#1 | |
Wet floors
When it rains, water collects slowly on the floor of the driver and passenger side of my 1995 Cherokee Country. The carpey gets soaked and a small pool forms on the rubber mats. It is not an active leak that you can watch come in from any specific location and after removing the dash cowl, I can only find dry components. The undercarriage is solid as well. Anyone else experience this? Where could this water come from?
#2 |
wet
have you checked the seal on front windshield???i had a similar problem floor wet everything else dry until I listened on a dry day at highway speed the slightest whistle from the front windshield turns out the seal was installed poorly and the water ran behind the front windshield trim down the post and on the floor.its worth a shot b4 you drown bud check it out.
addicted to trails freedom and jeep 1991 xj limited 4.0l ho full load 1989 xj 5inch lift 32x11.5x15 mudders on eagle mods 1995 jeep yj (project bogger) |
#3 |
Thanks for the reply. I do notice that the seal is not well installed and drying out in some areas. I did pour 3 buckets of water over the windshield without any leaks though. That doesn't mean it isn't the problem, it may just mean that a long downpour eventually meets a saturation point where it finally leaks in. I will probably reinstall the windshield. It can't hurt.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
