Wanting to stall right after start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Wanting to stall right after start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 03-27-2010, 08:09 AM   #1
whiteys_red_XJ
I Have a 96xj and lately it has been haveing a hard time starting it will keep clicking to try to start but dearly does but if it does start it stalls out right away but if I pump the gas as I'm trying to start it will start but I have to keep reving it to keep it goin but after about a min or less of reving it I'll stop reving and it's fine it doesn't stall while I'm driving and after I sart it this way it won't do this again for about a week this started happening after I put a k&n air filter in would that have any thing to do with this please help
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline   Reply With Quote
Unread 03-27-2010, 10:12 AM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
What you describe sounds like it very possibly is a marginal battery. Stalling and having to feather the throttle are classic symptoms of not enough voltage to keep the engine management system happy. As the engine runs for a while and the alternator charges it up a bit, it finally develops enough voltage to keep the engine mgmt. system supplied with juice and you are no longer symptomatic.
Start with having your battery LOAD TESTED. (also be sure battery cables/posts are shiny clean)
Load testing is the ONLY conclusive way of determining battery condition. Many parts stores will do this for you for free in the hopes of selling you a new one if you need it.
There are other possibilities but my money is on the battery and it must be eliminated first as a possible root cause.
Good luck and let us know what you find!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Unread 03-27-2010, 12:15 PM   #3
whiteys_red_XJ
I alrady had the battery and alternator tested there both good and the battery is pushing 120 more cold cranking amps then it's rated for
Unread 12-01-2010, 03:32 PM   #4
COLOUXJ
2010 JK Wrangler
having this same issue, and the battery is good, bump for some more ideas.
"When i die, bury me with my jeep. Its never been in a hole it can't get out of"
Black Jeep Society
My JEEP helped win a War > Your Honda mows my grass!!
Mechanical Engineers Build weapons Civil Engineers build targets
COLOUXJ is offline   Reply With Quote
Unread 12-01-2010, 03:55 PM   #5
tjwalker
tjwalker's Avatar
With the battery checking out, test the THROTTLE POSITION SENSOR.
96 xj , hard start , k&n , pump gas
