WARNING: All 4.0 owners check your motor mount/block Bolts!!!! - JeepForum.com
 1Likes
post #1 of 248 Old 08-16-2008, 12:11 AM Thread Starter
BrunoS
Grab a socket and check all the motor mount bolts that go into the engine block of your 4.0!!!! if any are loose, replace them now as odds are if ANY are loose then you have a stress crack in those that are NOT loose now! When the remaining bolts fail...you will be stuck with several sheared bolts in the engine block at best or cracked mounting bosses on the block.
Simply put....the right front (passenger) side motor mount/bolts that secure the lower mount mount to the engine block can vibrate loose a hair. This loads up the remaining two bolts, and they will start to stress crack. Then, on a normal highway drive without much load, go over a small bump and POP....The lower mount will then shear off the three grade #5 bolts that go into the engine block.
when this happens...the shifter will move 3 inches to the right, and you will hear the main cooling fan hitting the radiator shroud.....get off the gas, shut the motor down. you will save your radiator, a/c hard lines, and a bunch of other stuff.
To fix...my shop did everything but was only to get one bolt out. They replaced it with a new bolt, and heliarc welded the lower motor mount to the engine block bosses in two spots to prevent any movement or vibration from getting the plate loose ever again. If i ever pull the block, it can be machined off during the rebuild and the bolts removed.
i understand that a company is selling 'bomb proof motor mounts' for around $240 or so that utilize the 7 or 8 bolt studs available on that side of the motor. having seen what happened on mine...i hope i have saved everyone some trouble.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #2 of 248 Old 08-16-2008, 01:49 PM
jeepjack1995
1991 MJ Comanche
ive been there and it sucked.
1991 Comanche 4.0. Stock for now
1995 Cherokee 4.0. Built to the teeth, but sadly retired. R.I.P.
jeepjack1995 is offline
post #3 of 248 Old 08-16-2008, 03:16 PM
MudColoredXJ
MudColoredXJ's Avatar
Yep, happened on my 95 a few years back pulling out of the driveway. I basically had to unbolt all drivetrane mounting bolts and drop the motor/tranny/x-fer case as one unit. This enabled me to get a drill bit square on the sheared off bolts by going through the wheel wells. Got two out and replaced. The third was a lost casue. I also had to put a helicoil in one of the holes. Quite possibly the worst experience yet with my jeep.
1995 Red Sport 4-door 4x4
5-speed manual ax-15
d30 front, chry 8.25 rear with stock 3.07 gears
Carpetless with new floors and Red Durabak interior.
31 x 10.5 retreads
Cragar soft 8's (15x8 w/3.75' backspacing)
RE6030 (full packs) with .75" coil spacers up front
JKS adjustable trackbar and discos,
Rancho 9000 shocks with in cab controls
Custom Skyjacker style t-case drop
Extended rear brake line and 1995 stock YJ front lines
MudColoredXJ is offline
post #4 of 248 Old 08-16-2008, 03:44 PM
mattathayde
i loath helicoils, i feel your pain
-matt
mattathayde is offline
post #5 of 248 Old 08-16-2008, 08:52 PM Thread Starter
BrunoS
160 miles later...holding up well with the repair. Have now had several near full throttle freeway onramp blasts. The motor mount repair and all new bolts on both sides have really smoothed out engine vibration and accelerations feel "tighter" with less motor wobble. Jeimminny, wish I had known about this years ago!
Should be among the top things to check on any XJ besides a worn out cooling (primary) fan clutch!!!!
BrunoS is offline
post #6 of 248 Old 08-16-2008, 09:11 PM
91HeAp
Originally Posted by BrunoS View Post
100 miles later...holding up well with the repair.
Should be among the top things to check on XJ's besides the fan clutch!!!!
Newbe XJ (and Jeep) owner. check the fan clutch? thanks for the advice above will be under the ol' girl tomorrow.
91HeAp is offline
post #7 of 248 Old 08-16-2008, 10:42 PM
kadetklapp
1997 XJ Cherokee
Yes, grade 5 hardware for teh suck.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #8 of 248 Old 08-17-2008, 12:03 PM Thread Starter
BrunoS
Correct bolts for engine mount bolts that go into the block are Grade 5. You could use Grade 8, but good luck drilling those out if they should ever fail.
BrunoS is offline
post #9 of 248 Old 08-17-2008, 02:31 PM
Saudade
1988 XJ Cherokee
Best set of easy outs I've ever used.
The easy out itself is straight and fluted.
Each size has a matching collar that slips over it and allow the collar to slide up against the broken bolt/stud. This applies all of the torque to twist out the broken piece without snapping the easyout.
Using these, a right angle drill attachment and a centering drill, I was able to get the 2 broken bolts out of the block when my snapped off.
Saudade is offline
post #10 of 248 Old 08-17-2008, 02:32 PM
Si1ver03Rubicon
^ We use those exact ones in the military.
Si1ver03Rubicon is offline
post #11 of 248 Old 08-17-2008, 04:46 PM
JeepRide
JeepRide's Avatar
What is the brand name of those ez outs and where did you get them?
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #12 of 248 Old 09-25-2008, 09:39 PM
rod_serengeti
1995 XJ Cherokee
In 252,410 miles, X2 motor mount bolts. The first set failed in 2003 at 142,000 or so miles. This set lasted until I hit a big rut on a forest road.
Now there's grade 8 bolts in there. I have to figure these will at least out last the original engine.
rod_serengeti is offline
post #13 of 248 Old 09-25-2008, 10:14 PM
TwistedcaB-
1991 XJ Cherokee
could a vibrating at low speeds ( like parking lots ) till u get on the gas a little be motor mounts bein loose?
TwistedcaB industries
1991 XJ. 8" lift, 35" BFG KM2's. the new project
1990 XJ. 6.5 lift, 33" BFG ATKO's. SOLD : (
TwistedcaB- is offline
post #14 of 248 Old 09-25-2008, 10:36 PM
jeep_rider
Has mileage always above the 100k mark?
jeep_rider is offline
post #15 of 248 Old 09-25-2008, 10:44 PM
TwistedcaB-
1991 XJ Cherokee
if ur talkin to me i have 180k
Motor mount bolts broken off in engine block skid2964 XJ Cherokee Technical Forum 29 06-21-2014 03:07 PM
Motor mount bolts broke off in engine block klockdoc XJ Cherokee Technical Forum 10 03-11-2014 06:52 AM
2 Motor mount bolts broke off in block, need advice ki1022 XJ Cherokee Technical Forum 2 08-24-2008 11:53 PM
Motor mount bolts broke inside of block.... XJ_jeepin_06 XJ Cherokee Technical Forum 5 10-31-2005 02:09 AM
Warning - Engine Mount bolts rabidfowler XJ Cherokee Technical Forum 9 06-06-2003 11:43 PM
