what did i do wrong (rms/oil pan & gasket replacement) - JeepForum.com
post #1 of 3 Old 05-19-2012, 12:20 PM Thread Starter
slayer
Long time lurker, first time poster....
Let me start by saying while I was a helicopter mechanic in the Marine Corps, I never before this worked on my Jeep before...
I have a 1996 Grand Cherokee V8. Here is the progression to where I am...
1) I start intermittently losing oil pressure on the gauge at stop lights/signs. It drops, dings, and then went back up when going again. This went on for about a month but I mostly just ignored it.
2) I drive through an oil change station and within a few days the pressure drops down and never goes back up. At this time a slight leak starts as well.
3) Take the Jeep back to oil change place and tell them whats going on. The manager takes video of my underside leaking from between the pan and tranny and indicates that this is likely the problem with pressure.
4) I call stealership. They tell me it is likely the rear main seal and its a $900 dollar fix.
5) I say no way and I live with the leak until it becomes too much. Being the veteran mechanic that I am, I proceed to buy tools and parts to do the job myself.
6) First day, I go to drain the oil and find that the plug is stripped. Thank you drive through oil change place. I get a new pan from O'Reilly's for next day pickup.
7) Day two, put the jeep on jacks, take off old filter (which is mysteriously different than the new one I have), remove starter, remove inspection plate, undo pan bolts and drop the pan. At this point I realize that yes, I will have to do all that other **** to take the pan out.
8) Day three, mother's day, and since I am a mom, I took the day off!
9) Day four, remove exhaust pipe from manifold (hard even for my little hands, how do you guys do it?), jack the tranny, remove crossmember and mount, slide exhaust down but only to the limit of the O2 sensor wires because I could not get it off. I placed the exhaust pipe on a jack so as to spare the O2 wires. At this point I expect pan to drop but it won't, so I jack tranny higher and higher. NO JOY!
10) Day five, at my wits end and searching around this site for answers. I did not want to get into removing steering stuff so I ask a neighbor for a quick hand. He comes over and says, "turn the steering wheel to the left". I did and voila, pan comes out!
11) Day six, I clean off old pan gasket, remove the oil pump, pull off the rear cap (easily) and pop out the top seal (easily again). Next comes the part of trying to figure out which lip is the "big lip", I am pretty sure I got this right. I use some dish soap to lube the seal and a syringe squirt of dish soap into the channel, the seal goes right in (I used my thumb to keep it from sheering the whole time). Cleaned the cap surface and rtv to the two spots the manual indicates. Bolt it back on and torque to specs. place new pan in with gasket, and rtv the four corners indicated in manual and online research. bolted it up and torqued to specs. replaced all the rest and torqued to specs.
12) Now that it was all back together I took it off jacks, added 5 qts, and started her up. FAIL! Heres the problems:
a) engine sounds like ****, like she is really hurting (oil pump?). On top of
that, there is a rattling (inspection plate?)
b) there is still a leak (though smaller, i think), i smelled it and i think it
smells like dishsoap? so still rms?
c) after a minute of running (****ty) there is mass smoke from right side
d) had to pull out of drive way and park on the street and she did not
want to go. now she sits parked and waiting for me to figure it out.
please help!!!!!! p.s. in the bay area if someone wants to come help me out!
slayer is offline
post #2 of 3 Old 05-19-2012, 02:17 PM
kg4kzv
1995 XJ Cherokee
Sorry to see your troubles and I don't think it sounds good. Your Jeep is a ZJ Grand Cherokee (1993 - 1998) so hopefully a mod moves your post over there soon and you will get more help. XJ Cherokees never got the V-8 stock. I find it very cool you decided to take on the work on your own and being a shade tree I don't see anything you did wrong.
I suspect that the oil leak was a somewhat separate issue from your oil pressure trouble unless it ran out of oil at some point. Best of luck to your on getting you Jeep back on the road.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #3 of 3 Old 05-20-2012, 04:02 PM
kg4kzv
1995 XJ Cherokee
Bump so maybe mods will catch and move to the correct sub-forum and someone there hopefully can help slayer out!!!
Chris
kg4kzv is offline
cherokee , gasket , oil pan , oil pump , rear main seal
oil pan gasket replacement popowiecki XJ Cherokee Technical Forum 14 04-20-2016 09:17 AM
Could my head gasket be installed wrong Sdenzik XJ Cherokee Technical Forum 5 05-06-2012 12:57 PM
Oil pan gasket replacement chris782 XJ Cherokee Technical Forum 7 10-03-2010 07:13 PM
Oil Pan Gasket Replacement DesertOne XJ Cherokee Technical Forum 2 02-19-2010 05:30 AM
Valve cover gasket job gone wrong!!!!!! limited XJ Cherokee Technical Forum 9 07-28-2008 10:20 AM
