Weird Temp Signature - JeepForum.com
post #1 of 5 Old 01-30-2012, 11:54 AM Thread Starter
jmaxey27
Hey guys.
I recently had a great little go around with my cooling system after it my 99 XJ Sport overheated. I ended up completely replacing the radiator, t-stat, t-stat housing, electric fan, and some hoses.
I don't know if this is a huge problem or not, but my temp fluctuates between 210* and back down to the immediately lower hash-mark.
My assumption is that the new radiator is doing its job really well and bringing my 50/50 mix down to a nice, low temp.
But... when I let it idle for a little while, the temp goes up to around half-way past the 210* hash mark. The electric fan takes care of it and keeps it there, but I'm a little concerned that this is happening in the deal middle of a cold winter. I don't want to leave it alone and then end up overheating again come spring.
If anyone has any thoughts on this, I'd love to hear em!
Thanks
jmaxey27 is offline
post #2 of 5 Old 01-30-2012, 12:14 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What is the condition of your water pump ?
The temperature should stay steady in a very narrow range of 190*-210* with very little fluctuation. You description of the symptoms is a little vague, what temp is a "hash mark" ? Can you estimate your temperature fluctuations ? Do you have full dashboard gauges or just idiot lights.
You should buy or borrow an Infrared Temperature Scanner and confirm you engine temps by testing at the thermostat housing.
CJ7-Tim is offline
post #3 of 5 Old 01-30-2012, 03:41 PM
Carves
As CJ7-Tim said ... There should be very little needle movement displayed on the dash gauge ...
In fact, with a good cooling system - you need a scan gauge or similiar - to pick up on the few degrees variation ... as the factory gauge is not much better than a warning light.
Prolonged idle however ... will usually cause an increase in temp ... and the aux fan will kick in if nescessary.
The longer its left idling ... the more often - the heat up/fan on/fan off, cycle will continue.
If its reaching the ... aux fan turn on temp, very quickly at idle ... you might want to consider the condition of the fanclutch.
Waterpump could also be a factor.
If the temp gauge needle is moving around a fair bit whilst driving ....
- Have a look at the Coolant Temp Sensor connector and ensure its clean and secure on the CTS,
- Try another thermostat ... Not a different temp rating ... just another 195* t'stat.
Carves is offline
post #4 of 5 Old 01-30-2012, 04:10 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
And what "brand" thermostat should he try Carves???
Just a little "inside joke" as I always rave about the quality of OEM Jeep stats.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 5 Old 01-30-2012, 04:22 PM
Carves
Now Now Mr Walker ...
I already, partly joined - the "lemmings brigade" by stating ... a 195* t'stat ... ..
But ..... at this time of year when all your bears are snoozin, you've got 20' of snow in ya backyards and glaciers sliding past the mailbox ...
.... its probably the best choice of temp rating ....
Carves is offline
cooling system , temperature gauge
Water Temp actin Weird 1984XJ XJ Cherokee Technical Forum 7 08-08-2010 08:51 PM
weird change in temp wyojeep92 XJ Cherokee Technical Forum 8 01-15-2009 08:55 PM
Weird Temp Gauge SmittysXJ XJ Cherokee Technical Forum 5 04-07-2005 12:11 AM
Weird idle/ temp issue Herdfan XJ Cherokee Technical Forum 3 04-06-2005 09:23 PM
Signature kingfish XJ Cherokee Technical Forum 12 06-08-2003 12:43 AM
