Went wheelin today (pics) - JeepForum.com
post #1 of 12 Old 02-07-2009, 01:37 PM Thread Starter
4lmudn
Finished up my suspention lift so I went out to my hunting spot today. It handled really well.
I noticed when I was going over bumps and turning I would hear a knock under my feet. So I had my buddy steer left to right. I found the problem.
Were the trackbar bolts onto the axle bracket the hole has been worn oval. I could tell with out taking the bolt out by how much it was moving. I am trying to think of a way to fix the problem. Maybe by getting a grade 8 washer and welding it on the bracket on the bolt head side. Any advice I need it.
4lmudn is offline
post #2 of 12 Old 02-07-2009, 01:38 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
click free.
88XJSport is offline
post #3 of 12 Old 02-07-2009, 02:39 PM
89SAFARIXJ
1989 XJ Cherokee
same thing happened to mine. ive just left it so far. its really annoying. you could cut it off and weld a new plate there. or you could drill a new hole and buy an adj. trackbar.
-Sean
89SAFARIXJ is offline
post #4 of 12 Old 02-07-2009, 03:16 PM Thread Starter
4lmudn
did it make that clunking sound?
4lmudn is offline
post #5 of 12 Old 02-07-2009, 03:29 PM
beater_xj
I think welding the washer would work fine. You may want to weld on 2 or 3 washers thick to prevent it from wearing out again.
05' Rubicon 6spd - 4" Saavy w/ Bilstein, 35" MTR
08' BMW 335i 6spd - JB4, FBO, E40 12.39@115.5
beater_xj is offline
post #6 of 12 Old 02-07-2009, 03:50 PM
JimmyDiablo
1987 XJ Cherokee
I need to get out and do some wheeling.
"Gay, Stupid and Dumb" are not words that apply to inanimate objects, period.
When you deal with adults, expect to be corrected.
JimmyDiablo is offline
post #7 of 12 Old 02-07-2009, 09:37 PM Thread Starter
4lmudn
thanks beater xj!
4lmudn is offline
post #8 of 12 Old 02-07-2009, 10:57 PM
1996jeepxj
jeep looks good!
clayton 3 link, 35" mtx, lockers, 12,500lb winch, arb safari snorkel
1996jeepxj is offline
post #9 of 12 Old 02-07-2009, 11:14 PM
Stout95YJ
drill the axle mount hole out larger so its not oval to use a wider bolt and correct size bushing sleeve
Stout95YJ is offline
post #10 of 12 Old 02-08-2009, 09:31 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That's only an option if the aftermarket trac bar bushing can be made larger. Best/easiest way to do this is to weld on a new piece of metal to it and drill it o the stock size.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #11 of 12 Old 02-08-2009, 11:14 AM
Billet
Im with Balloo on this on, also make sure your threaded side has some metal left, and not loose and wallered out
Oh! Dude, You Broke It.
awesome fluid chart,
Billet is offline
post #12 of 12 Old 02-08-2009, 01:57 PM
racerdude_9
i agree if your gonna do it you might as well do it right. either that or make it better then it was stock. which in my book thats still doing it the right way lol
-1998 cherokee xj limited.. current daily driver.
-1991 dodge w250 cummins.. old daily driver and regular tire burner
racerdude_9 is offline
Wheelin pics from today Swagger_Wagon XJ/MJ Cherokee Non-Technical Forum 25 08-07-2009 06:09 PM
Did some wheelin' Today.... {pics} wolfepack215 XJ Cherokee Technical Forum 3 02-24-2007 06:11 PM
Wheelin Pics from Today 5-17-06 90XJGuy XJ Cherokee Technical Forum 3 05-17-2006 09:40 PM
Wheelin Pics from Today AustinXJ13 XJ Cherokee Technical Forum 17 03-12-2006 12:27 PM
Done gone wheelin today (pics) mbood82 XJ Cherokee Technical Forum 20 06-24-2005 01:24 PM
