what does a bad power steering box feel like?? - JeepForum.com
post #1 of 10 Old 07-24-2009, 03:38 PM Thread Starter
will_coop
1989 XJ Cherokee
I'm pretty sure my steering box has gone out but I want to know if anyone else has replaced one and what it felt like before. Right now it drives fine until about 50 then it is hard to keep it in a lane. I have checked all of my linkage and arms and everything is tight with no play. The steering box is the last thing i can think of. There has always been quite a bit of side to side play in the steering wheel and it drove fine.
will_coop is offline
post #2 of 10 Old 07-24-2009, 06:40 PM
Bstd_02_wgn
Take off the drag link from the pitman arm and see if you can wiggle the shaft coming out of the power steering box. If there is any play replace the box. If there is no play, have someone start the jeep and turn the wheel back and forth while you watch the pitman arm. See if there are any jerks or anything, the action of that shaft should be smooth (Dont take THAT the wrong way!). If those things check out fine, remove the belt around the power steering pump and see if the pulley has play...if for some reason the pump isn't throwing out the right amount of fluid it may show up as a hesitation in steering. Let us know!
Bstd_02_wgn is offline
post #3 of 10 Old 07-24-2009, 06:43 PM
Mickey_D
Normally when a pump goes, it fails to pump enough fluid and it makes low speed/stopped steering difficult.
Highway speed wandering is indicative of worn suspension/steering components.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 10 Old 07-24-2009, 08:26 PM Thread Starter
will_coop
1989 XJ Cherokee
the suspension may have 10k miles on it. all u-joints, ball joints and bushings have been replaced. I will try taking off the drag link and see what happens.
post #5 of 10 Old 07-24-2009, 08:30 PM
Mickey_D
Now that I think about it, a bad bearing on the steering box output shaft would cause wandering...
________________
#4
Mickey_D is offline
post #6 of 10 Old 05-13-2015, 05:42 PM
40jeep99
I'm have the same issue. Right at 50. Wandering and a little wooble. Steering box has side to side play in the output shaft. But here's the kicker. It's the fourth new one I have tried in a week. 3 new stock xj boxes. And now I have s10 box in it. Every one of them had side to side play.
40jeep99 is offline
post #7 of 10 Old 05-13-2015, 06:47 PM
RLE
When was your last alignment? If the front wheels
are toed-out, they can wander on the highway.
The front should be toed-in about 1/4 to 3/8 inch.
If that isn't the problem, then it could very well be
the steering box. I changed mine when it had about
four inches of play on the steering wheel a few years
ago and the wandering stopped.
RLE is offline
post #8 of 10 Old 05-13-2015, 09:32 PM
FairlanePhil
FairlanePhil's Avatar
Alignment will do that. Until I found a good shop my old Fairlane had trouble keeping between the guard rails.
I know my XJ steering box is shot. It's gushing fluid all over from the pitman shaft seal
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #9 of 10 Old 05-13-2015, 10:03 PM
40jeep99
My alignment is good. I do them myself. My steering box doesn't have any play in it. Other than the side to side movment in the output shaft. My wandering is more likely my geometry between my drag link and my Trac bar. But my wooble is definitely the play in the output shaft.
40jeep99 is offline
post #10 of 10 Old 05-13-2015, 10:04 PM
AZ Jeff
2014 JK Wrangler
The output shaft (properly called the "pitman shaft") should NOT have any radial OR axial play in it. Where are you getting these steering boxes that are coming like this?
Wandering can be caused by things other than the box, but a loose pitman shaft certainly will not lessen wander. I would be inspecting the entire linkage (including ball joints) AND the track bar for signs of wear, as that can be a major source of wander.
The front suspension on the XJ is a system, and that means that ALL parts of the system need to be up to snuff to work as a system as intended. Fixing the steering box is a good first step, but don't stop there.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
Steering wheel feel tight and won't return to center crowncaprice XJ Cherokee Technical Forum 15 06-01-2011 08:07 AM
Power Steering too lightno road feel Johnny1953 XJ Cherokee Technical Forum 6 10-21-2009 07:54 PM
Whinning power steering; replace steering box or pinion seal? myriad360 XJ Cherokee Technical Forum 1 05-12-2009 09:15 PM
steering just doesn't feel right iwishihad1 XJ Cherokee Technical Forum 2 08-04-2007 11:49 PM
Brake pedal "Feel" & Power steering too!! dezmoduo XJ Cherokee Technical Forum 3 11-28-2006 11:10 AM
