weak brakes - JeepForum.com
post #1 of 8 Old 08-01-2014, 07:08 PM Thread Starter
Rossman123
1993 XJ Cherokee
weak brakes
So in my 93 xj my brakes are very bad and barely stop me. Im running 35s right now and didnt know if they would just need upgraded a bit or if theres a problem somewhere? I recently changed the brakes all around and put a new wheel cylinder in the rear and have bled the brakes multiple times. What else could it be? And what things would be best to check first?
93' xj: 6.5in rough country suspension lift, 35in cooper discoverer stt tires,cragar d-window wheels
Rossman123 is offline
post #2 of 8 Old 08-01-2014, 08:57 PM
Paradise XJ
1988 MJ Comanche
Did you adjust the drum brakes with a brake spoon (or screwdriver[s])?? The star wheel on the adjuster needs to be adjusted all the way out until the wheel will just barely turn...and then backed off a turn or two.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 8 Old 08-01-2014, 08:59 PM
1stockjeep
1993 XJ Cherokee
Pedal go to floor? Do they get hot after a hard stop? Could be anything from bad master cylinder or booster to bad brake pads or needing to upgrade. Give more info about what it does
1stockjeep is offline
post #4 of 8 Old 08-01-2014, 09:02 PM Thread Starter
Rossman123
1993 XJ Cherokee
if i put the brake to the floor it barely stops me and if i ride them for very long at all like crawling down a hill or anything they get hot and barely work at all then. Doesnt take long at all for them to get hot.
post #5 of 8 Old 08-01-2014, 09:21 PM
1stockjeep
1993 XJ Cherokee
If goes to floor could be master cylinder, make sure rear brakes are adjusted as well
post #6 of 8 Old 08-02-2014, 06:41 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
With stock brakes and 35's, you should expect poor brake performance. You need top quality high performance brake pads and rotors, or a brake upgrade such as a WJ Grand Cherokee front disk brake swap, or rear disk brakes.
Google Black Magic brakes, and EBC brake pads.
CJ7-Tim is offline
post #7 of 8 Old 08-02-2014, 06:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do the WJ booster upgrade and makes sure your rear shoes are adjusted properly.
The brake pads Tim recommends are great also.
The booster upgrade is HUGE.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #8 of 8 Old 08-02-2014, 09:06 PM
Muddy97Cherokee
1997 XJ Cherokee
Should expect this with 35's and stock brakes although it does seem you have a weak point somewhere. Even so if you want to upgrade your brakes I suggest the WJ knuckle swap for better steering and brakes. Along with that ZJ or KJ rear disk swap. My buddy is capable to lock up his 35's and able to stop on a dime with that set up.
But to start out with I would check your booster and master cylinder. If they check out then I would seriously recommend you look into the WJ swap.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
