What differential do I have? - JeepForum.com
post #1 of 16 Old 08-29-2011, 08:57 PM Thread Starter
Mikej1224
I think it's a Dana 35 but I want to be certain before I buy a diff cover. Attached is a picture of it:
It's a 99 XJ, does not include full-time 4WD. Just 2WD, N, 4H, 4L
Thanks.
Mikej1224 is offline
post #2 of 16 Old 08-29-2011, 09:31 PM
bdodge
1997 XJ Cherokee
Yes that is a d-35, the cryco's have a flat lip across the bottom.
97' Cherokee sport 2 DR / 4.0 Power Tech, 5 spd MAN, Command trac / Dana M30/181MM front axel, Corporate 8.25 rear axel / 6.5" Bastard lift, 31X10.5 Daytona futura's on Cragar 15X8 soft 8's, Logans Metals Front winch bumper, Flowmaster super 44, Magnoflow high flow cat
bdodge is offline
post #3 of 16 Old 08-29-2011, 09:33 PM
lonewolf41191
Im no pro but it looks like a chrysler 8.25, Heres mine
lonewolf41191 is offline
post #4 of 16 Old 08-29-2011, 09:36 PM Thread Starter
Mikej1224
the 8.25 looks too circular. i think its the dana 35. look at the part that protrudes in the bottom left of the d35. you don't see that with the 8.25
post #5 of 16 Old 08-29-2011, 10:08 PM
Scott_Sport99
do you have ABS?
this is from WIKI
http://en.wikipedia.org/wiki/Jeep_Cherokee_%28XJ%29
Front Axle
* 1984–1996: Dana 30, High Pinion, Reverse Cut, 27-spline axleshafts (1989 – 1995 : with ABS used 5-297x universal joints, non-ABS had 5-260x universal joints. Certain XJ models were produced with constant-velocity joints instead of universal joints.)
* 1996–1999: Dana 30, High Pinion, Reverse Cut, 297x/760 universal joint, 27-spline axleshafts.
* 2000–2001: Dana 30, Low Pinion, Standard Cut, 297x/760 universal joint, 27-spline axleshafts.
* 1985–2001: Straight non-driven front axle for two-wheel drive only.
[edit] Rear Axle
* 1984–1989: Dana 35, non c-clip, with anti-lock braking system (ABS) or non-ABS.
* 1990–1996: Dana 35, c-clip, ABS or non-ABS.
* 1997–2001: Dana 35, c-clip, ABS.
* 1991–1996: Chrysler 8.25", c-clip, non-ABS, 27-spline axleshafts.
* Late 1996–2001: Chrysler 8.25", c-clip, non-ABS, 29-spline axleshafts.
* 1987–1990: Dana 44, non-abs, 30-spline axleshafts.
Scott_Sport99 is offline
post #6 of 16 Old 08-29-2011, 10:15 PM
95JeepFactory
1995 XJ Cherokee
Thats an 8.25. Read the sticky at the top of the forum
95JeepFactory is offline
post #7 of 16 Old 08-29-2011, 10:30 PM
the_weirdo
the_weirdo's Avatar
That is a Dana 35. What makes you think it is a C8.25? If you say rubber plug, please be aware that lots of Dana 35's have rubber plugs.
the_weirdo is offline
post #8 of 16 Old 08-29-2011, 10:45 PM
gweezo698
The OP's(Mikej1224) axle is a Dana 35, see the dana logo?
lonewolf41191's photo is of a Chrysler 8.25. Note the flat part of the diff that sticks out pasted the cover, easiest way to tell the difference.
-01 XJ 4.0 auto 31s ARBs and armored
-96 XJ stock 4.0 5spd SOLD
-94 XJ 4.0 5spd 3" 33s(beater/parts)SOLD
-96 XJ 3" Rusty's 4:56s f/ARB r/Detroit 35s SOLD
-84 CJ-7 4.5" 35s locked SOLD
-97 TJ Sahara 3.5" 34s locked SOLD
gweezo698 is offline
post #9 of 16 Old 08-29-2011, 10:48 PM
JeepZJlover
That's a Dana 35
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #10 of 16 Old 08-29-2011, 11:05 PM Thread Starter
Mikej1224
Dana 35 it is. thanks guys.
post #11 of 16 Old 07-19-2013, 12:29 PM
pandilucciano
Hi Guys, well I think I have a dana 30 in my 2005 TJ front axle, but in some other parts I see they mention a Dana 35, can U help me to clear up if this is Dana 30 or 35?
pandilucciano is offline
post #12 of 16 Old 07-19-2013, 05:28 PM
the_weirdo
the_weirdo's Avatar
Front axles are Dana 30's. No such thing as a Dana 35 front axle in a Jeep.
post #13 of 16 Old 07-20-2013, 07:44 AM
effinstang
One thing I've noticed is the C8.25 has a bead roll around the outside edge
of the dif cover, where as the dana 35 cover is just flat all the way to the edge. Can't really tell in the OP pics.
effinstang is offline
post #14 of 16 Old 07-20-2013, 07:50 AM
sjones26573
Wrong forum bub. Ask your q's in TJ Tech. For the most part, the majority of Jeep front axles are Dana 30's. A Dana 35 is a rear axle only.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #15 of 16 Old 07-20-2013, 08:06 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I am relatively sure that in the last 2 years since the OP posted, he has been able to figure out his rear axle type.
The Chrysler 8.25 has a flat lip on the bottom, and extra lumps on the topside over the pinion yoke. The D35 does not.
Rubber plugs, ABS, and/or the diff cover are not that relevant to the identification.
CJ7-Tim is offline
cherokee , differential , xj
What differential?? meofouse XJ Cherokee Technical Forum 2 10-16-2010 07:38 AM
LSD Differential for 2WD Tess XJ Cherokee Technical Forum 6 07-14-2010 05:52 PM
differential ID artboy XJ Cherokee Technical Forum 4 05-11-2007 07:08 PM
Also, MUD IN DIFFERENTIAL!!! A lot of it too. dirt machine XJ Cherokee Technical Forum 13 01-05-2006 11:27 AM
Differential oil Rescue XJ XJ Cherokee Technical Forum 3 06-07-2005 06:23 PM
