Weight of xj ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Weight of xj ???
Engo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air lockerIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-14-2007, 02:09 PM   #1
Gsmyth75
1992 XJ Cherokee
Weight of xj ???
On the thread where it says all the cherokee facts it says "curb weight 4wd = 3,057 lbs - 3,386 lbs" but today on my door it said gross vehicle weight something like ... 4900 lbs. Does anyone know what a 4wd auto xj weights b/c if it actually weighs 5000 then that would suck... alot
1992 Cherokee Laredo 4.0 L6, Aw4, Dana 30/35, Np242, 201k
Crower p/n 44243 Camshaft, Camsaver High Oiler Lifters, He Pistons .030 Over, Decked Block and MIlled Cylinder Head. Melling High Volume Oil Pump
Flowmaster Super 40/ Cat and Tailpipe Delete, Apn Header, Homebrew Bored Throttle Body, Rustys Cold Air Intake with Spacer
Gsmyth75 is offline   Reply With Quote
Unread 05-14-2007, 02:13 PM   #2
XJLI
1993 XJ Cherokee
the gross vehicle weight rating (GVWR) is the maximum loaded weight rated for the Jeep. as in, the max it should weight when packed full of crap.
Factory Four Link
XJLI is offline   Reply With Quote
Unread 05-14-2007, 02:15 PM   #3
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Mine weighs a little under 4000 i think. But i ussally carry a bunch of crap.
Arcticcat843 is offline   Reply With Quote
Unread 05-14-2007, 02:22 PM   #4
UltimatE
Resident Audio Guru
UltimatE's Avatar
Stock weights are between 2900 and 3,200 lbs IIRC. GVWR is the maximum the vehicle can handle loaded + vehicle weight.
XJ's are actually very light vehicles and I hopefully will one day make a street sleeper LS1/M6 combo.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 05-14-2007, 02:22 PM   #5
XJ99
Last time I got weighed, I (the XJ) came in at 4,000 lbs.
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is online now   Reply With Quote
Unread 05-14-2007, 02:47 PM   #6
JeepFreak91
Quick ?, does curb weight include all fluids?
JeepFreak91 is offline   Reply With Quote
Unread 05-14-2007, 03:04 PM   #7
XJ99
Curb (kerb) weight is the total weight of a vehicle with standard equipment, all necessary operating consumables (such as motor oil and coolant), a full tank of fuel and not loaded with either passengers or cargo.[1]
http://en.wikipedia.org/wiki/Curb_weight
Unread 05-14-2007, 03:28 PM   #8
ChewyXJ
nom nom nom
ChewyXJ's Avatar
I had mine weighed on some commercial scales a couple years ago. I was leaving on a 2 week trip to Moab and was loaded down with lots of stuff, plus me (180lbs) and my dog (120lbs). She weighed 3,985lbs. I'm guessing she weighs under 3400 lbs empty.
Weight was one of the issues that convinced me to buy an XJ. I do a lot of snow-wheeling and wanted a light rig that could carry lots of junk.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline   Reply With Quote
Unread 05-14-2007, 05:52 PM   #9
Gsmyth75
1992 XJ Cherokee
ok, thanks my friend had me confused about it.. I just figured since its unibody and all, it should be fairly light
Unread 05-14-2007, 07:43 PM   #10
severous01
i call BS...
i looked at my sticker yesterday and it says curb wt: 4900lbs
i have a 94 xj sport. that's 4wd and no power options like windows or locks, and no keyless...just the necessities to off-road.
curb is with no gas or near the E, and regular fluids needed to run...tranny, engine, diff fluids, coolant and all that jazz...also, washer fluid.
severous01 is offline   Reply With Quote
Unread 05-14-2007, 07:47 PM   #11
bmyohn
Youngin'
bmyohn's Avatar
i pretty much maxed out my XJs payload with 37 bags of shredded mulch, each weighing 38 pounds
so u do the math on how much that is
2011 Dodge Ram 1500 Big Horn 4x4
5.7L V8 Hemi
"The Tow Rig"
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline   Reply With Quote
Unread 05-14-2007, 07:48 PM   #12
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by severous01
i call BS...
no way in hell the XJ is 5,000lbs... its between 2,900 and 3,300 depending on the options.
-Matt
White '94 YJ Sport
Unread 05-14-2007, 07:53 PM   #13
xj 98/yj 94
mine was weighed at the emissions center last year with 31's plus 31" spare, rack, lights, and system, and it came in 34xxlbs
'95 ZJ.... new DD
'98 XJ.... sold
'98 XJ.... Sold...(biggest regret)
'91 YJ.... Was mine,now dad's DD
'94 YJ.... Sold...
'95 ZJ.... Sold, '04 TJ.... Mom's DD.....'97 TJ.... Sold
xj 98/yj 94 is offline   Reply With Quote
Unread 05-14-2007, 08:03 PM   #14
88XJSport
1988 XJ Cherokee
Last time I got it weighed, mine weighed precisely 3,042lbs. And mine has the 4.0, 231.......ah just read the sig...
88XJSport is offline   Reply With Quote
Unread 05-14-2007, 08:12 PM   #15
Chris_Walker
1988 XJ Cherokee
I'd imagine my XJ weighs a little under 1300 lbs.
Chris_Walker is offline   Reply With Quote
