weird rear wiper - JeepForum.com
post #1 of 13 Old 02-03-2009, 06:58 PM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
weird rear wiper
okay, so today out of the blue, whenever i depress the brake pedal, the rear wiper just comes on. it will even wipe intermittantly if i am at a stop light and keep my foot on the brake. otherwise, while i'm driving, it behaves normally.
the switch is turned off.
so, before i tear into it tomorrow, i wanted to know if anyone has seen this one, or have any constructive ideas about where to begin...under dash, etc.
it's a 97 sport, AT, I6
gracias.
97 Cherokee Sport
jcrowley is offline
post #2 of 13 Old 02-03-2009, 07:04 PM
jeep95xj
1995 XJ Cherokee
Id check for broken and or pinched wires in the harness going from the keep into the tail gate. Check in the rubber boot.
jeep95xj is offline
post #3 of 13 Old 02-03-2009, 07:08 PM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
yep, i did a quick 5minute check in the dark with a flashlight, and didn't "see" anything obvious.....sorry for the pun.
i replaced the switch at the dash about a year ago. it would only work in the "wash mode" but not in intermittent. so, i dunno.
thanks for the advice. hopefully i'll post some results if i figure it out.
jc
97 Cherokee Sport
jcrowley is offline
post #4 of 13 Old 02-03-2009, 07:12 PM
jeep95xj
1995 XJ Cherokee
Have you had the kick panel or sill plates off lately? Run any wires? May have pinched the wiring when putting it back together. I work on cars every day i figure stuff like this out all the time but this is a new one for me lol.
jeep95xj is offline
post #5 of 13 Old 02-03-2009, 07:16 PM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
nope, nothing of the sort really. i just got my dogs out of the back, closed the hatch, and on the ride to work i noticed the wiper moving every time i pressed the brake. it all just happened today.
i'll find out more tomorrow, or the day after i'm sure. it's just weird that it's happening as i press the brake even with the wiper switch off. it's getting power somehow.
97 Cherokee Sport
jcrowley is offline
post #6 of 13 Old 02-03-2009, 07:25 PM
jeep95xj
1995 XJ Cherokee
Yea thats why i said check the wiring between the jeep and the hatch focus on the wiring in the rubber boot. Id be willing to put $ of the fact thats where your problem is. Kinda funny actually lol Here's a thought, turn your rear wiper on and see if your break lights come on.
jeep95xj is offline
post #7 of 13 Old 02-03-2009, 07:35 PM
LilRedDakota
bad ground for brake lights back feeding through rear wiper motor? don't have schematic to figure it out
LilRedDakota is offline
post #8 of 13 Old 02-03-2009, 08:00 PM
AZ Jeff
2014 JK Wrangler
I am betting the issue is that the wire that feeds the high mounted center stoplight is cross-feeding to the power wire to the wiper motor. Of course, for that to happen, both wires must be broken, or at least have the insulation off of them where they are adjacent to each other in the wiring harness. The area where the harness passes through the hatch hinge line is the likely area for this issue.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #9 of 13 Old 02-03-2009, 08:27 PM
jeepkid03
Winning
jeepkid03's Avatar
haha I've never heard of that before. I bet it gets annoying though. I agree with the post above about the insulation wearing off and the two wires contacting each other.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #10 of 13 Old 02-03-2009, 08:40 PM
dameono4
dameono4's Avatar
i had something kinda similar happen to me... everytime i hit the brakes the entire dash would short out, speedo, tach, radio, everything. It ended up being a wire in the rear of the jeep almost in between the speakers in the headliner. just an idea.
hope it helps, chris
1999 Cherokee Sport
dameono4 is offline
post #11 of 13 Old 02-05-2009, 07:17 AM
jeep95xj
1995 XJ Cherokee
So whats the verdict, you figure out your problem?
jeep95xj is offline
post #12 of 13 Old 02-06-2009, 04:18 AM Thread Starter
jcrowley
jcrowley's Avatar
1997 XJ Cherokee
no verdict yet. i pulled the rear hatch panel and unplugged the wiper motor for now. i got put on some overtime at work, so it looks like a saturday job now.
thank you all for the suggestions.
97 Cherokee Sport
jcrowley is offline
post #13 of 13 Old 12-10-2009, 09:36 PM
mbat11
1997 XJ Cherokee
I have a 97 xj with the exact same problem. So I took out the fuse (number 22) for the rear wiper and now the wiper stays put but every time I put on the brakes the rear washer fluid pumps out. You go through a jug in a day. Too bad the original author of this post did not circle back and post the verdict. I will check the wires for insulation at the tailgate.
mbat11 is offline
Rear Wiper? JRS0428 XJ/MJ Cherokee Non-Technical Forum 9 07-28-2009 10:28 PM
Rear wiper Justin1805 XJ Cherokee Technical Forum 1 03-14-2008 12:04 AM
Rear defrost and rear wiper switches darkwing XJ Cherokee Technical Forum 6 02-08-2008 02:15 PM
XJ rear wiper XJ_DIESEL XJ Cherokee Technical Forum 9 02-17-2007 11:08 PM
Weird Wiper Jmila1901 XJ Cherokee Technical Forum 10 02-04-2006 10:12 PM
