Water Pump Pulley Seized - JeepForum.com
post #1 of 15 Old 09-07-2008, 09:14 AM Thread Starter
MBJR9
This morning I discovered my water pump pulley is seized. I whacked it a few times with a rubber mallet, and then with a standard hammer. I started it back up and it ran fine for a few seconds, then it got stuck again.
I'm pissed because at this point I don't have the time nor desire to work on my rig all day (I do have the tools and knowledge however). I was wondering if anyone had any suggestions on how to get the pulley un-stuck so I could at least attempt to make it to my mechanics.
Thanks guys .
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless
The Daily Driver
2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg
MBJR9 is offline
post #2 of 15 Old 09-07-2008, 09:31 AM
tangofox007
Do you have tow hooks on the front?
tangofox007 is offline
post #3 of 15 Old 09-07-2008, 09:48 AM Thread Starter
MBJR9
Nope .
The XJ
The Daily Driver
MBJR9 is offline
post #4 of 15 Old 09-07-2008, 10:39 AM
AZ Jeff
2014 JK Wrangler
Thanks guys .
Trying to run the engine with a stuck pulley is going to trash the belt, and maybe other stuff too.
Either suck it up and fix it yourself, or pay for a tow....
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 15 Old 09-07-2008, 03:02 PM Thread Starter
MBJR9
I realize that, that's why I asked if anyone had any ideas for freeing the pulley/pump. I'm not stupid enough to try and drive 4 miles with a stuck pulley, not to mention a water pump which isn't circulating coolant.
What's the usual rate for a tow? $60 hook-up and $3/mi?
The XJ
The Daily Driver
MBJR9 is offline
post #6 of 15 Old 09-07-2008, 06:55 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
If you know someone with a truck and a hitch rent a tow dolly or car hauler from U-haul, rates run about $39 for a dolly to about $49 a day for a car hauler.
I rented a dolly once but only had a van to haul it since it was only a few miles I told them I was towing Honda Civic other wise it wont be a compatible match for towing and they wont rent it to you.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #7 of 15 Old 09-07-2008, 07:50 PM
UNCC_99XJ
I see in your sig that you DD a 5.7L HEMI Ram......got a hitch on the back of it?
If so, grab a uhaul dolley like mentioned, hook it up to the back of the truck and tow it on down the road to the shop.
--Tim
99 XJ, 4.0, AW4, NP242, JCR Stage 2 Front, 3.5" RE Super Ride, RE H&T SYE, 31x10.50 BFG A/T's, JKS Trac bar, a few lights.....my never ending money pit
UNCC_99XJ is offline
post #8 of 15 Old 09-07-2008, 09:06 PM
AngryBassets
AngryBassets's Avatar
A water pump is at the MOST a 3 hour job, if you have no idea what you are doing AND screwing off. Belt off, two hoses, few bolts off, done.
stale milk white 97 Police Package XJ (former FD gofer vehicle) bought in 11/08 w/ 41.6k**95 YJ 4cyl/5spd summer beater
Past Jeeps:97 XJ Sport 6cyl/auto, 00 TJ 6cyl/auto,95 YJ 4cyl/5spd 95 XJ SE 6cyl/auto, 93 YJ 4cyl/5spd
AngryBassets is offline
post #9 of 15 Old 09-07-2008, 09:57 PM
tangofox007
Another option might be to hire a mechanic to make a house call. That might be cheaper than a tow truck, especially if it's an after work, off-the-clock arrangement.
post #10 of 15 Old 09-08-2008, 06:14 AM Thread Starter
MBJR9
Yep, I do have an '04 Hemi with a hitch. That is something that crossed my mind. Do they include tie-down straps in the $49 price? I can't seem to locate any of mine.
Ya, 3 hours I didn't have time for. I've changed a water pump before but I'm SURE this damn thing would fight me tooth and nail. Everything I've done to this so far has been a PITA.
The XJ
The Daily Driver
MBJR9 is offline
post #11 of 15 Old 09-08-2008, 12:39 PM
Rtbeebe
1997 XJ Cherokee
I thihnk you can't have it both ways. Power steering pump locked up is a good reason to take off the pump or have a tow. The other option is to remove the belt, drive the few miles to the mechanic and let them do thier work. Not to many options if you don't have the time to do it yourself.
97 Cherokee sport 4WD w/ 4.0
Rtbeebe is offline
post #12 of 15 Old 09-08-2008, 12:58 PM
tangofox007
Speaking of having it both ways, where did the locked up power steering pump come from?
That could be an incredibly expensive option. Unless the trip is broken into several segments with lots of time for cooldown between each segment.
I had a belt break once about one mile into a drive. I had to drive another 1/4 mile to get safely off the road. By that time, the temp gauge was pegged to the hot side. Things ger hot fast when the coolant stops circulating.
post #13 of 15 Old 09-08-2008, 02:57 PM
murrayman23
1987 XJ Cherokee
you know....water pumps really arnt too hard to do. I did mine when i first got my XJ...it seized up....it wasnt hard at all.
"Rusty" 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.Half Herculined Half Navy blue
murrayman23 is offline
post #14 of 15 Old 09-08-2008, 04:23 PM Thread Starter
MBJR9
Power steering works like a champ .
The thought of removing the belt did cross my mind, then I realized how dumb that'd be. Driving w/o a fan might be do-able, driving w/o coolant circulation, no so much.
Yep, I know. I've done the job a couple times before, I just don't have the time to do it now. School started (hrs of homework), I work in the afternoons, and I've got a few things going on the side. 3-4hrs is something I don't have at this point.
Also, just in case anybody is wondering, I had it towed over there this morning and just picked it up. My mechanic said it was once of the worst pumps he has seen, and I agreed. The impellers were digging into the case and the bearing was TOTALLY shot. $300 some odd dollars later, she runs like a champ.
The XJ
The Daily Driver
MBJR9 is offline
post #15 of 15 Old 09-08-2008, 06:09 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
$300 for an $18 pump--wow! We just changed mine in the driveway--took right around two hours with my crappy tools.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
Water Pump Pulley LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 12 06-07-2011 04:47 PM
squeaking water pump pulley bearings = bad pump? Willy36 XJ Cherokee Technical Forum 17 09-09-2009 11:57 PM
Water Pump Pulley danw77 XJ Cherokee Technical Forum 1 02-17-2009 02:47 PM
bad water pump pulley, whole pump or just the pulley? xjmatt XJ Cherokee Technical Forum 5 05-14-2006 12:17 AM
Help-...water pump pulley Scurv XJ Cherokee Technical Forum 2 12-15-2004 07:20 AM
