want to flush heater core,thinking muriatic acid, other ideas? - JeepForum.com
post #1 of 19 Old 11-02-2010, 07:11 AM Thread Starter
4x4xjCREW
i want to flush my heater core it seems clogged, does any one know if the heater core is made from copper or aluminum?
4x4xjCREW is offline
post #2 of 19 Old 11-02-2010, 07:19 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I'm not sure but I would be a little nervous that "pure" muriatic acid might be too strong. Not sure about diluted, but some dilution would be necessary I would think.
I've heard of people containing the heater core and filling it with vinegar or CLR though.
And somewhere there is a thread that contains the name of a stronger commercial product that supposedly works well. I will see if I can find it when I have time.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 19 Old 11-02-2010, 08:08 AM
BigSteve
why not just hit it with some compressed air. that will blow out any clog.
BigSteve is offline
post #4 of 19 Old 11-02-2010, 10:40 AM
Kevin108
Have you tried just flushing it both ways with a water hose?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #5 of 19 Old 11-02-2010, 10:45 AM
93ZJbeast
this ^ worked perfect for me on two jeeps. try it first, its free and easy.
**1988 Cherokee - the project
**2000 Regal GS - Supercharged, cammed, headers, laptop tuner, full suspention and ALOT more
**2000 zx9r - the speed freak
**2000 sea-doo XP - plain fun
93ZJbeast is offline
post #6 of 19 Old 11-02-2010, 12:51 PM
AZ Jeff
2014 JK Wrangler
If you are going to flush with corrosive chemicals, I would NOT use muriatic acid. I would use VINEGAR (acetic acid). It's far less "aggressive".
It would be pretty bad to see your heater core have a hole eaten through it, and have muriatic acid running out of the heater box onto the carpet and floor pan.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 19 Old 11-02-2010, 01:51 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
and compressed air might blow out the heater core or the radiator.
Any radiator flush product from the auto parts store would be a better idea than acid or compressed air.
CJ7-Tim is offline
post #8 of 19 Old 11-02-2010, 06:15 PM
jdumont
Yea I think it would make much more sense to use something designed to flush rads and heater cores than take the chance. Go stronger or longer on the off the shelf stuff before trying something that may cost you many hours to fix if it goes wrong.
jdumont is offline
post #9 of 19 Old 11-02-2010, 06:44 PM
BigSteve
I used compressed air on mine and it worked just fine. But to each his own. Either way acid is a bad idea.
BigSteve is offline
post #10 of 19 Old 11-03-2010, 06:56 AM Thread Starter
4x4xjCREW
Yeah, ill see what i can get off the shelf at the local auto parts, then maybe compressed air, it just sucks im freezing cuz i have no heat and i really dont feel like removing my dashh, but thanks for all the help guys!
post #11 of 19 Old 11-03-2010, 07:02 AM Thread Starter
4x4xjCREW
muriatic acid wont harm anything, unless its aluminum, if its made out of copper then the acid is harmless, does anyone know if the heater core is made out of copper or aluminum????
post #12 of 19 Old 11-03-2010, 08:51 AM
tjwalker
tjwalker's Avatar
I think that most of them nowadays are aluminum, but it is possible that both copper cores and aluminum cores are available. I've seen that with some other vehicles.
You could search an online parts store and see if it lists the construction material, but that still wouldn't confirm whether the one in your vehicle is copper or aluminum.
If you aren't sure, I would opt for something less aggressive like vinegar.
tjwalker is offline
post #13 of 19 Old 11-03-2010, 10:24 AM
Kevin108
A couple other things - are you sure your coolant is full and have you verified the one hot/one cold hose coming from the heater core?
Kevin108 is offline
post #14 of 19 Old 11-03-2010, 12:55 PM
AZ Jeff
2014 JK Wrangler
WRONG. Muriatic acid is more correctly called "hydrochloric acid" and it will MOST CERTAINLY eat brass, copper, steel, aluminum and ANY OTHER METAL, given contact for sufficient time!!!
Hey go ahead, knock your socks off, and do some hillbilly cleaning procedure on your heater core. Just don't come back here reporting heater core leaks when the danged thing gets a hole eaten it and it blows out under pressure.
AZ-Jeff
AZ Jeff is offline
post #15 of 19 Old 11-03-2010, 01:54 PM
Paradise XJ
1988 MJ Comanche
CLR is the only thing I'd use for a heater core short of just replacing the thing.
C = calcium
L = lime
R = rust.
Unless you have something else in your cooling system, it's all you need.
Here's the MSDS for "muratic" acid: http://www.jtbaker.com/msds/englishhtml/h3880.htm
...and the MSDS for CLR: http://www.broward.k12.fl.us/rmt/MSD...%20-%20CLR.pdf
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 09:53 PM
Heater core bypass question and coolant flush firedogut XJ Cherokee Technical Forum 5 09-17-2010 09:59 PM
Can't flush radiator core cheepjeep96 XJ Cherokee Technical Forum 4 01-17-2009 10:06 PM
Heater Core flush question cobra XJ Cherokee Technical Forum 2 12-28-2008 12:26 AM
Heater core flush Grey4.0L XJ Cherokee Technical Forum 2 01-15-2007 09:07 PM
