WARNING: All 4.0 owners check your motor mount/block Bolts!!!! - Page 4 - JeepForum.com
 1Likes
post #46 of 251 Old 10-12-2008, 12:07 AM
mud-dog27
hope i dont gotta go through that shiat i just replace my motor mounts with some bombproof ones and mine were nice and tight mind you i did notice that i only had 2bolts on either side instead of the 3 that are sposed to be there but hell i figure ive gone this long with 2 per side so meh
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #47 of 251 Old 12-24-2008, 09:55 AM
collkid
So all bolts at 27 lbs
Has anyone else heard of getting a tiny bit shorter bolts? this is suppose to be better for some reason?
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
post #48 of 251 Old 12-24-2008, 10:08 AM
Thegonagle
Thanks for the warning. My '96 has over 220,000 miles. She's not my daily driver (that's a stick-shift Honda Accord that gets 35 MPG on the highway), but I've grown quite fond of her, and I wish to keep her running for awhile yet.
Thegonagle is offline
post #49 of 251 Old 12-24-2008, 10:15 AM
loosenut
1997 XJ Cherokee
Would it be possible to take one bolt out at a time and replace it with a better one? Seems like an easy way to change out the old bolts without having to support the engine and do a whole motor mount at once. If my thinking is wrong, let me know.
loosenut is offline
post #50 of 251 Old 12-24-2008, 10:16 AM
mattathayde
the only way they could be better is if he standard bolts for what ever reason cannot reach all the way in and are to long to seat tightly, shorter bolts have less friction to keep them in and have less old in general so there is no reason they would be better unless like i said the full lengths cannot tighten in fully
-matt
mattathayde is offline
post #51 of 251 Old 12-24-2008, 10:18 AM
mattathayde
2 posts cause i saw this posed after i did my other one
i dont think its going to be possible to do that with no support, you may be able to squeeze it in but the engine is so heavy that i bet the holes will not alight properly to get it back in (if you can even get the bolt out to start with if there is no support to get the weight off the mounts)
-matt
post #52 of 251 Old 12-24-2008, 11:44 AM
tc90xjcherokee
1990 XJ Cherokee
Originally Posted by XJLI View Post
wash it.
they hold your motor up.
HAHAHA
Thats funny **** right thur
90 XJ Cherokee 236,000 miles, Still going strong/ New Red Re-Paint/ Rusty's TB Spacer/ AutoPal H4 Conversion/ Ford 19# Injectors from Five-O/ Every Sensor+ and the ECU Replaced/ Factory Power Windows,Door Locks,Tach Guage Cluster / 3" Rocky Road Outfitters Lift, 31" D**k Cepecs / Factory Tow Package, Spotless Cloth Interior, 20% Tint / CD/MP3/SD CARD/USB/iPod Deck with 1200W System, Cap, Obcon Comp. Series 1200 RMS Amp, Two 10" Visionik Subs, Sub-Zero Ported Box
tc90xjcherokee is offline
post #53 of 251 Old 12-24-2008, 11:48 AM
collkid
Yeah I thought that one was funny too.
I wonder if I should go Grade 8? some have some havent'...
Colorado Member #89
collkid is offline
post #54 of 251 Old 12-24-2008, 02:46 PM
Saudade
1988 XJ Cherokee
There have been other posts that claim the bolts are too long and bottom out in the holes instead of "clamping" the bracket properly. When I changed my pass side (2 broken), I did not observe this. The FSM calls out 2 different lengths for my 88. I did swap for Grade 8.
If the remaining bolts are tight, I don't see why you would not be able to swap them out one at a time. If the bolts spin out by hand once you have them loose, the new ones should line up fine.
Saudade is offline
post #55 of 251 Old 02-28-2009, 10:16 PM Thread Starter
BrunoS
7500 miles later. still running great, no cracks in weld; DD.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #56 of 251 Old 03-01-2009, 05:49 AM
NowMed
Word to mother!
Motor mounts are dangerous!
If you break a motor mount your truck might bite the dust!
Then start to rust!
Then your girl will have to drive and then start to fuss!
Check your motor mounts, ITS A MUST!
NowMed is offline
post #57 of 251 Old 04-12-2009, 01:41 AM
nrpalmer32
1987 XJ Cherokee
Nice NowMed. hahah Just bringing this back up because I do remember seeing my radiator fins crushed a little from the stock fan. Would this be a sign of the motor mounts going out? BTW I cant go out and check the motor mounts bc of where I am, so please no smart a$$ comments! lol The radiator is not completely damaged but it does have a large "ring" shown on the fins.
nrpalmer32 is offline
post #58 of 251 Old 04-12-2009, 01:30 PM
Buzzstrike
+1 on the pass. side bolts.
That's what I found out what was bad when I bought my XJ (for 400.00 off of CL) it only had 1/2 gear.
Thought it was the eng mounts. When I went in to replace said mounts I found the rt hand side eng. cushion bracket seperated from the block.
All 3 bolts had failed and were remaining in the block. I was able to remove two of them and replaced all hardware with grade 5.
I still have one shank in the block but will be comming out soon because I now have the proper tooling (drill) to get the M/Fer out.
I now have 204K on it and I bought it with 201K back in the first week of March.
To cool.
Buzz
Black Jeep Society Member
The rules of life.
1) Life is NOT fair.
2) Stupidity SHOULD be painfull.
3) Play stupid games win stupid prizes.
Buzzstrike is offline
post #59 of 251 Old 04-12-2009, 01:52 PM
Fox Fader
I better check mine. Juuust to be certain.
God Rules!
Fox Fader is offline
post #60 of 251 Old 04-12-2009, 02:00 PM Thread Starter
BrunoS
short answer: yes, check bolts
BrunoS is offline
Motor mount bolts broken off in engine block skid2964 XJ Cherokee Technical Forum 29 06-21-2014 02:07 PM
Motor mount bolts broke off in engine block klockdoc XJ Cherokee Technical Forum 10 03-11-2014 05:52 AM
2 Motor mount bolts broke off in block, need advice ki1022 XJ Cherokee Technical Forum 2 08-24-2008 10:53 PM
Motor mount bolts broke inside of block.... XJ_jeepin_06 XJ Cherokee Technical Forum 5 10-31-2005 01:09 AM
Warning - Engine Mount bolts rabidfowler XJ Cherokee Technical Forum 9 06-06-2003 10:43 PM
