Quantcast wanna bulid a bumper - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > wanna bulid a bumper
Old 08-30-2004, 10:13 PM   #1
Lucky13
hey guys i just want to know that if i build a tube bumper for the rear of my xj can i use the stock bumper mounts or will they not be strong enough to be pulled out by?
Me and my friends did acid in the woods, 'cuz there was much less chance of running into an authority fugure. But we ran into a bear. And that is way more of a buzz kill. I looked around and saw my friend swearing to prevent forest fires. Later, he came up to me and said, "Mitchell. Smokey is way more intense in person.- Mitch Hedberg
Lucky13 is offline   Reply With Quote
Old 08-30-2004, 11:10 PM   #2
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
You should do what I have. Use square tubing that inserts into the frame rails. Inside the square tubing you weld some nuts on to make removal and install a breeze. You have to cut a little square out of the rear, but it works very well. I'm no fabricator though, so I don't know what is the strongest, but its the same way a hitch mounts, so its gotta be strong.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 08-30-2004, 11:13 PM   #3
jandj
that is how my aftermarket one came so I had angle iron added to the bumper that connects to the frames.
sold my 96' XJ
Look'n to purchase now
jandj is offline   Reply With Quote
Old 08-31-2004, 09:20 AM   #4
Lucky13
so the stock mounts should be strong enough to be puled out by if i build a new bumper?
Old 08-31-2004, 09:24 AM   #5
denverd0n
NO!!! The stock bumper mounts are definitely NOT strong enough for pulling your XJ out of a stuck situation!
If you want to pull on the bumper then, in addition to mounts at the stock location, you need to get a set of the nutcerts that go into the frame rails and attach the bumper along those.
denverd0n is offline   Reply With Quote
Old 08-31-2004, 10:14 AM   #6
Doolittle
I tried running my 75 pound custom steel bumper with the stock mounts and when I got stuck it ripped the stock mounts right off. I would recamend running angle iron back about 12 inches on the frame rails( or unibody rails, whatever they are) and bolt it through a couple of times.
1995 Jeep Cherokee
4WD 2Dr SE
Emerald Green on Charcoal
4.0 Litre HO 5-Speed
Command Trac
D30/8.25
3in. BDS Lift
BDS shocks w/yellow boots
_Tires_
Front: noname 235's
Rear:(new)31x11.50 uniroyal larado rv's
[COLOR=DarkOrange][U]I don't give a rats *** about online jeep clubs jeep club[/U] member # 10010101100101001[/COLOR]
Doolittle is offline   Reply With Quote
Old 08-31-2004, 11:57 AM   #7
Kilhoffa
Here is a link to my jeep thread. You can see how I mounted the bumper. The bumper just bolts off and it is strong enought to be tugged on. I found this out friday night when I rolled my jeep into a hole. Two full sized trucks put chains on my bumper and pulled the jeep out and it didnt even budge.
http://www.jeepforum.com/forum/f11/wreck-repair-3-months-99510/
Kilhoffa is offline   Reply With Quote
Old 08-31-2004, 01:17 PM   #8
Lucky13
when can i get these nut strip thingys?
Old 08-31-2004, 01:34 PM   #9
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
They dealer ship sells them, but if your able to build your own bumper, you can make your own nut strip.
Matt
MY XJ PICS
Old 09-01-2004, 09:16 AM   #10
Lucky13
and how would i go about making these nut strips?
Old 09-01-2004, 09:54 AM   #11
denverd0n
I'd look for the nutcert strip at a junkyard.
Old 09-01-2004, 01:30 PM   #12
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
All you need are nuts and bolts and a little metal strip. Slide it into the frame rail and mark where then holes are. Drill them out and make sure they are still in the right posistion. Then tack the nuts to the metal peice and see if it fits.
Or like he said, you can get then at a yard, but it can be a pain in the butt, cause you have to remove the rear bumper, which can be a nightmare on a junkyard vehicle. Also, most XJs on have them on the passenger side, I thknk only the ones with tow packages had them on the driver side too.
Matt
MY XJ PICS
Glock Forum
