#1 | |
Wet Floors?
Ok, when I use my AC the passenger side floor gets soaked. I have no idea what this is, I read about ti but completely forgot what was wrong, and consiudering I cant search, would any of you remember the problem that is?
And how do I fix it?
I wanna go so fast I think im gonna die.... Then shift into second... |
#2 |
It's the condensed water that gets inside, the drain tube is quite propably clogged. Pretty common on XJs.. but don't ask me where the exact location of the drain tube is, never needed to clean mine since the AC is not working. I guess it's right in front of the firewall on the engine side, at least on mine there are two tubes hanging next the the right hand side LCA - those look like drain tubes to me..
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc.. http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/ 1990 XJ Limited (4-door), 4.0 I6, AW4, NP242, ***rolled and totalled @ 165k miles*** ***Under construction*** 1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc... http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/ |
#3 |
It's definitely that the drain tube is clogged. Same thing happened to my wife's Grand Cherokee and my Dodge Ram. We took the Grand in to a local shop, they lifted it up and took about 20 minutes to clean it out. A bunch of crap fell out of it. I can't remember exactly where the tube is though.
#4 |
the drain tube is located on the firewall a few inches below the inlet/outlets for the blower box...........should be a little rubber tube pointing downward
if you're lucky, you just have debris in the tube.........rather than an actual leak in the box
2001 Cherokee Limited 4.0 ~ AW4 ~ 4x4 ~ D30/8.25 ~ OME suspension ~ ZJ rear brakes |
#5 |
my tube was upside down when i got it....all i had to do was turn it over and it was fixed....that was of course when my A/C worked
#6 |
wow, you have been having bad luck with your jeep lately, don't give up on it!
But now definately pull the carpet and dry it out. you will thank me when your jeep doesn't turn into my black one in 6 months.
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#7 |
Nah dude, this problem has been fro a while, but I LOVE my truck, so im Not going to give up on it!
Ok, im gonna go try that drain tube... Thanks guys!
#8 |
I know this sounds dumb.. Anyone have any pics of this thing, I cant seem to find mine...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
