WARNING: All 4.0 owners check your motor mount/block Bolts!!!! - Page 17 - JeepForum.com
 1Likes
post #241 of 251 Old 03-09-2016, 12:34 PM
Hwdavis444
Quick Question i have what seems to be a motor out of a 97 xj that i am trying to put into my 87 xj and i cant seem to get the motor mounts to line up any reason for this or am i doing something wrong
Hwdavis444 is offline
post #242 of 251 Old 03-09-2016, 02:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Verify it's the correct engine.
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #243 of 251 Old 04-03-2016, 07:07 AM
photontraveler
Old Dude
photontraveler's Avatar
Thanks Brother for this info. You saved me a big headache and a lot of work. I have seen this warning a number of times but the importance wasn't apparent to me. I went out to the garage this morning and braced the motor with a jack and board under my 96. I first checked the passenger side. The bolts could not have been any tighter. I scooted over to the driver's side and the bolts were finger loose. I am very fortunate to not have experienced any damage yet. Again, thank you so very much.
"Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars."
photontraveler is offline
post #244 of 251 Old 04-03-2016, 07:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Kudos to you for being proactive and heeding the warning!!!!
post #245 of 251 Old 10-17-2016, 07:44 PM
hcredneck
1995 XJ Cherokee
had the 95 XJ in the shop not once but twice for the same thing, first time the bolt broke off i didn't realize it till the engine cut off on me, was able to push it in an empty parking lot (luckily) found out why my engine cut off and wouldn't start back up the distributor snapped in half. so word of advice. if the bolts snap on you for whatever reason especially the ones on passenger side right next to the distributor to save you a lot of money and time in to it by drilling out and putting new bolts into it and a new distributor make sure when the snap fix it ASAP not wait a few weeks/month or two after it happens to fix it. it'll cost you a lot more headaches trying to put a distributor in it.
hcredneck is offline
post #246 of 251 Old 12-31-2016, 01:25 PM
Kevin96XJ
Since I haven't been able to find this info, here is the bolt size, straight from the parts fiche:
.375-16x1.125
--OR--
3/8-16x1-1/8
I attached the image from the fiche for reference.
(admittedly I stopped reading the thread and just went to find this, so maybe someone already posted)
Kevin96XJ is offline
post #247 of 251 Old 12-31-2016, 05:21 PM
jeepsterguy
2011 WK
I had to change mine after the fact, I was not prepared and in a hurry. I went back with Homedepot bolts.
Later I bought much better quality, grade 9 IIRC, never had the chance to go back and replace them again.
I would look for the best quality I can find instead of going back with the original.
jeepsterguy is offline
post #248 of 251 Old 01-09-2017, 03:31 AM
ToddPaul
1990 XJ Cherokee
I just got my '90 XJ running today, I will definitely put this on my checklist of things to do . Just by visual , I got the impression they are in poor condition
ToddPaul is offline
post #249 of 251 Old 02-07-2017, 05:07 PM
Skidroadie
Put a set of Brown Dog rubber mounts on my '94 XJ and they are awesome! Took two hours and put my driveline back inline and lessened some vibes I was getting.
Skidroadie is offline
post #250 of 251 Old 05-23-2017, 12:44 PM
Robs2000XJ
Wow.. I think i'm going through this now. Thanks for the heads up!
Robs2000XJ is offline
post #251 of 251 Old 05-23-2017, 01:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I would. Believe me, it's no fun after the fact.
Motor mount bolts broken off in engine block skid2964 XJ Cherokee Technical Forum 29 06-21-2014 02:07 PM
Motor mount bolts broke off in engine block klockdoc XJ Cherokee Technical Forum 10 03-11-2014 05:52 AM
2 Motor mount bolts broke off in block, need advice ki1022 XJ Cherokee Technical Forum 2 08-24-2008 10:53 PM
Motor mount bolts broke inside of block.... XJ_jeepin_06 XJ Cherokee Technical Forum 5 10-31-2005 01:09 AM
Warning - Engine Mount bolts rabidfowler XJ Cherokee Technical Forum 9 06-06-2003 10:43 PM
