What is best engine and transmission skidplate? - Page 2 - JeepForum.com
post #16 of 22 Old 04-10-2013, 03:01 PM Thread Starter
Charley3
With 242 Tcase and Chysler rear diff, 2" lift typically creates vibes. I experienced that with my prior XJ and 2" lift. I also read that in the JF sticky on SYE.
However, with only 1.25" to 1.5" lift (and stock crossmember) hopefully I won't have vibes and won't need SYE.
However, with 1.25" to 1.5" lift AND a TNT crossmember that raises Tcase and driveline 1", that would be a total of 2.25" to 2.5" change in driveline angle, which would for sure require a SYE since I have 242 Tcase and Chrysler rear diff.
Thanks for explaining about not wanting to lower drive train. I will avoid lowering driveline, and (at least for now) I will avoid raising driveline.
I am going to get Skidrow engine-tranny skid, which works with stock crossmember, though I would like to buy a strong crossmember (with no lift or drop). Anyone know of a stronger cross member with no lift or drop?
I can decide later what to get for Tcase. I'm not going near rocks. At least not any time soon.
Mainly I want weight of front and rear skids installed BEFORE I install lift springs.
Charley3 is offline
post #17 of 22 Old 04-10-2013, 03:26 PM
RockRodHooligan
RockRodHooligan's Avatar
If it becomes an issue, I highly recommend the IRO hack-n-tap SYE over the RE one. With the RE it generally cost me about $130 to rebuilt my rear shaft with spicer parts, the stock front shaft took about $90 to rebuild, or about $13 for a good one out of the junk yard.... Guess what I did most of the time?
http://www.ironrockoffroad.com/Merch...egory_Code=PFX
And with the IRO SYE, one shaft works front and rear, no need to run with 2 spare shafts when you are wheeling.
Edit: nevermind I forgot the 242 uses a different SYE.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #18 of 22 Old 04-10-2013, 06:06 PM Thread Starter
Charley3
Thanks for advice on skidplates and SYE.
I appreciate it.
Charley3 is offline
post #19 of 22 Old 04-26-2013, 06:54 PM Thread Starter
Charley3
Originally Posted by RockRodHooligan View Post
I'm partial to the TNT belly pan, high clearance crossmember and t-case skid all in one.
Do you know how much that weighs?
Considering getting it.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #20 of 22 Old 04-26-2013, 07:24 PM
RockRodHooligan
No I don't remember, I sold mine when my last Jeep went down. I'm gonna guess around 60lbs? I would contact Rod over at T&T and ask, he'll get you hooked up.
96 XJ:
***** inches...
post #21 of 22 Old 04-26-2013, 08:20 PM Thread Starter
Charley3
I wonder how to mount a Skidrow engine-tranny skid to TNT belly pan? My cousin and I will figure it out, but any advice from someone who's already done it would be appreciated.
Charley3 is offline
post #22 of 22 Old 05-09-2013, 06:56 PM Thread Starter
Charley3
I ordered:
Skidrow engine-tranny skid, and T-case skid,
JCR gas tank skid,
and Omix-Ada front-end skid (replica of OEM front skid).
Charley3 is offline
