what controls the resistance in steering? - JeepForum.com
post #1 of 15 Old 10-09-2006, 07:46 PM Thread Starter
ChipsXJ
1993 XJ Cherokee
what is it that controls the resistance in steering?
I have a 92 briarwood that has easy turning of the steering wheel.
My other 2 jeeps (92 and 93 xjs) have steering that has more resistance.
The first is not loose or anything, it just does not have the resistance/control of the others.
thanks
1993 Jeep Cherokee
4.0 Auto 4dr 4X4
RED JEEP MEMBER #253
ChipsXJ is offline
post #2 of 15 Old 10-09-2006, 07:54 PM
XJ2Timer
I don't know but I'm guessing the amount of hydraulic pressure boost the pump provides. The steering on my '01 just feels heavy and while it may have more of a return to center it feels vague at the same time. My old '89 had a lighter feel but felt more precise in steering input and response.
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline
post #3 of 15 Old 10-10-2006, 07:39 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I'd like to know this too. My 93 will turn with little or no effort, while my wife's 99 is heavy.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 15 Old 10-10-2006, 07:57 AM
WMW0505
i would say just the difference in the power steering setup...like said above the pump and hydraulic setup.
WMW0505 is offline
post #5 of 15 Old 10-10-2006, 07:58 AM
law.74
The steering box has a "slop" adjustment screw on the top. I'm not sure what the real name is but the FSM should hold more info.
law.74 is offline
post #6 of 15 Old 10-10-2006, 12:09 PM
oldmanscherokee
1992 XJ Cherokee
the sector shaft adjustment nut on the top of the box is your preload for steering feel. although you can adjust it its not recomended. not enough and its real loose, just a smidge to much and youll have no return to center. if its only feeling loose and theres no slop inthe steering linkage dont bother with it.
full time tech for chevy, part time trail rider
95 Ford Lightning (sold), 09 Caddy CTS-V, 04 Buell Firebolt XB12R w/true flame paint, 00 harley XL chopped, 81 Trans Am, 85 K5 Jimmy 4 inch w/35s, 92 cherokee
10,000 original miles
4.5 inch RC lift
32 11.5 bfg muds
oldmanscherokee is offline
post #7 of 15 Old 10-10-2006, 02:30 PM
XJH-007
XJH-007's Avatar
X2
My old 84 XJ had powersteering that you could wheel with your Pinky.....my newer one is much more stiff.
I think they do it so there's more restistance as your're turning..more like a car....It's suppose to be more safe
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #8 of 15 Old 10-10-2006, 03:05 PM
PhatJeeps
It's safety related. More resistance at higher speeds = better stability if you're a nervous, twitchy little bastard. LOL!!!
PhatJeeps is offline
post #9 of 15 Old 10-10-2006, 03:06 PM
xj BMX xj
1992 XJ Cherokee
what about the steering dampener? wouldent that have a play in that? or am i just stupid for asuming that haha
92 Cherokee Trail toy. - 97 Cherokee Street toy.
XJcruiser: Crumple zones? I guess the other car will have to share those.
xj BMX xj is offline
post #10 of 15 Old 10-10-2006, 03:14 PM
90lerado
90lerado's Avatar
it might be similiar to the setup on my dads durango. the steering keeps the same resistance reguardless of the RPMS. on my 90 dodge the higher the rpms the easier the wheel is to turn, wiuth the durango its the same. provides a better feel at highway speeds.
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts"
- General George Patton Jr, "War as I knew it" 1947
Wife's/my vehicle: 06 Pontiac vibe awd
Hopefully a jeep sometime in the future
90lerado is offline
post #11 of 15 Old 10-10-2006, 07:26 PM
stevenaa
Are you talking resistance while stopped or is it twitchy while driving. Caster affects this while in motion.
stevenaa is offline
post #12 of 15 Old 10-10-2006, 07:36 PM
XJ2Timer
Originally Posted by XJH-007
X2
My '89 was like that. Great for off road and I never had a problem with it feeling twitchy on the road. It handled more precisely than my '01.
XJ2Timer is offline
post #13 of 15 Old 10-10-2006, 08:49 PM
quadzilla
The more caster a front end has the harder it will be to steer away fron center but will center itself easier. Or it could be the other way around. I can't remember which.
1987 Cherokee Pioneer 4.0 Automatic 246,000 miles. Front: zj coils+spacers rear: 3" lift blocks. I will never get all the mud off it now.
quadzilla is offline
post #14 of 15 Old 10-11-2006, 01:35 AM
tizzdizz
tizzdizz's Avatar
2003 WJ
I'm thinking of a Chopper with a big long fork, and how that would affect the turning, etc. Does more caster = closer to the front end of the car, or closer to the rear end of the car? I can never remember... I kinda see what you're getting at though.
, 4" Zone, 265/75/16 Duratracs, Addco rear swaybar
r: Stock with 31s and a trim. Sold
: 2" on 31s with armor and dents. Sold
74 Nova - 2" drop and disc conv. Sold.
tizzdizz is offline
post #15 of 15 Old 10-11-2006, 11:28 AM
Robs92XJ
Does the steering wheel return to center after completing a turn on its own pretty well? If not, I would suspect caster is too low, and would take it to get an alignment and have them give you a print out of the specs.
Robs92XJ is offline
Fan Clutch..........No resistance when hot?? Swiss XJ Cherokee Technical Forum 11 07-23-2008 12:27 PM
Uneven steering resistance josephmartins XJ Cherokee Technical Forum 2 05-13-2007 04:51 PM
steering stabilizer increase resistance ChipsXJ XJ Cherokee Technical Forum 9 05-05-2007 05:50 PM
Viscous Fan Resistance 88XJ Ltd XJ Cherokee Technical Forum 2 05-11-2005 06:11 AM
Steering resistance while turning XJ_Eric XJ Cherokee Technical Forum 4 02-24-2004 11:04 AM
