What causes hose to come off radiator? - JeepForum.com
post #1 of 13 Old 02-03-2010, 06:50 PM Thread Starter
mmscheeler
1992 XJ Cherokee
I just replaced nearly the entire cooling system. It is due for emissions inspection and I went to take it tonight. I have not driven it since the replacement other than around my yard. I took it to get gas and air after that I decided not to take it for the inspection as I would not make it. I pull back into my garage and shut it off. I was sitting in the car looking at something and hear a pop and water hitting the floor. When I got under the hood the top radiator hose had come off from the radiator. No holes or anything and the hose is not clogged! Any thoughts as I really just want this back on the road.
Thanks for the help in advance!!
mmscheeler is offline
post #2 of 13 Old 02-03-2010, 07:28 PM
USMC_XJ
2003 WJ
Most likely those hose clamp was junk. This happened to me. Also, make sure the hose is actually all the way onto the outlet. I had to remove the top of the core support in order to put it on all the way and then tighten the clamp. Has been fine for a couple months so far.
Pull the top of the core support and put the hose on good with a new clamp.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 13 Old 02-03-2010, 07:32 PM Thread Starter
mmscheeler
1992 XJ Cherokee
The core support was off but I will try a new hose clamp. Should it make any difference if it I replaced the t stat with a 160*? Thanks for the tip.
post #4 of 13 Old 02-03-2010, 07:35 PM
danw77
1994 ZJ
same thing happened on my 95. the end tanks (and the place where the hose attaches) are made out of plastic. on mine, the plastic cracked and the "rib" that runs around the where the hose connects broke off and there was nothing for the hose clamp to grab on to.
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
post #5 of 13 Old 02-03-2010, 08:05 PM
USMC_XJ
2003 WJ
Why are you running a 160* t-stat? That will only hurt your engine, not help it...
USMC_XJ is offline
post #6 of 13 Old 02-03-2010, 08:17 PM Thread Starter
mmscheeler
1992 XJ Cherokee
Good to know... guess I will be replacing that tomorrow!!! I read a few guys on here running cooler t stats
post #7 of 13 Old 02-03-2010, 08:17 PM
AZ Jeff
2014 JK Wrangler
If you are running a 160 t'stat, you have a good chance of FAILING an emissions test. If you don't know WHY, then ask.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #8 of 13 Old 02-03-2010, 08:55 PM
1stockjeep
1993 XJ Cherokee
There is alot of mixed emotions on t stats on here! But a 160 will run to col and the engine will be constantly adding more fuel thinking its still not warmed up.
1stockjeep is offline
post #9 of 13 Old 02-04-2010, 08:30 PM Thread Starter
mmscheeler
1992 XJ Cherokee
So I replaced the t stat with a orig. temp one and tightned the hose clamp. It looks pretty new & I think I may not have had it as tight as it should have been. So !I get it put back together and now it is overheating again. The upper radiator hose was ice cold and I had no heat. What else can I do?
post #10 of 13 Old 02-04-2010, 08:37 PM
blingII
Bleed and fill
blingII is offline
post #11 of 13 Old 02-04-2010, 08:54 PM Thread Starter
mmscheeler
1992 XJ Cherokee
I did once. Any suggestions on getting all the coolant out of the reservior?
post #12 of 13 Old 02-06-2010, 12:45 PM Thread Starter
mmscheeler
1992 XJ Cherokee
Got all the air out and now it is running better Does it matter that it is now running a little below 210?
post #13 of 13 Old 02-06-2010, 06:05 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
A little below 210 is where the majority of 4.0 engines run. Good to go.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro XJ Cherokee Technical Forum 2 08-13-2009 08:49 PM
Got new radiator hose. few questions! theglowingbus XJ Cherokee Technical Forum 9 01-09-2009 03:58 PM
lower radiator hose blacky_j XJ Cherokee Technical Forum 11 07-25-2008 04:07 PM
Radiator Hose Cut by Fan on KJ jwhitley XJ Cherokee Technical Forum 2 06-12-2008 06:34 AM
Radiator hose over AC compressor cnskate XJ Cherokee Technical Forum 1 02-07-2008 11:17 AM
