way back in the day.
Best bet is to drive to a Kragen/Shucks/Checker or Autozone and have them run a free electrical diagnostic test. They can test the output of your alternator (installed in the vehicle) both with load and without load. They can tell you right then and there if you alternator is not able to meet the electrical demand of the vehicle.
If it turns out to be a bad alternator, you replace it yourself with basic hand tools and maybe an hour.
It could also be a bad battery (bad cell) which would put an excessive load on the alternator.
As a simply, inconclusive test, you can put a multimeter on the battery with the vehicle off (should read ~12VDC) then start the vehicle. With the engine running, it should read ~14VDC. Then turn on headlights, AC, defrost, etc (to create a load) and it should be able to maintain ~13-14VDC.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #9 of 11 Old 01-22-2007, 04:40 PM
RickyN29
RickyN29's Avatar
Yeah, us RENIX Jeepers don't have warning lights for anything......they just never break!!! In 96+ more instrument indicator lights were installed with the switch to OBDII (On Board Diagnostics [system 2])
*Rusty's ~6" Lift
RickyN29 is offline
post #10 of 11 Old 01-22-2007, 04:46 PM Thread Starter
red96jeep
that looks good excpet for the whole drive part lol. my friend who is a mechanic is comming over to take a look at it. hopefully he can shed some light by being able to see the jeep.
5 inch lift
rear ended= totaled
project vehicle
post #11 of 11 Old 01-22-2007, 04:51 PM
RickyN29
RickyN29's Avatar
Opps, missed this post!
Hum, I would first rule out the battery. Could be a completely dead battery. If possible, try jumpstarting it. If that doesn't seem to work, disconnect your battery (which might have a bad cell) completely, and hook the jumper cables just to your battery cables. Try to jump it again.
*Rusty's ~6" Lift
RickyN29 is offline
Drivers side brake light/running light/ blinker all not working. 2doorxj XJ Cherokee Technical Forum 6 11-02-2009 08:25 AM
Emergency Brake light, ABS light and Airbag light stay on after starting 2001 4.0. s4ryanl1 XJ Cherokee Technical Forum 5 02-14-2009 06:42 PM
Tail Light / Turn Signal / Brake Light Problem swdmus XJ Cherokee Technical Forum 1 12-03-2008 04:09 PM
check engine light/battery dummy light coming on iwishihad1 XJ Cherokee Technical Forum 4 08-23-2007 12:22 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 09:50 AM
