-   -   What differential do I have? (http://www.jeepforum.com/forum/f11/what-differential-do-i-have-1258947/)
Mikej1224 08-29-2011 08:57 PM
I think it's a Dana 35 but I want to be certain before I buy a diff cover. Attached is a picture of it:
http://img850.imageshack.us/img850/9...9110812704.jpg
It's a 99 XJ, does not include full-time 4WD. Just 2WD, N, 4H, 4L
Thanks.
bdodge 08-29-2011 09:31 PM
Yes that is a d-35, the cryco's have a flat lip across the bottom.
lonewolf41191 08-29-2011 09:33 PM
3 Attachment(s)
Im no pro but it looks like a chrysler 8.25, Heres mine
Mikej1224 08-29-2011 09:36 PM
the 8.25 looks too circular. i think its the dana 35. look at the part that protrudes in the bottom left of the d35. you don't see that with the 8.25
Scott_Sport99 08-29-2011 10:08 PM
do you have ABS?
this is from WIKI
http://en.wikipedia.org/wiki/Jeep_Cherokee_%28XJ%29
Front Axle
* 1984–1996: Dana 30, High Pinion, Reverse Cut, 27-spline axleshafts (1989 – 1995 : with ABS used 5-297x universal joints, non-ABS had 5-260x universal joints. Certain XJ models were produced with constant-velocity joints instead of universal joints.)
* 1996–1999: Dana 30, High Pinion, Reverse Cut, 297x/760 universal joint, 27-spline axleshafts.
* 2000–2001: Dana 30, Low Pinion, Standard Cut, 297x/760 universal joint, 27-spline axleshafts.
* 1985–2001: Straight non-driven front axle for two-wheel drive only.
[edit] Rear Axle
* 1984–1989: Dana 35, non c-clip, with anti-lock braking system (ABS) or non-ABS.
* 1990–1996: Dana 35, c-clip, ABS or non-ABS.
* 1997–2001: Dana 35, c-clip, ABS.
* 1991–1996: Chrysler 8.25", c-clip, non-ABS, 27-spline axleshafts.
* Late 1996–2001: Chrysler 8.25", c-clip, non-ABS, 29-spline axleshafts.
* 1987–1990: Dana 44, non-abs, 30-spline axleshafts.
95JeepFactory 08-29-2011 10:15 PM
Thats an 8.25. Read the sticky at the top of the forum
the_weirdo 08-29-2011 10:30 PM
That is a Dana 35. What makes you think it is a C8.25? If you say rubber plug, please be aware that lots of Dana 35's have rubber plugs.
gweezo698 08-29-2011 10:45 PM
The OP's(Mikej1224) axle is a Dana 35, see the dana logo?
lonewolf41191's photo is of a Chrysler 8.25. Note the flat part of the diff that sticks out pasted the cover, easiest way to tell the difference.
JeepZJlover 08-29-2011 10:48 PM
That's a Dana 35
Mikej1224 08-29-2011 11:05 PM
Dana 35 it is. thanks guys.
pandilucciano 07-19-2013 12:29 PM
1 Attachment(s)
Hi Guys, well I think I have a dana 30 in my 2005 TJ front axle, but in some other parts I see they mention a Dana 35, can U help me to clear up if this is Dana 30 or 35?
the_weirdo 07-19-2013 05:28 PM
Front axles are Dana 30's. No such thing as a Dana 35 front axle in a Jeep.
effinstang 07-20-2013 07:44 AM
One thing I've noticed is the C8.25 has a bead roll around the outside edge
of the dif cover, where as the dana 35 cover is just flat all the way to the edge. Can't really tell in the OP pics.
sjones26573 07-20-2013 07:50 AM
Wrong forum bub. Ask your q's in TJ Tech. For the most part, the majority of Jeep front axles are Dana 30's. A Dana 35 is a rear axle only.
CJ7-Tim 07-20-2013 08:06 AM
I am relatively sure that in the last 2 years since the OP posted, he has been able to figure out his rear axle type.
The Chrysler 8.25 has a flat lip on the bottom, and extra lumps on the topside over the pinion yoke. The D35 does not.
Rubber plugs, ABS, and/or the diff cover are not that relevant to the identification.
http://www.fototime.com/EC03D5A7E23CA77/standard.jpg
http://www.fototime.com/0167C2BCEA93748/standard.jpg
http://www.fototime.com/E4D19ADE68546E9/standard.jpg
The time now is 11:32 PM.
