Went to remove bolts from tps and stripped one of the bolt heads - JeepForum.com
post #1 of 6 Old 08-19-2012, 02:46 AM Thread Starter
XJ99Josh
Would a needle nose vise grip work to free the bolt?
XJ99Josh is offline
post #2 of 6 Old 08-19-2012, 08:34 AM
JGriff99xj
If you can use a dremel tool just cut a flat into the head of the bolt and get it out with a flat head screwdriver.
JGriff99xj is offline
post #3 of 6 Old 08-19-2012, 08:58 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Remove the throttle body from the engine. Grind the head off the stripped bolt and remove the TPS by sliding it off. Remove the remains of the bolt with a ViseGrips. Heating the bolt and throttle body slightly with a propane torch will loosen the thread lock compound. Get replacement cap screws at the hardware store.
The bolts are very firmly locktighted in place and this will not work.
CJ7-Tim is offline
post #4 of 6 Old 08-19-2012, 10:05 AM
AZ Jeff
2014 JK Wrangler
This happened to me. I used need nosed Vice-Grip AFTER I heated the local area of the throttle body with a propane torch. It came out no sweat.
I used stainless steel socket head cap screws and some Never-Sieze when I put on the new TPS.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 6 Old 08-22-2012, 03:30 AM Thread Starter
XJ99Josh
Thanks guys got it off hit the head a few times
And it came right off after a few twists
XJ99Josh is offline
post #6 of 6 Old 08-22-2012, 03:42 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Don't use LocTite - #242 is too strong, and #222 is even a bit much.
What do I use? Fingernail enamel. Works great! It's strong enough to hold, light enough to break easily, and elastic enough to allow for adjustment without reapplication. I use clear for threadlocker on small screws, and white for bringing out witness marks, matchmarks, and timing marks.
(I started out by using fingernail enamel for riflescope screws, and decided it worked really well! Anything under #10 or M5 gets the stuff on the threads, I only use LocTite #222 if it's something I don't plan on needing to adjust from time to time.)
If the screw breaks, I usually just cut the head off with a Dremel and clamp on it with a Vise-grip, once the sensors is off (since I'm probably replacing the sensor anyhow.) If you cut carefully, you won't gouge the housing - and there are usually washers under the screw head anyhow. Using a regular cutoff wheel instead of the reinforced will give you more control over the cut, and the wheel is smaller so you're less likely to hit something important.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
broken tps screw , stripped tps screw
