#1 | |
warm just warm
97 jeep cherokee sport 125000 miles and the heat is just warm doesnt really get hot any suggestions???? i have not replaced the thermostat yet thinking that may be the problem jeep runs at about 160 degrees
,=====o00o //___l__,\____\,___ l_--- \___l---[]lllllll[] _ _(o)_)___(o)_)--o-)_) only in a JEEP |
#2 |
forum supporter
Search "blend door", your heat should still be hot even if it's really only running at 160*. My diesel Ram runs around 165 to 170* and the heater will run you out.
#3 |
Go Jeepin
Maintenance is always a good cure for problems.
Flush the radiator, inspect it for clogged passages and rot. Inspect the hoses. Replace both the radiator cap and the thermostat. Fill with 50/50 coolant mix and then test the coolant ratio.
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#4 |
thanks for the help gonna try thermo this weeek hoses all look good no rot no leaks and the rad cap is good alsp no leaks
#5 |
It's the crank sensor!
You really should try to get that temperature up. Your XJ is designed to run in the 200-210 range. I'd flush the radiator AND heater core. Install a factory OEM 195 thermostat (recommend buying directly from Jeep) and see where you're at. And as mentioned, be sure to test the coolant-water strength with a coolant tester.
99 Cherokee, 4.0 AW4, NP242 Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche Without "data", all you have is an opinion! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
