WARNING: All 4.0 owners check your motor mount/block Bolts!!!! - Page 3 - JeepForum.com
 1Likes
post #31 of 245 Old 09-29-2008, 11:25 PM
xjpro
żAs preventive measure, will it be a good idea to extract OEM bolts on engine mounts and apply some anti seize, or will it be better to replace them with grade 8 ones?????
My XJ is close to 148k miles so I dont want any casualties with those darn bolts.-
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #32 of 245 Old 09-29-2008, 11:37 PM
mattathayde
if your going through the work of getting them out you might as well upgrade them.
only issue i see with putting anti seize is that you could make it shake out more easily. maybe a lighter thread locker since it would keep it from shaking out but should keep it from being able to seize since there will be something inbetween it but im not to sure
-matt
mattathayde is offline
post #33 of 245 Old 09-30-2008, 12:33 AM
Wisbar
Wisbar's Avatar
Is there something different with the 95/96 mounts? It seems to only happen in those years???
ΜOΛΩΝ ΛΑΒΕ
BLUE JEEP CLUB MEMBER #152
BUSHMAN'S JEEP CLUB
Originally Posted by Ski01xj
"your becoming more of a redneck every time the UPS man shows up"
Wisbar is offline
post #34 of 245 Old 09-30-2008, 07:24 PM
xjpro
So, since I have a 01 XJ shouldn't I be worry about this????
xjpro
01 xj limited
xjpro is offline
post #35 of 245 Old 09-30-2008, 07:34 PM Thread Starter
BrunoS
With the high torque output of the 4.0/ unibody design of the XJ, road vibrations are transmitted to motor mounts more than older full frame designs.
On stick shift XJ's, you have more vibration and rpm's than with automatic transmissions.
as bolts slightly vibrate, over a period of high miles (i've crawled web and found quite a few of these "sheared 4.0 motor mount bolts") near 140k where this becomes an issue.
as for bolts, the majority of body bolts use SAE Grade 5 bolts. Grade 8 are much stronger and are a huge pain to drill out and remove.
Personnally, I'd use grade 5 and blue threadlocker. Mainly prevents vibration loosening and prevents corrosion.
As the original poster of this thread, I'll update that my single bolt and fully welded factory "mount plate" (part of motor mount that bolts to block) is holding up perfectly to full throttle power. No cracks at any of the block boss/mount plate welds.
Again: I'd advise folks to just simply grab a torque wrench and CHECK you bolts...too damm easy to do, but what a pain when they shear off!!!!
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #36 of 245 Old 09-30-2008, 07:41 PM
4.0H.O.XJ
I checked the ones I could actually reach with a socket today, and they appear tight: Yet they appear to have a "spacer" washer behind them (between mount and block). Ill check them ALL tommorrow and let you know what I find. By the way, mine seems to fall into the "suspect" category, being a '96 H.O. motor, with over 200K and stickshift.
4.0H.O.XJ is offline
post #37 of 245 Old 09-30-2008, 09:42 PM
CherokeeErik
grade 8s arnt that hard to drill if you have the right bits, I do alot of them at work, so good drill bits of all sizes are readily available, I guess thats a different story at home for most people though
CherokeeErik is offline
post #38 of 245 Old 10-01-2008, 03:15 PM
XjoncampuS
Sounds silly, but my jeep is so caked in mud, I cant find the motor mounts. Someone enlighten me as to where they are exactly. :-P
XjoncampuS is offline
post #39 of 245 Old 10-01-2008, 03:18 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
wash it.
they hold your motor up.
Factory Four Link
XJLI is offline
post #40 of 245 Old 10-01-2008, 08:24 PM
XjoncampuS
Nevermind, I got em.
post #41 of 245 Old 10-02-2008, 07:38 AM
97babyxj
anyone know torque specs for motor mounts. to block, to frame, and the through bolt?? 97 4.o
99 XJ - A Fresh Start
97 XJ - Being 'fixed' (off the road for a while)
67 Chevelle Malibu - 327+th350 and some rust
97babyxj is offline
post #42 of 245 Old 10-09-2008, 01:11 PM
Crashogre
1994 XJ Cherokee
Ok, so now I'm a little nervous. I just bought my 94 XJ and one of the things that had been done was to replace the motor mounts. Now when I shift I hear a clunk near the passenger right side. Do the replacement mounts need tightening after a break in period? I'm not too mechanical so sorry if this is a dumb question.
Crashogre is offline
post #43 of 245 Old 10-09-2008, 07:40 PM Thread Starter
BrunoS
torque is around 27 ft lbs
check the bolts going in to the block, just above oil pan. it's three bolts, grade 5, with 3 hash marks (3+2= grade 5), going through the lower plate/motor mount INTO the block.
BrunoS is offline
post #44 of 245 Old 10-09-2008, 11:57 PM
afguy
The M.O.R.E. site lists the mounts for 91-96. That would explain why 97+ owners havent really commented on the problem. Ive owned 2 TJs prior to this XJ and I have never heard of any TJs having that problem.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies.
afguy is offline
post #45 of 245 Old 10-10-2008, 09:59 AM
skid2964
skid2964's Avatar
1995 XJ Cherokee
I'm in the damn broke motor mount bolt club to!
Went over a bump and the right side sheared off.
Item lost:
Fan shroud, Radiator and fan clutch, lots of time!
I used the M.O.R.E. mounts to get mine going again, they work like a charm.
skid2964 is offline
Motor mount bolts broken off in engine block skid2964 XJ Cherokee Technical Forum 29 06-21-2014 03:07 PM
Motor mount bolts broke off in engine block klockdoc XJ Cherokee Technical Forum 10 03-11-2014 06:52 AM
2 Motor mount bolts broke off in block, need advice ki1022 XJ Cherokee Technical Forum 2 08-24-2008 11:53 PM
Motor mount bolts broke inside of block.... XJ_jeepin_06 XJ Cherokee Technical Forum 5 10-31-2005 02:09 AM
Warning - Engine Mount bolts rabidfowler XJ Cherokee Technical Forum 9 06-06-2003 11:43 PM
