Water Pump Died...New Engine Needed? - JeepForum.com
post #1 of 6 Old 01-16-2016, 07:28 AM Thread Starter
judbgrdmchn
My pump died & it ran hot several times as I limped home, adding water along the way. I now have low compression in cylinders 1 & 2, possibly more. Cylinder 1 came back at 30, I don't remember 2, & they stopped testing after that. Do I need a new engine, top end rebuild, head gasket, rings...? I had the engine rebuilt 2-3 years & would rather not do it again.
judbgrdmchn is offline
post #2 of 6 Old 01-16-2016, 07:30 AM
ravenworks
ravenworks's Avatar
I'd say that it's done.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 6 Old 01-16-2016, 09:10 AM
joshr1987
joshr1987's Avatar
Sounds like blown head gasket minimum, warped head is likely. Won't know until they pull the head off.
joshr1987 is offline
post #4 of 6 Old 01-16-2016, 02:05 PM Thread Starter
judbgrdmchn
Perhaps I should add that I'm still driving it & I'm the only one who can tell a difference in the idle. Aside from a slightly rough idle & the CEL being on, there's really nothing noticeably wrong with it.
post #5 of 6 Old 01-16-2016, 03:33 PM
boykinjw
Pull the head, have it checked for cracks and shaved to straighten if needed. Check the valves but their not expensive so I would put new valves and seals in while it's apart. Put it back together with a quality head gasket. Also you'll have to change your oil with the head job, if you wait to pull the head and still drive it change your oil now. The high temps could have compromised it.
2005 WK Hemi QDII
1999 XJ OME MD, 245/75/16 ST MAXX, ARB Bull Bar, Aussie Locker F&R
boykinjw is offline
post #6 of 6 Old 01-16-2016, 08:14 PM Thread Starter
judbgrdmchn
Thanks for the actual advice. I really appreciate it.
