WARNING: All 4.0 owners check your motor mount/block Bolts!!!! - Page 6 - JeepForum.com
 1Likes
post #76 of 249 Old 05-05-2009, 07:58 PM
escapeartist
Another method for drilling out broken bolts, go to a tool supply house and buy a left hand drill. Sometimes when you start drilling with one of these they catch and back the broken stud out or as the bolt warms up they come out. If it doesn't work you are no worse off and have a hole drilled the right size. The drills are usually about 10 bucks each and a higher quality cobalt HSS tool steel than the average black drills.
escapeartist is offline
post #77 of 249 Old 05-06-2009, 09:47 PM
94HOCHEROKEE
1994 XJ Cherokee
I heard a really good idea of taking a welding rod and welding it to the bolt, then after letting it cool down twist the bolt out. I heard it from my boss at Wally world TLE express after it happend to his cherokee. I guess his insurance adjuster meantioned how to get out, said it works 90% of the time. Thanx for the lines......
94HOCHEROKEE is offline
post #78 of 249 Old 05-06-2009, 11:46 PM
5-90
5-90's Avatar
1988 XJ Cherokee
A relatively common problem.
It's caused by the screws bottoming out in the holes. You're not establishing a tensile preload under the head when you torque screws that are bottomed out, you're establishing a compressive preload at the very end.
Problem is, a compressive preload in this application is totally useless.
The fix? Simplicity itself. Find out if/which screw(s) is/are bottomed out with a thin feeler gage (even .001" is too much, so use the thinnest gage you have.) If the gage slips in under the head, remove the screw and add a washer or two. Reinstall the screw and retorque.
Typically, the screw fails (due to a lack of preload and repeated shear stresses,) the head breaks off, and you're stuck with a broken screw shank. Then you have to drill and remove it - no fun.
Even with the full-length "Bombproof" engine mounts, check under the screw heads before you pronounce the job "done." Same thing - if you find any heads with room under them, install a flat washer and retorque. Easy.
If you see space under the head with your naked eyes, install two flat washers just to be safe.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #79 of 249 Old 05-15-2009, 09:29 PM
portcityXJ
1995 XJ Cherokee
just ordered brown dog mounts (no brackets, just mount) with poly bushings. i had enough space to fit my entire finger in the mount above the bolt where the bushing is worn/missing.
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #80 of 249 Old 09-02-2010, 08:01 PM
jeepsterguy
2011 WK
Originally Posted by brand0nlp View Post
i let my motor down just undid the motor mount, used a block of wood and a jack under the oil pan and carefully dropped it oto the steering arms. but kept the jack just snug underneath it so it wouldnt put to much weight on the steering components.
I realize that the thread is old but this just happened to my '96. Did you have to use a 90* drill?
jeepsterguy is offline
post #81 of 249 Old 09-02-2010, 10:21 PM
brand0nlp
no, actually when the bolts break its usually cause there already loose, i took a flat screw driver and a hammer and made indent in the bolt then i used the screw driver to take it out if the screw driver and hammer doesnt work use a thin cut off wheel, and make a slot for the screw driver. it shouldnt be that hard to take out the bolts.
96 cherokee with lots of goodys!
brand0nlp is offline
post #82 of 249 Old 09-03-2010, 07:20 PM Thread Starter
BrunoS
Old thread, I posted it. Very important to check. As for getting bolts out, whatever works. My single new bolt and motor mount plate to block weld has still held under full dd hammering . Two bolts were impossible to remove with 4 mechanics and a full shop.....
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #83 of 249 Old 09-03-2010, 07:51 PM
FairlanePhil
FairlanePhil's Avatar
Vendor link please!
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #84 of 249 Old 09-04-2010, 12:09 PM
jeepsterguy
2011 WK
I soaked them for a couple of days in Kroil, came out easily.
There is no reason that I can see for the bolts not to come out easily, the hardness of grade 8 assures a clean break and the tolerance in these bolts is sloppy. The only way I can see it happen is if the guy drills in to the threads. I used a pilot hole just to make sure I was straight and not hitting any threads. At that point I tried a small easy out and they came right off.
post #85 of 249 Old 03-03-2011, 03:44 PM
gretsch921
This issue just happened to my brother, I think i'll be changing my hardware to grade 8
gretsch921 is offline
post #86 of 249 Old 03-03-2011, 04:05 PM
jeepsterguy
2011 WK
The original are grade 8 and they don't do very well.
I bought some socket bolts that are supposed to be better than grade 8 and will install them first chance I get.
post #87 of 249 Old 03-03-2011, 04:30 PM
cbenez1
I believe the originals are grade 5
cbenez1 is offline
post #88 of 249 Old 03-03-2011, 04:41 PM
jeepkid03
Winning
jeepkid03's Avatar
Originally Posted by limited View Post
To the guys wondering about how to replace the bolts without an engine hoist; Take a jack and center it under the oil pan and use it to take the weight off the mounts. Be sure to use a piece of wood in between the jack and pan.
how strong is the oil pan? Is it okay to support it with the jack while replacing the mounts? I've never experienced this problem but would like to know for future reference. Does this problem occur more frequently in certain years?
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #89 of 249 Old 03-03-2011, 04:57 PM
ZexGX
1987 XJ Cherokee
Does anybody know the length and thread pitch of the bolts to replace? Thinking of replacing these with some high quality hardware before something bad happens.
Exactly what I was wondering!
'87 XJ 4 door 4.0L 4x4 420k+ miles - not enough mods
'99 Firebird V6+4L60E w/BAR certified LS1+4L60E swap - as many mods as the Jeep
ZexGX is offline
post #90 of 249 Old 03-04-2011, 06:45 PM Thread Starter
BrunoS
originals are grade 5.
Get new bolts, they're standard thread, nothing fancy, ensure new bolts are SHORTER than the factory bolts.
The factory bolts are about 1/16" too long and the bolt head does not clamp the motor mount against the block. This is what shears the bolt.
I'm at 180K DD miles, and repair is still holding.
BrunoS is offline
Motor mount bolts broken off in engine block skid2964 XJ Cherokee Technical Forum 29 06-21-2014 02:07 PM
Motor mount bolts broke off in engine block klockdoc XJ Cherokee Technical Forum 10 03-11-2014 05:52 AM
2 Motor mount bolts broke off in block, need advice ki1022 XJ Cherokee Technical Forum 2 08-24-2008 10:53 PM
Motor mount bolts broke inside of block.... XJ_jeepin_06 XJ Cherokee Technical Forum 5 10-31-2005 01:09 AM
Warning - Engine Mount bolts rabidfowler XJ Cherokee Technical Forum 9 06-06-2003 10:43 PM
